Old 3rd Apr 2012, 20:31   #1
Bogomip
... Yo Momma
Bogomip's Avatar
Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!Bogomip - it's over 9000!!!!!!!!1!1!1!!!
Home Media...
So, Im looking to move somewhere new - and I found this place tonight which was great, but the bedroom I would be occupying would be too small for a desk, meaning my normal setup would be a bit disturbed. I am therefore looking for a new solution to my file needs
So this is what I want.
Everything on my two external USB hard drives to be available over the wireless network as well as to my xbox, without either buying a wireless connector for my xbox or connecting my computer to anything. This means what ever it is will need an ethernet port and the ability to connect to xboxes, but also wireless and the ability for it to connect to my computer. I realise you can get NA Servers, but do they connect to xboxes OK? Do they have wireless?
Bogomip is offline   Reply With Quote
Old 3rd Apr 2012, 22:05   #2
TaRkA DaHl
Ultramodder
TaRkA DaHl's Avatar
TaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpit
You can get a synology has type thing with no drives that you just connect USB drives too and it shares them. On phone, cant remember the name.
TaRkA DaHl is offline   Reply With Quote
Old 3rd Apr 2012, 22:11   #3
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpit
I have no idea how good or bad they are but this seems to be made for such a situation.
Meebox NAS WiFi Media Server
again I have no idea how good or bad they are. Trying to find a review now which is proving difficult Meh, could always go back if unsuitable I guess.
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
AMD FX-6300-Gigabyte 990AX-UD3-MSi GTX660-Momentus XT-be quiet! E7-600W-Avexir 2x4GB 1600
Share And Enjoy!
Throbbi is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
