#1 |
Loft Gremlin
Is it dead?
Hi Guys,
I've started getting a windows error saying "Windows detected a hard disk problem" and basically tells me to back up my files and then change/repair/RMA the HDD. It started today and seems to pop up at random intervals ranging between 15 min to a couple of hours. How much do I panic? ![]() ![]()
__________________
Modified Silverstone Temjin TJ-07B - Core i7 920 - Asus Rampage II Extreme - 3x2Gb Corsair Dominator 1600MHz - GTX570 - 9600GT - 128GB Crucial M4 - 1tb Samsung Spinpoint F3 - Corsair HX1000W -Win 7 HP 64 bit - Samsung 206BW |
#2 |
It's big, and it's clever.
Hve you backed up? If not.... Panic.... Then back up.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623 EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered MOON | Thecus N3200pro 3TB RAID5
#3 |
Corsair Fan
This ^^ unless its not important information then take a sledge hammer to it and buy a new one
#4 |
Loft Gremlin
Yep, anything I care about is backed up, reckon now is a good excuse to hold off the monitor upgrade (again) and get a SSD?
__________________
#5 |
Corsair Fan
What size drive is it ? An ssd will never be a bad upgrade from a mechanical HDD
#6 |
Loft Gremlin
1 TB Samsung Spinpoint F3, just noticed I've spelt spinpoint wrong in my sig.
Have been mulling over getting one for a while but I can never justify it over a MB, GPU, CPU etc upgrade.
__________________
#7 |
I *am* the guy with two left hands
1) back up data
2) depending on hard drive manufacturer get the official tool for the specific brand : Western Digital Data Lifeguard Diagnostic Seagate Seatools Samsung - no idea, HUTIL probably, but i guess someone else will give you the exact name of the tool Test the drive, if it says it is bad then RMA it.
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04 |
#8 | |
Corsair Fan
, movies keep freezing and then drive is unresponsive. Fuuu such a bad time to buy a mechanical hdd now too.
#9 |
Still not as bad as few months ago. Preflood price of WD20EARX - 71 euro. Post flood price - 150-200 euro. Current price - 105-115 euro. Not the preflood price, but already lower than 1,5-2 years ago (at that time, it was 135 euro if i remember correctly).
__________________
#10 | |
Loft Gremlin
__________________
#11 |
Corsair Fan
Scan do still sell the F3, i have just looked
#12 |
Loft Gremlin
I can has linky please? can't seem to find it :<
__________________
#13 |
Corsair Fan
DOH didn't look properly, its only the 500GB well thats a fooker. Says direct RMA on samsung drives anyway so save the time and RMA it to samsung direct, i think thats where mine is going to end up
#14 |
Supermodder
A little offtopic, an appropriate second test to see if anything is dead = poke it with a stick.
__________________
| Intel Core i7 2600k | ASUS Maximus IV Extreme-Z | 2x4GB Corsair Vengeance DDR3 @ 1600mhz | | MSI GTX580 Twin Frozr II | | 64GB OCZ Agility 3 + 2TB Storage | CM Storm Stryker | Corsair TX750 PSU | Asus Xonar DX | Acer G245HQ | |Steam - [UK] Holcroft|
#15 |
Loft Gremlin
Yarp. Now,the question is: What shall be my new HDD?
__________________
#16 |
Corsair Fan
We talking SSD...if so, what size ? 128gb would be nice...i run an M4.
#17 |
Loft Gremlin
I was looking at that. Will my motherboard support it?
__________________
#18 |
Source Engine's #1 fan!
Okay, if your mechanical HDD is dead, there is one solution that might work when you have nothing to use. Grab the drive, find a hard surface, and just give it a good solid smack on the surface. Not hard enough to damage the exterior, but enough to dislodge any stuck parts. Obviously do it when the drive is powered off. It has saved a couple drives for me, and done nothing on a couple more. It's worth a try since if it doesn't work you haven't exactly lost anything you weren't going to use anyways.
__________________
The Brass Balls: i7 870 @ 4.2ghz | Cooler: CM Hyper 212+ | 8gb G.Skill Ripjaws DDR3 1600 | GPU: ZOTAC GTX 560 Ti 448-core 1,280mb | Motherboard: MSI P55-GD65 | Case: ThermalTake Element G | ThermalTake 850w PSU | Samsung Spinpoint F3 1tb | Corsair Nova 32gb SSD |
#19 |
Mac_Trekkie, are you serious ? For starters, he will lose warranty if he does that. Second, his drive works, but corrupts data. That means he has platter surface problems, and no "stuck parts".
__________________
#20 |
Loft Gremlin
Not whacking it on anything lol.
I'll decide and order whatever SSD I'm getting tonight and rma the f3 when it turns up. Other than the pop up,no issues so far apart from maybe a little slowdown in game loading so hopefully it will last until then. I think I might get a 128Gb crucial m4, seems like a good choice going by several members sig. The price seems reasonable too. I'm open to suggestion though. Either way, thanks a lot for the advice, much appreciated
__________________
| Tags |
| dead, error, faulty, hdd, windows |
| Thread Tools | |
