Old 4th Apr 2012, 12:27   #1
streetuk
Multimodder
streetuk's Avatar
streetuk has yet to learn the way of the Dremel
Custom PC for retina iPad?
Is there any timeframe for the custom pc app on the iPad to be updated for the retina display on the new iPad? I think it'd really add to the functionality....being that you can actually read the text without having to zoom in on everything!
__________________
Asus Maximus GENE-Z
Intel Core i7 2600K @ Stock
8192MB @ Stock
NVIDIA GeForce GTX 580
OCZ Vertex 3 120GB
streetuk is offline   Reply With Quote
Old 4th Apr 2012, 12:48   #2
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!
Use zinio, its better and I beleive it has been updated.
fdbh96 is online now   Reply With Quote
Old 4th Apr 2012, 16:06   #3
streetuk
Multimodder
streetuk's Avatar
Just looked, doesnt look like its been updated to support it. Just out of interest, does anyone know if it just takes a simple update of the app to support a retina display or would the devs have to put higher res text/images in?
__________________
Asus Maximus GENE-Z
8192MB @ Stock
OCZ Vertex 3 120GB
Old 4th Apr 2012, 17:17   #4
fdbh96
I *am* a Dremel
fdbh96's Avatar
Weird- on the app store it says it doesnt support the retina yet online people have said that it does in the new update :/
Old 4th Apr 2012, 20:27   #5
c.cam108
Hypermodder
c.cam108's Avatar
c.cam108 has yet to learn the way of the Dremelc.cam108 has yet to learn the way of the Dremel
Plain text will render at high resolution natively, as will any iOS UI elements (toolbars, tables etc). Any images will need to be scaled by the developers.
(I don't use the CPC app, but I'm a dev.)
__________________
[witty sig]
[/witty sig]
c.cam108 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
