Old 6th Apr 2012, 11:43   #1
it2perm
What's a Dremel?
it2perm has yet to learn the way of the Dremel
Review search
Hello,
I'm a new reader/subscriber to this magazine. I'm wondering if there is any kind of article search available. I'm looking for a way to find if specific components have been reviewed and which old issues I need to buy to read them.
/ Mikael
Sent from my GT-I9100 using Tapatalk
it2perm is offline   Reply With Quote
Old 11th Apr 2012, 18:40   #2
T2I3M
Multimodder
T2I3M's Avatar
T2I3M has yet to learn the way of the DremelT2I3M has yet to learn the way of the DremelT2I3M has yet to learn the way of the Dremel
Hi Mikael,
Have you looked around the Bit-Tech website. Most of the reviews are on here too.
__________________
AMD Phenom II 955-Cooler Master Hyper 212 Plus-Asus M4A78 Pro -ASUS DirectCUII 670 TOP-8GB DDR2 Ram-Samsung 840 Pro 256GB-1Tb Samsung HDD-Corsair HX750W-Fractal Design R3-23" LG W2361V Monitor-Windows 7 HP 64Bit-Logitech MX518
T2I3M is offline   Reply With Quote
Old 17th Apr 2012, 15:19   #3
it2perm
What's a Dremel?
Hi,
Thank you for your reply. I have looked on the website but if possible I would like to know if I can support the magazine if the specific reviews are in a issue.
//Mikael
Skickat från min GT-I9100 via Tapatalk 2
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
