Go Back   bit-tech.net Forums > Technology > Hardware
View Poll Results: Enermax Liberty 400W PSU Vs E8500 + GTX 480
YES, it will work flawlessly! 30 57.69%
NO, it will never work! 22 42.31%
Voters: 52. You may not vote on this poll
Reply
Thread Tools
Old 11th Apr 2012, 21:05   #41
Blogins
Panda have Guns
Blogins's Avatar
Blogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpit
My GTX 480 arrived today!
Exploring the installation of the EK water block it looks well put together but taking a peep inside I can see an awful lot of gunk! It doesn't look like corrosion to my eyes and cleans off to a nice shine with isopropanol. So I will need to strip the card right down before I even think about installing it in my loop. Looks like both the block and GPU will be treated to an alcohol bath. Also give me the chance to apply silicone grease to all the o-rings which I've found invaluable when it comes to water cooling.
__________________
|Fractal Design Define R3, Black Pearl (Case)|ASUS P8P67 Deluxe (Motherboard)|Intel® Core™ i5-2500K (Processor)|
|G-Skill 8GB DDR3 1600mhz Sniper 1.25v (Memory)|ASUS GTX 670 / Gigabyte GTX 670 (SLI Graphics)|
|Corsair Professional Series Gold AX 850W (Power Supply Unit)|Asus Xonar D2X PCI-Express (Sound Card)|
|OCZ Vertex 3 120GB (Solid State Drive - Boot)|OCZ Vertex 3 240GB (Solid State Drive - Games)|
Blogins is offline   Reply With Quote
Old 12th Apr 2012, 19:55   #42
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
ooo mine arrived today. you know what that means...... overclock off!
actually, no forget that. i'm on air and don't fancy being burned by the exhaust gases. lol
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts.
The_Crapman is online now   Reply With Quote
Old 12th Apr 2012, 21:43   #43
Blogins
Panda have Guns
Blogins's Avatar
But I have a weaker PSU so it's a fair fight surely!
__________________
Old 13th Apr 2012, 01:50   #44
The_Crapman
And it's Core 2 Duo versus Core 2 Quad i suppose. Here's my score on rather modest settings:
CPU and 480 both@stock, apart from a more aggressive fan profile to curb those temps. Heaven settings@ DX11, Tesellation Normal, Shaders High, x4 Antisropy, stereo 3d disabled, AA off and full screen at 1080.
your move....
__________________
Old 13th Apr 2012, 04:27   #45
Blogins
Panda have Guns
Blogins's Avatar
I'm cracking the Gelid cooler out for this fight!
__________________
Old 13th Apr 2012, 21:49   #46
Blogins
Panda have Guns
Blogins's Avatar
OH MY DEAR GOD! My GTX 480 with Gelid Icy Vision installed works flawlessly on my 400Watt Enermax PSU!
Currently at stock settings with EVERYTHING powered through the Enermax Liberty 400Watt PSU, including Delta fans at minimum speed. Running Furmark stability test the GTX 480 is under 60 degrees and the system is pulling under 470W from the mains.
Next stop I will try stressing the E8500 alongside Furmark.
__________________
Old 13th Apr 2012, 21:51   #47
LennyRhys
Silenced
LennyRhys's Avatar
LennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpit
Under 60 degrees? DANG! That's even better than my Gigabyte monster lol!
Now that's a good PSU.
__________________
i7 930 @ 4.2 :: Gigabyte X58 USB3 :: 6GB Elpida @ 1528MHz 6-7-6-18-1T
GTX480 SE :: Toughpower 775w :: 320GB & 2TB :: Cherry G80-3000HSMGB
LennyRhys is offline   Reply With Quote
Old 13th Apr 2012, 21:59   #48
Blogins
Panda have Guns
Blogins's Avatar
It's not even under water yet!
Just ran a light run on Prime95 alongside Furmark and it's now drawing over 500W from the mains. I'm very very happy with this result, what an amazing little PSU! Hopefully tomorrow I'll be able to run a more stressful test under Prime95 and really push the pedal to the metal.
If everything works fine on that angle then I'll take some benchmarks and look forward to putting the card under water and testing the overclock headroom this Enermax PSU can tolerate.
__________________
Old 13th Apr 2012, 22:23   #49
docodine
docodine's Avatar
docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!
Holy cow, I wonder if my PSU could handle that sort of load without crapping out.
Props for going through with it, I wouldn't have!
__________________
Intel i7-3820 @ 4.65GHz | GeForce GTX 480 | 4x4GB Vengeance | Asus Sabertooth X79
Silverstone TJ07 | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet
docodine is offline   Reply With Quote
Old 13th Apr 2012, 23:14   #50
Blogins
Panda have Guns
Blogins's Avatar
Thanks, It's my fun factor PC. Been through so many configurations over the years! Air cooled in various guises, GTX 8800, HD 4870, GTX 260, GTX 460 SLI and then a Geforce 210. Constantly wrestled with cooling the Northbridge and also burning out RAM at one stage! I think I'll settle for full water cooling and a GTX 480 for my final salute to this proud system.
Also did I get lucky? With my short series of tests the GTX 480 doesn't seem to be quite the electricity chewing monster it's been made out to be! I'd estimate a 50W difference to a GTX 260 from what I've observed.
__________________
Old 13th Apr 2012, 23:42   #51
The_Crapman
Currently bricking it. You'll probably smash my my heaven score now. First run on stock fan profile saw 82C! How did nvidia ever pass these cards for sale with these hsf's on!?
If I wasn't saving for the bits for modding my rig (and my mates wedding in vegas ) I'd go get a 3rd party cooler. Actually, f it. It'll be a good few months before then and I can't go cooking it before then!
__________________
Old 14th Apr 2012, 00:29   #52
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
My old 480 used to hit 100C I'm furmark with the stock cooler. It also used to cause my old OCZ 600w PSU to shut down. They really should have at least had better coolers.
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is offline   Reply With Quote
Old 14th Apr 2012, 04:27   #53
Blogins
Panda have Guns
Blogins's Avatar
It's not like the stock cooler isn't a serious piece of cooling metal though.
Perhaps it's the way air flows over the assembly that was the problem?
__________________
Old 14th Apr 2012, 14:51   #54
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.
It was pretty good cooler, in relative terms, but even a vapour chamber cooler would have had difficulty cooling fermi, as the Gtx 580 had lower leakage slow switching capacitors, that and the vapour chamber cooler all helped to make the 580 a completely different beast in comparison to the 480.
and good on the 400W liberty PSU, I knew Enermax where awesome, I don't think I'll ever use a different PSU company, and I reckon you could probably pull 600W from that PSU before it craps it's pants and calmly shuts down
__________________
i7 3930k/watercooled on 360 rad/Asus Rampage IV Extreme/16Gb Corsair Dominator GT 2133Mhz/Gtx 480/2 x Corsair Force GT 240Gb RAID0 /Silverstone TJ11/Enermax Platimax 1500W
thetrashcanman is offline   Reply With Quote
Old 14th Apr 2012, 16:36   #55
The_Crapman
It is a massive chunk of metal that's for sure. I didn't realise till I saw it in the flesh that the whole of the top is part of the heat sink. But it's quite thick and with only your case air flow to cool the top of it, it could be just retaining heat causing the whole of the thing to overheat.
__________________
Old 14th Apr 2012, 21:12   #56
Blogins
Panda have Guns
Blogins's Avatar
This is a test for my GTX 480 using Furmark Xtreme Burning Mode.
With my twin Delta fans on low the Enermax Liberty 400W was pulling just a shade under 500W from the mains.
__________________
Old 14th Apr 2012, 21:34   #57
Blogins
Panda have Guns
Blogins's Avatar
This is a test for my GTX 480 using Furmark Xtreme Burning Mode alongside a light test of Prime95.
With my twin Delta fans on low the Enermax Liberty 400W was pulling just a shade under 540W from the mains.
__________________
Old 14th Apr 2012, 22:06   #58
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
At least wind her up to 800 MHz and give me a fight... as I have just tweaked mine up to 825 at stock voltages...
Bog standard card ( Gigabyte stickered ! )
LOL
dunx
__________________
Asus P6T7 WS Revo. + Asus U3S6 - i7-960 @ 3.8 GHz - Corsair H70 - 6 GB Corsair DDR3 @ 1600 MHz - 64 GB Cucial M4 SSD - Dual WD Caviar Black 1TB SATA III HD's - HD 5870 + GTX 480 - Coolermaster 1250W PSU - ANTEC P280 - 4 x 240 V server fans - Griffin Powermate
dunx is offline   Reply With Quote
Old 14th Apr 2012, 22:12   #59
Blogins
Panda have Guns
Blogins's Avatar
Are you on air?
I don't want to push things to hard at the moment because I have no direct contact cooling on the VRM or memory. Once I clean up the card and get it fully kitted out with a water block and possibly a backplate then I'll consider the overclocking potential I can unleash. Also beware as I'm an old hand editing Fermi BIOS since unlocking the voltage on my GTX 460 cards!
__________________
Old 14th Apr 2012, 23:50   #60
meandmymouth
I *am* a Dremel
meandmymouth's Avatar
meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!meandmymouth - it's over 9000!!!!!!!!1!1!1!!!
What a monster little PSU that is.
meandmymouth is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
