#1 |
May irritate Eyes
best OS for me
Hey everyone. Recently, due to lack of use, I decided I want to repurposed my desktop pc as a file server. I started experimenting with amachi but am starting to think it isn't the best or most simplest solution. Atm I currently have 3.35TB of disks in it and will be expanding this in the coming weeks or months depending on prices.
Currently at home I have an xp machine, my laptop, a netbook,my brothers laptop and a couple of phones that I would like to have a central location for storage and access. I would also like to be able to set up home email and calander and hopefully be able to sync with an android device (default calander sucks and doesn't play nice when adding dates with three calanders feeding into it. basically what is the best OS for the job? Ive been playing about with hamachi but with windows home server being so cheap wouldn't it be an easier and more equiped solution? any advice and explaining the advantages between each would be greatly appreciated. thanks for your help |
#2 |
How many wifi's does it have?
If you are a student, at a school that is registered at MSDNAA, then you have the full and latest Windows Server version waiting for you.
If not, you have Linux and as you mentioned Windows Home Server. I haven't touch either, but I would guess that if your are in a Windows environment at home, I would go with Windows Home Server, especially that it is so cheap (much cheaper than normal Windows too). What I like about Windows, is that you know it will be easy to use, and won't have to fiddle with command line and stuff. Here is an overview Windows Home Server:
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB Last edited by GoodBytes; 8th Apr 2012 at 14:44. |
#3 | |
May irritate Eyes
I complete forgot about the MSDNAA Guess that solves it. cheers goodbytes |
#4 | |
CHMOD bit-tech 777
Once your MSDNAA is expired then you will need to replace the key or install a new OS.
__________________
| AMD FX 8350 @ 4.0GHZ | Gigabyte GA-990FXA-UD5 | 16GB Corsair Vengeance DDR3 1600mhz |
| Corsair Force 3 120GB SSD X 2 RAID0| Corsair H100 | Samsung F3 1TB HDD | MSI GeForce GTX 680 SLI | | Silverstone 1200W | Corsair 650D | LG IPS225V X 2 | |
#5 |
System Support Specialist
They are for academic purposes, so using it in a home network to simulate a small business setup would be okay
![]() and they never expire :P
__________________
If someone has helped you remember to + Rep them (: |
#6 |
Ultramodder
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | 7950w/boost WC | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | Cheap LG IPS
#7 |
The license for Student of Windows and all software available is that you can use it for educational purposes or home. Not business. javaman has nothing to worry about, unless he lunches a web site which sales something, or run a business.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#8 |
May irritate Eyes
Check the website and they have server 2008 in many flavours and forms. Trying to decide is there any advantage or point to going to anything above standard apart from the fact I can.
As far as Im aware it is a permanent licence, tho I'm looking at T&C's just to confirm. If I want email I should also be looking to get exchange? |
#9 |
Hey What Who
license technically expires when your education has ended
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands |
#10 |
May irritate Eyes
I can't find anywhere that confirms or deny's this. I'll continue digging
#11 | |
PAM says no...
/rant But seriously, stop treating Linux like a tool for ultra-h4x0rs, it's not. It used to be, but now most common distributions actually move the user away from the terminal. In fact, Ubuntu is even limiting customization in the attempt to cater for the 'average' user. EDIT: Oh yes, and actually replying to the OP: I would just install Ubuntu, then install Samba, and share from that. See above in the rant for details
__________________
The Linux Schools Project |
#12 | |
May irritate Eyes
Found it after I clicked proceed to checkout
#13 |
Yea, I don't think the product key ACTUAL expires. I will be surprised if it does.
Just you won't get access to MSDNAA. Some software like Visual Studio (all editions), which cost 2-3x the price of Windows, don't even have a product key for the MSDNAA version.
__________________
#14 |
CHMOD bit-tech 777
I'd better start hording keys off my accounts then LOL
__________________
| Thread Tools | |
