Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 9th Apr 2012, 18:57   #1
wodgah
Supermodder
wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!wodgah - it's over 9000!!!!!!!!1!1!1!!!
HTPC using AMD Llano A6 A3500 as cpu
First time building a HTPC wanting to use it for XBMC.
Looked around and thought this might suit my needs.
It will be running thru an Onkyo SR606 and i want 1080p video with full DTS-HD sound.
I am looking at this so far.
AMD Llano A6 A3500 2.1GHz Socket FM1 3MB L2 Cache Retail Boxed Processor £55
Asrock A75M-HVS AMD A75 Socket FM1 5.1 Channel HD Audio mATX Motherboard £50
I need to find a small case with psu and i have some ram i can use in it.
What does anyone in the know think.
Thanks
wodgah is offline   Reply With Quote
Old 9th Apr 2012, 19:08   #2
modd1uk
Corsair Fan
modd1uk's Avatar
modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!
I was never really a fan of the AMD APU's until i tried one.
The price was excellent compare to the intels so i opted for one to update my HTPC/Media Server, it runs nice and cool and is perfect for the job imo. I went for a lesser model the A4 3400 and love it, excellent little cpu for the money.
I paired mine with a lovely asus mobo with sata 6 and usb 3 on it.
__________________
Corsair 800D :: ASUS P8P67-EVO :: i5 2500K :: 8GB Corsair Vengeance :: MSI Twin FrozrII GTX 570 :: Corsair HX520 :: Corsair H100 :: Samsung 830 256gb :: Samsung F3 :: Samsung F4
Originally Posted by loftie View Post
^+1
Energy saving light bulb agrees with the incandescent bulb.
modd1uk is offline   Reply With Quote
Old 9th Apr 2012, 19:27   #3
wodgah
Supermodder
How does the a4 do with full 1080p and DTS-HD ?
Also which board did you get ? id be interested to know prices as well, im looking to spend 175 ish total for the build.
Thanks for the reply
Old 9th Apr 2012, 19:47   #4
driftingphil
Modder
driftingphil has yet to learn the way of the Dremel
I Have Exactly the same kit and would also like to know.
I guess your going to using xmbc live, I would use dual boot so to use windows also for playing games in 720p (Xbox quality) using probably a8 3870k and do some overclocking.
driftingphil is offline   Reply With Quote
Old 14th Apr 2012, 11:10   #5
wodgah
Supermodder
Found a case i think may suit my needs its the Compucase 8K Mini ITX, i think it might be what im after and in my price range. It has 1 3.5" drive bay and i can easily use some velcro to fasten the ssd inside the case too. It comes with a 120w psu which im sure is enough for the 3500 llano but would love some feedback on what experienced HTPC builders think.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
