Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 10th Apr 2012, 15:54   #1
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
A Guide to Disable Core Parking, to gain performance in games!
What is Core Parking? - Core Parking is a power saving feature, which stops some of your cores running.
Have you ever wondered why only your physical cores only run in games, and the HT threads are Parked?...This is due to this power saving feature. This is a guide to how to unlock this feature.
Originally Posted by Max Silencio
Window 7 will deliberately park some of your cores which will decrease FPS substantially in CPU eating games like GTA IV.
In my GTX570SLI setting I had about 110 FPS ingame onscreen. After changing to GTX680 I was really disappointed as I had meager 60 to 70 FPS. Now that I changed registry settings after reboot I get instantly about 100 FPS ingame (depending on the scene).
Max Silencio CPU after disabling parked cores. GTA IV on his 3930K (Below)
How To Disable CPU Core Parking For Multi-Core Processors, editing the Registry.
0cc5b647-c1df-4637-891a-dec35c­318583 -Registry key from the Video, so you can copy and paste.
So if You don't like to mess with registry here's a simple tool:
Disable CPU Core Parking Utility.
Clicky
Once you have done 1 of the 2, you will now need to restart your computer for it to take effect!
Doing this on my Laptop, has given it a new lease of life, but does drain the battery more.
Enjoy!
Cheers,
Simon
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 10th Apr 2012, 16:09   #2
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
Will it work for both cores of my cpu?
feathers is offline   Reply With Quote
Old 10th Apr 2012, 16:14   #3
true_gamer
Cheesecake on sale!
true_gamer's Avatar
It's worth a shot on your CPU, but peeps with HT are gaining more FPS. As games don't really use the HT Threads from your CPU, until you un-parked them.
__________________
Old 10th Apr 2012, 16:48   #4
Landy_Ed
Combat Novice
Landy_Ed's Avatar
Landy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming SaiyanLandy_Ed is a Super Spamming Saiyan
worth a go I guess. Coincidentally decided to start playing through GTA4 last night, seem to be capped at 65fps (before vsync), if it makes a difference I'll post back!
Landy_Ed is offline   Reply With Quote
Old 10th Apr 2012, 16:50   #5
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Please do, with your RIG Specs, and your FPS gains, if any.
__________________
Old 10th Apr 2012, 19:48   #6
dnottis
What's a Dremel?
dnottis has yet to learn the way of the Dremel
I don't know why people keep blaming HT for this, Windows is parking the cores. I prefer to leave HT on, using software like convertxtoDVD u can setup the application to use 8 threads for encoding and it makes a huge difference.
Core parking is not a problem created by having a CPU with hyper threading, it's a Windows feature to save power and disable cores not in use.
dnottis is offline   Reply With Quote
Old 11th Apr 2012, 06:42   #7
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Where have I stated about turning HT off? Yes I know Windows parks unused threads, to save power. But until you unpark the threads, no game will utilise all the threads.
This is why people are getting more FPS in games with parking turned off, as the games are using the HT threads as well.
__________________
Old 11th Apr 2012, 07:23   #8
Mac_Trekkie
Source Engine's #1 fan!
Mac_Trekkie's Avatar
Mac_Trekkie has yet to learn the way of the DremelMac_Trekkie has yet to learn the way of the Dremel
So this only affects CPU's with hyperthreading, right? The Core 2 Duo in my laptop won't notice a difference? Well I'll slap the utility in my desktop and see if it makes a difference.
__________________
The Brass Balls: i7 870 @ 4.2ghz | Cooler: CM Hyper 212+ | 8gb G.Skill Ripjaws DDR3 1600 | GPU: ZOTAC GTX 560 Ti 448-core 1,280mb | Motherboard: MSI P55-GD65 | Case: ThermalTake Element G | ThermalTake 850w PSU | Samsung Spinpoint F3 1tb | Corsair Nova 32gb SSD
Mac_Trekkie is offline   Reply With Quote
Old 11th Apr 2012, 07:37   #9
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Have a look in Task manager, Click on CPU tab, and see if 1 of your cores is Parked (As pictured above).
__________________
Old 11th Apr 2012, 07:55   #10
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.
Anyone with a mains power meter? Can you measure the power draw difference in everyday/browsing mode with parking on and off? Just tried, but my meter is foobar... constantly reading 0watts... LOL. I wish.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ H105 ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ EVGA GTX980 Super-Clocked¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS9260-8i ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 11th Apr 2012, 08:18   #11
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Core 2 Duo won't. Conroe and Penryn cores were power gated to the package not the core. It would either send the whole die into a C3 state or both CPUs would be 'active'. If you had a C2Q with two dies you could get 2 cores parking on one of the dies.
Lynnfield was the first notebook part to be per-core power gated (Nehalem was on Desktop).
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 11th Apr 2012, 08:27   #12
true_gamer
Cheesecake on sale!
true_gamer's Avatar
I don't have one, so I can't help there...
Congrats on your 33k post
Thanks for the info.
So only people with a Q6600 and above will get parked cores?
__________________
Old 11th Apr 2012, 10:59   #13
Salty Wagyu
moo
Salty Wagyu's Avatar
Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!Salty Wagyu - it's over 9000!!!!!!!!1!1!1!!!
Never saw a parked core on my i5-750. Somewhat sceptical of this tweak, because if games and apps demand the power the CPU should be providing it anyway.
__________________
Main System & HTPC Specs
Salty Wagyu is offline   Reply With Quote
Old 11th Apr 2012, 11:02   #14
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
I've also never seen a parked core on my i5 750, but I disabled core parking just in case. For me it made no difference so I just re enabled it to save a bit of power.
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 11th Apr 2012, 11:16   #15
megadriveguy
Hypermodder
megadriveguy's Avatar
megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.megadriveguy is a hoopy frood who really knows where their towel is.
Tried this last night though I only ran heaven maxed out, not the best cpu test
My 2600k cores were parking at the desktop, I unparked them made no difference to fps
would probably only affect a few games gta must be one of them maybe someone could try Civ V total war
Cant see this making a big difference to power usage
megadriveguy is offline   Reply With Quote
Old 11th Apr 2012, 11:32   #16
JoeDorson
What's a Dremel?
JoeDorson has yet to learn the way of the Dremel
Interesting, will have to try this when I get home and runs some tests before and after to see if there is any gain.
JoeDorson is offline   Reply With Quote
Old 11th Apr 2012, 11:41   #17
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Windows would have to park both cores at once. Maybe. I don't know what C state 'parked' constitutes to so I can't say for sure.
__________________
Old 11th Apr 2012, 11:44   #18
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Why not try it on BF3? A lot of people are saying they are getting good gains from it.
I would, but I have no GPU's at the mo...No gaming for a couple of weeks
__________________
Old 11th Apr 2012, 11:45   #19
MrDomRocks
I Mod, Therefore I Own
MrDomRocks's Avatar
MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.
I will give this a go on my i5 2500K, see what happens.
MrDomRocks is offline   Reply With Quote
Old 11th Apr 2012, 11:45   #20
true_gamer
Cheesecake on sale!
true_gamer's Avatar
No worries. I'm sure someone will post there findings with those CPU's and above.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
