#1 |
Do you even mod, bro?
Quick Question on PCIe Lanes.
Quick Question on PCIe lanes
I have a Asus P8Z68 Deluxe. It has 2 x PCIe 2.0 x16 (x16 or dual x8) 1 x PCIe 2.0 x16 (x4 mode, black) *1 2 x PCIe 2.0 x1 If I put 2x GTX 480 in the PCIe x8 slots, am I ok putting an Asus Xonar DX in the last x4 slot, or will this impact the bandwidth of the two GPUs?
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#2 |
I've been away far too long
It shouldn't affect anything. It all adds up to be the same 20 PCI-E lanes no matter what config you use.
Edit: Elton's response makes more sense than this one lol
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU Last edited by noizdaemon666; 11th Apr 2012 at 10:58. |
#3 |
Proud Model M User
The last X4 slot would run in X4 mode. No biggie.
__________________
There's good ideas and then there's terribly great ideas. |
#4 |
Hypermodder
If my understanding of the Z68 chipset is correct, the "graphics" PCIe slots are controlled directly from the CPU. The third x16 (physical) slot uses the PCIe lanes from the PCH so using it will not have any impact on the graphics performance.
I am not certain how Asus have allocated the 8 PCIe lanes from the PCH. There is a possibility that the x16 black slot shares lanes with the x1 slots. |
#5 | |
Should be ok I guess.
__________________
| Thread Tools | |
