Reply
Thread Tools View Mode
Old 11th Apr 2012, 12:33   #1
Mindphaser
Modder
Mindphaser's Avatar
Mindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the Dremel
Combine Ceiling Turret
Hi everyone.
I am an entry-level modder from Ukraine.
This is my second modding project, the first one http://forum.coolermaster.com/viewto...p?f=49&t=14808.
I have no sponsors, so project budget is limited and hardware is not state-of-the-art.
Here is the hardware list
CASE: full custom
PSU: Flex-ATX Seasonic SS-250SU
MB: Gigabyte H55N-USB3
CPU: Intel i3-550
CPU cooler: Intel box (fan replaced)
MEM: Hynix DDR3 2x2G 1333MHz CL9
GPU: Asus HD7750 512Mb GDDR5
HDD: SATA 160Gb Samsung SpinPoint F1 8Mb
DVD: DVD-RW SATA Sony Nec Optiarc AD-7690H (slim slot-in).
Concept.
If you ever play Half Life 2, you have to remember Alliance turrets, including Combine Ceiling Turret:
So I’ve plane to make the case not in the style of the game but highest possible close to original source.
Also inspiration objects photos:
Layout
2D layout:
3D layout:
Here are the initial set of materials
So, the frame made from aluminum angle bars, side panels - glass-fibre plastic, and the rest during the process.
Getting started.
Install the CPU cooler – its height is not very pleased. Have to replace the fan by low-profile one.
To initiate the process make a power supply unit angular mounts:
Adjust the attachment holes and fan cut-out:
Time to handle a framework. The problem is that the case almost have no right angles, all surfaces are sloped - will have some fun.
Mindphaser is offline   Reply With Quote
Old 11th Apr 2012, 13:26   #2
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.jhanlon303 is the Cheesecake. Relix smiles down upon them.
Interesting.
I watch.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 11th Apr 2012, 17:54   #3
dirky90
Multimodder
dirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremel
haha, this is going to be so good!! amazing concept drawings!! and you cant beat half life!!
if you are struggling for space you could drop to a 2.5??
rob
dirky90 is offline   Reply With Quote
Old 11th Apr 2012, 17:57   #4
Mankz
________
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Very much liking the idea of this.
Mankz is offline   Reply With Quote
Old 11th Apr 2012, 19:34   #5
Mindphaser
Modder
Mindphaser's Avatar
rob
It's no sense to replace the 3'5" HDD to 2'5" one. In that place enough space in all dimensions. Anyway thanks for comment
Old 11th Apr 2012, 21:52   #6
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Interesting your other project looked crazy, good crazy.
Waynio is offline   Reply With Quote
Old 12th Apr 2012, 07:42   #7
Mindphaser
Modder
Mindphaser's Avatar
Yeah, really?
I think that every techno geek should have a cyber monster like this
Old 12th Apr 2012, 11:01   #8
Mindphaser
Modder
Mindphaser's Avatar
Let's continue.
The pair of rear frame’s profiles:
Manual bending:
Angle revision:
Forming the rear side of the frame:
HDD mountings treatment:
Mid frame profiles cutting:
Trying on the motherboard:
Rear panel cutouts:
Have to make cutouts for memory modules too:
Frame assembly.
Old 12th Apr 2012, 11:10   #9
dirky90
Multimodder
wow, it looks so good so far!! I cant wait to see how this turns out. keep up the good work!!
Old 12th Apr 2012, 20:48   #10
Samrobmoe
Minimodder
Samrobmoe's Avatar
Samrobmoe has yet to learn the way of the Dremel
This is looking truly EPIC, I literally cannot wait to see this finished in all it's combine-y glory
Samrobmoe is offline   Reply With Quote
Old 13th Apr 2012, 10:58   #11
Mindphaser
Modder
Mindphaser's Avatar
dirky90, Samrobmoe Thanks guys, you will not be disappointed
Old 14th Apr 2012, 00:08   #12
Waynio
Waynio's Avatar
This is shaping up absolutely awesome mate, sweet bar work.
Old 14th Apr 2012, 01:50   #13
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpit
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is online now   Reply With Quote
Old 14th Apr 2012, 07:52   #14
Mindphaser
Modder
Mindphaser's Avatar
The frame is almost ready, can place the hardware.
Installing PSU:
PSU cable assembly:
Here is the secret ingredient - furniture hinge.
“What for?” you can ask.
The fact that the lid will be a separate structure that is rotated forward relative to the frame.
Lid close position:
Lid open position:
So, a furniture hinge serves as a pivot joint.
A video card housing will slide back through the guide:
The conclusion on the results of fitting the power supply - there is a problem with wires.
In the sense of wires packing in a tight inner place.
P.S.: I almost forgot to say - no machinery tools used, except screwdriver. All works done by hand tools.
Old 16th Apr 2012, 01:25   #15
Waynio
Waynio's Avatar
A whole lot can be done with hacksaw & files & some random bits from a DIY shop very nice work mate.
I would only get a manual drill if I wanted to do a blackout mod though, a mod without the aid of electricity, nice bragging rights come with that I think.
Edit: powerdrill still nice though & repped earlier.
Last edited by Waynio; 16th Apr 2012 at 03:06. Reason: Edit: powerdrill :hehe: still nice though. :)
Old 16th Apr 2012, 01:37   #16
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.
Anyone else getting dead pics?
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 16th Apr 2012, 01:42   #17
Waynio
Waynio's Avatar
Don't know but I can see them.
Old 16th Apr 2012, 02:54   #18
jhanlon303
jhanlon303's Avatar
Pics work for me
john
__________________
Old 16th Apr 2012, 13:15   #19
Mindphaser
Modder
Mindphaser's Avatar
The next assembly. Now the PSU fixed.
Graphics card and cooling system added for the sake of completeness:
Old 16th Apr 2012, 14:42   #20
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
lol!
cabinet hinges, aluminum, computer and modding!
LOVE IT!
kinghong1970 is offline   Reply With Quote
Reply
Tags
glass-fibre plastic, half life 2, mini-itx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
