Reply
Thread Tools View Mode
Old 21st Apr 2012, 11:21   #41
BnZn
What's a Dremel?
BnZn has yet to learn the way of the Dremel
Absolutely speechless. I love that concept that you're working from, this is going to be one mean case!
BnZn is offline   Reply With Quote
Old 22nd Apr 2012, 03:24   #42
bluc
Supermodder
bluc has yet to learn the way of the Dremel
You should have this on a swivel mount hanging from the ceiling with a stepper motor and laser sensor setup to track peoples movements as the walk through the room would be seriously un nerving to have that track you as you move through the area.
bluc is offline   Reply With Quote
Old 22nd Apr 2012, 04:42   #43
Gaming_freak_10
Hypermodder
Gaming_freak_10's Avatar
Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.Gaming_freak_10 is a hoopy frood who really knows where their towel is.
^ THIS! That'll be funny!
__________________
Steam: Gaming_Freak_10. Xbox 360: BlueEyeDragoh. PS3: enickel2009 (PS3's dead Until I manage to fix the problem)
Gaming_freak_10 is offline   Reply With Quote
Old 22nd Apr 2012, 08:04   #44
Mindphaser
Modder
Mindphaser's Avatar
Mindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the Dremel
Unfortunally i have no enough skills to make this. You're right, it would be funny, especially to make turret speak like in Portal 2
Mindphaser is offline   Reply With Quote
Old 22nd Apr 2012, 08:16   #45
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: video card housing guide - update 22/04/12
As I wrote early, video card housing will slide back through the guide.
Telescoping rail guide (from furniture set) need to be shortened at first:
Both original and shortened guide:
Close position:
Open position:
Fixing at mounting angles:
Old 23rd Apr 2012, 09:34   #46
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: visual sensor holder - update 23/04/12
Original turret from game has a visual sensor system to detect intruders in its sight line:
Realization of that system will be later, but now making its holder.
Old 25th Apr 2012, 08:43   #47
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Brilliant stuff I'm enjoying this.
Waynio is offline   Reply With Quote
Old 25th Apr 2012, 12:10   #48
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: lid side parts - update 25/04/12
Swivel lid will make from fiber-glass plastic.
Marking:
Ventilation holes contours marked trough laser printer paper copy and electric iron:
However forgot to mirror the image
Predrill:
A hacksaw and needle files working result:
Old 25th Apr 2012, 18:07   #49
dirky90
Multimodder
dirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremeldirky90 has yet to learn the way of the Dremel
lovely work, keep it up.
dirky90 is offline   Reply With Quote
Old 27th Apr 2012, 09:22   #50
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: lid frame assembly - update 27/04/12
Fitting the lid sidewall:
PSU and hinge determine case minimal width:
Lid frame in progress:
Case frame and lid together (not fixed yet):
Old 27th Apr 2012, 19:34   #51
Waynio
Waynio's Avatar
Nice progress Mindphaser, neat trick with the iron too, I'll have to try that out some time. +rep
Old 28th Apr 2012, 11:29   #52
Mindphaser
Modder
Mindphaser's Avatar
Thank you. It's very nice to be able to offer something new to such masters as you are. The trick with laser printer copy and an iron can still apply for drawing the tracks on the circuit board for etching (for example). The main thing - not to spare toner and well warmed up. Good luck.
Old 1st May 2012, 10:43   #53
bluc
Supermodder
Awesome stuff looking great . My panels are being cut at moment hope to have project log up end next week.
Old 1st May 2012, 11:24   #54
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: video card housing - update 01/05/12
It's time to start making a video card housing.
3D model its good, but need to check the actual layout and dimensions.
Natural size mockup from cardboard:
It’s not a advertising, just do not know how to use graphics editors
Place a video card inside:
Cut from fiberglass side parts of the housing.
Aluminum darby will determine the angle between the sidewall parts during assembly:
Old 1st May 2012, 11:52   #55
bluc
Supermodder
I was a fibreglasser for quite a few years good to see it used in mods. For such a versatile material it seems to be seldom used.
Old 1st May 2012, 17:07   #56
Big SturL
Multimodder
Big SturL's Avatar
Big SturL has yet to learn the way of the Dremel
Subd'!
__________________
Wish I had some imagination...
SN25P - 3500+ - 1GB - 7600GS - 250GB
Big SturL is offline   Reply With Quote
Old 4th May 2012, 12:31   #57
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: video card housing - update 04/05/12
Side parts assembly via pull-out rivets:
Aluminum softer then fiberglass so its easy to flush rivet heads:
Old 4th May 2012, 16:32   #58
sixfootsideburns
modeteer
sixfootsideburns has yet to learn the way of the Dremelsixfootsideburns has yet to learn the way of the Dremel
looking awesome man, the progress just gets better and better!
sixfootsideburns is offline   Reply With Quote
Old 4th May 2012, 16:57   #59
Waynio
Waynio's Avatar
^Agreed
Old 5th May 2012, 01:08   #60
dirky90
Multimodder
so clean, so original and looks like its should be a great replica. keep up the good work!!!
Reply
Tags
glass-fibre plastic, half life 2, mini-itx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
