#61 |
Modder
Combine Ceiling Turret: video card output box - update 10/05/12
Switch over to to a video cart output box, this part:
![]() The front of the box rounded shape, for it has used aluminum furniture leg diameter of 40mm: ![]() Dismantled, prepared for cutting: ![]() By the way, how to mark a longitudinal line of cut (in a sense parallel to each other and the axis of the cylinder)? Found the way - put angle: ![]() A little hacksaw work: ![]() That’s all for a while. |
#62 |
Supermodder
Coming together nicely!
#63 |
Modder
Combine Ceiling Turret: DVD-box - update 15/05/12
#64 |
sabertooth 990FX
interesteing
slimpel but Advanced
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing |
#65 |
Supermodder
Coming together very nicely
#66 |
I like wood ಠ_ಠ
OOOOOOOOOHHHHHHHHH YYYYYYYYEEEEEEEAAAAAAAA
Great looking mod, keep up the great work
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#67 |
Multimodder
Great build mate. nice skills
__________________
Urban Camouflage
#68 |
Keep calm & mod on. =)
Nice progress.
#69 |
Hypermodder
Still looking sweet! Nice progress
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC |
#70 |
Modder
fr0Zen, bluc, The_Beast, Overminde, Waynio, Mosquito
Thanks for the comments... There is no time for work for a while, log to be continued through a few weeks |
#71 |
Modder
Combine Ceiling Turret: CPU cooler mod - update 22/09/12
For some reasons have to replace CPU cooler by the low-profile Cooler Master Gemini II M4:
![]() Despite the fact that is the lowest Cooler Master cooler, I have to modify it. First, remove the fan, and then gave it a trapezoidal shape: ![]() In rotate position heat pipes run into the capacitors and the cooler base not in contact to processor ![]() ![]() Need to raise the cooler on the heat sink: ![]() ![]() Tinkering heat sink and heat pipes, a second attempt ![]() ![]() To warm up the heat pipes cooler is placed in a container with boiling water on the gas stove ![]() Heat sink roasting ![]() Cooler assembled ![]() Modified CM Gemini II M4 tests on OCCT v.3.1.0: With stock fan - better then original! ![]() Passive –fail (even without load): ![]() With Titan TTC SC-04 blower ![]() That’s my choice:
#72 |
Supermodder
Awesome to see you back have been hoping the project did not die
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
#73 |
Modder
Combine Ceiling Turret: blower mod - update 16/10/12
#74 |
Fenrir The Wolf
Great work. I can't wait to see it on the ceiling.
![]() 5 star for you.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#75 |
Nice work on the cooler Mindphaser.
#76 |
↓ Don't trust that face!
__________________
#77 |
^ Trying to fix my direct heat pipe cooler did end up badly for me.
#78 |
Modder
Combine Ceiling Turret: roof grating - update 18/10/12
#79 |
Modder
Combine Ceiling Turret: video card housing - update 30/10/12
#80 |
Supermodder
Only just seen this build, great work, it's my kind of build using anything and everything you can get your hands on and just making it work
+rep
__________________
Al-13 Duplicity, Dual Mobo Scratch build |
| Tags |
| glass-fibre plastic, half life 2, mini-itx |
| Thread Tools | |
| View Mode | |
