Reply
Thread Tools View Mode
Old 2nd Nov 2012, 08:25   #81
Mindphaser
Modder
Mindphaser's Avatar
Mindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the DremelMindphaser has yet to learn the way of the Dremel
Combine Ceiling Turret: video card housing - update 02/11/12
Lets make front part of video card housing:
Use an aluminum box-shaped profile:
One of these turbines will be installed inside:
So I have to give it a breath of fresh air, mark the holes:
Drilling holes
Ream a holes
Mindphaser is offline   Reply With Quote
Old 12th Nov 2012, 10:32   #82
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: video card housing - update 12/11/12
Still making front part of video card housing:
Use an aluminum darby:
Hand made perforation:
Top parts:
Adhesive tape assembly:
Front part:
After a while:
Cut away the needless edges and sanding:
Final assembly:
Old 12th Nov 2012, 10:39   #83
timerhan
Modder
timerhan's Avatar
timerhan has yet to learn the way of the Dremel
Aluminum structures look very impressive))))
Polish it be?
timerhan is offline   Reply With Quote
Old 12th Nov 2012, 19:58   #84
Mindphaser
Modder
Mindphaser's Avatar
Polish it be?
Thanks
Not polishing - just painting.
Old 14th Nov 2012, 01:14   #85
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Nice progress
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
bluc is online now   Reply With Quote
Old 14th Nov 2012, 21:19   #86
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Holy moly, awesome progress Mindphaser, you clearly don't shy away from a difficult form to make.
Waynio is offline   Reply With Quote
Old 15th Nov 2012, 03:04   #87
KithKhan
A dremel is all you need.
KithKhan's Avatar
KithKhan has yet to learn the way of the Dremel
Sweet concept! Very cool.
KithKhan is offline   Reply With Quote
Old 15th Nov 2012, 08:11   #88
Mindphaser
Modder
Mindphaser's Avatar
bluc, Waynio, KithKhan Thanks for the nice reference
Old 20th Nov 2012, 08:35   #89
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: video card housing - update 20/11/12
Back to the “coffin”:
Finally, after many hours of adjusting parts, video card housing installed on the guide mechanism and tested in action:
Now assembled frame with cover just hard to hold in hands and there is no normal position for its storage, have to immediately make a table mount:
Old 20th Nov 2012, 08:47   #90
Overminde
69 Dude!!
Overminde's Avatar
Overminde has yet to learn the way of the Dremel
Its looking great. keep up the good job.
__________________
Urban Camouflage
Overminde is offline   Reply With Quote
Old 28th Nov 2012, 08:21   #91
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: table mount - update 28/11/12
To keep at least some element of intrigue, I will not specify which item from the world of Half Life 2 was the inspiration object
Basic set of material
… and a baby carriage ?!
Not all of course, only covers from the wheels
Cutting, sawing, drilling
Meanwhile another staff - find a paint for outside surfaces
Old 2nd Dec 2012, 06:02   #92
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: table mount - update 02/12/12
Let's continue table mount making process…
Since intrigue failed - just a screenshot
I don’t really know what is it. Something links to the security screens in the Combine armory.
Billets for "legs" from the aluminum angle
Front support for legs
Cool stuff
Frame complete
Old 2nd Dec 2012, 11:28   #93
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
Wow.
I've never played half life, so have no idea what that is, but it looks cool. Nice work.
KrunchR is online now   Reply With Quote
Old 3rd Dec 2012, 04:31   #94
bluc
Supermodder
Originally Posted by KrunchR View Post
Wow.
Machine gun turrent
Sent from my Nexus 7 using Tapatalk 2
__________________
Old 3rd Dec 2012, 13:28   #95
Skill3d
Multimodder
Skill3d has yet to learn the way of the Dremel
Could it be the power source (battery) for the turret?
Skill3d is offline   Reply With Quote
Old 4th Dec 2012, 21:28   #96
Mindphaser
Modder
Mindphaser's Avatar
It's really great idea to build UPS into the table mount.
Here a lot free space inside and UPS weight could make construction more stable
Thank you so much for your idea
Old 4th Dec 2012, 21:43   #97
Waynio
Waynio's Avatar
This has been impressing me from the beginning.
It's been a while since I played half life so I didn't know what it was on the guess game but I always love seeing grab anything that works type modding like using a pram wheel for instance.
Old 8th Dec 2012, 21:53   #98
Mindphaser
Modder
Mindphaser's Avatar
Heartily thank you for your genuine interest to my work
Old 8th Dec 2012, 21:57   #99
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: DVD-box finish - update 09/12/12
The DVD-box assembly process.
Test assembly:
Now I work in a bathroom too
Prepare to sort components:
My inspiration:
Closer view:
Old 10th Jan 2013, 08:48   #100
Mindphaser
Modder
Mindphaser's Avatar
Combine Ceiling Turret: back to table mount - update 10/01/13
New year – same mod )))
Continue to make a table mount.
Fiberglass sidewalls:
Mains connectors:
An aluminum decorative details:
The nose part of the spray cartridge. There is the power switch with will be mount inside. Mold - zinc alloy shelf holder:
Modified spray itself:
Swivel mount holder for turret - furniture castor:
All assembled
Reply
Tags
glass-fibre plastic, half life 2, mini-itx
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
