#1 |
Hypermodder
Free 3-D Moddeling software
Sup dudes, I need a program that I can make 3-D models in an send to a CNC shop to get them machined out. Heres a list of supported filetypes that Protolabs use, so I need to be able to save in the following as they don't accpet .skp (Google SketchUp).
IGES (.igs) STEP (.stp) SolidWorks (.sldprt) ProE (.prt) Parasolid (.x_t and .x_b) ACIS (.sat) AutoCAD (.dwg, 3D only) Autodesk Inventor (.ipt) Thanks peeps, hopefully there is something out there for me.
__________________
Pexon PCs Pexon @ GH Steel Series 6G v2 w/ MX Black / Noppoo Choc Mini w/ MX Blues / Happy Hacking Keyboard Pro 2 Anthracite |
#3 |
Hypermodder
It doesn't support any of the file types they use dude. Thanks though.
__________________
#4 |
Modder
Can sketch-up export to IGES or STEP format, these are universal non-CAD specific formats?
If this is a one off, then Autodesk offer a 30 day trial for Inventor, so maybe give that a go? Let me know if you need any Inventor help. |
#5 |
Hypermodder
Downloading the 30 day trial now, thanks man!
__________________
#6 |
Supermodder
There is an extension to Sketchup that converts to stl. They should accept that?
__________________
WoT's: Xye_Sol Playing: Panther II, SU-8, PzIV, M2, M4A3E8, M36, Tetrarch, T43, T20, T50, JgdPnth, AMX13 75, ARL44
Mech_Antec: Xeon 3450@3.809GHz | Asus P7P55D-Evo (1808 BIOS)|Asus 6950|Corsair C300 128Gb|RAID 0 WD Cav. HTPC in Progress: E35M1-I DELUXE|Intel 320 Series 40Gb|2Tb Seagate Barracuda|The Dragon Reborn (Case) CNC Controller: E8500@3.3GHz (unable to push further)| Asus P5N-D|8800GTS|Barracuda 250Gb| Condensation (Case) |
#7 |
Hypermodder
Where can I find that mate?
__________________
#8 |
I don't know what I'm doing
There's a version of pro-e that works well, but pro-e itself is a bitch to use.
edit: Removed references to piracy. Please refrain from discussion of warez in future. - spec
__________________
i7 2600 | ASRock Z77E-ITX | Asus Radeon HD5670 | 8GB Corsair Vengeance 1600MHz | Samsung F4 2TB | 120GB Corsair Force 3 | Last edited by specofdust; 21st Apr 2012 at 15:18. Reason: Discussion of warez |
#9 |
aka "Panda"
I use inventor on my desktop (Student edition is free if you have a valid .edu address).
I use 123D on my laptop. Both can export in the format you need.
__________________
My web server is gone, if you find RED x's PM me with a link to the post and I will upload the photo to my bit-tech album and repair the link. |
#10 |
Cuppa tea anyone?
Still in Beta but worth a try.
http://sourceforge.net/projects/free-cad/
__________________
WoT Profile E8400@4.0GHz~T Power I45~MSI N560GTX Ti~OCZ Reaper PC2-8500 1066Mhz 4GB~Vertex 2E 90Gb~F3 1TB~Corsair HX650~Xonar DX~Titan Fenrir |
#11 | |
Hypermodder
__________________
#12 |
Supermodder
If you (or a nice friend) have a .ac.uk email address then you can download pretty much an Autodesk software for free.
__________________
Steam/GFWL/BFBC2/BF3/Autolog: bluespider42 i7 920 - HR-02, X58A-UD3R, GTX580, 6GB XMS3, Seasonic X750, 128GB Crucial 300, 240GB Vertex 2, Silverstone FT-02, U2711 + P1911 |
#13 |
Veni Vidi Vado
Try Autodesk 123D. It's a free software meant to create models that are to be produced in the end, which is exactly your purpose.
It's pretty easy to use, can export some of the fily types you need and will and will wield far better results than Sketchup.
__________________
Feel free to correct this post per PN or otherwise to help me improve my English. |
| Thread Tools | |
