Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 13th Apr 2012, 17:27   #1
TobletDanillio
Supermodder
TobletDanillio has yet to learn the way of the Dremel
WC part list
*PLEASE DELETE THREAD*
__________________
Xigmatek ELYSIUM | I7 2600K | Be Quite Dark Rock Pro | Asus P8P67 Pro | G-Skill RipjawsX 8GB 1600 MHz | MSI 560GTX-Ti Twin Frozr II 2GD5/OC | Samsung F3 1Tb | Samsung 830 256GB
TobletDanillio is offline   Reply With Quote
Old 13th Apr 2012, 18:09   #2
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.
Why have you started a new thread, when you already have one going?
http://forums.bit-tech.net/showthread.php?t=228896
__________________
i7 3930K @ 4.7GHz - ASUS Rampage IV Extreme - 16GB Corsair 2400MHz 10 12 12 31 - 3x EVGA GTX 670 F.T.W 4GB Tri SLI with AquagraFX waterblocks Cores: 1306MHz Memory's: 7114MHz - 128GB OCZ Vector SSD - PNY Prevail 120GB SSD - 2TB WD Black Caviar - Silverstone TJ07 - Silverstone Strider 1KW - Samsung DVD/RW - Custom Waterloop - U2713HM 2560x1440 @ 90Hz Overclocked
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
My Crysis 3 Ultra Config My Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 13th Apr 2012, 20:25   #3
TobletDanillio
Supermodder
i was hopping for more peoples opinions :'( but doesn't have seemed to work
Edit: I also have updated the thread too.
__________________
Old 13th Apr 2012, 20:29   #4
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
Pointless thread alert!
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
