Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 14th Apr 2012, 09:33   #1
Ficu
What's a Dremel?
Ficu's Avatar
Ficu has yet to learn the way of the Dremel
[Build-LoG] Ice Blue
Thank you very much to all members and sponsors who have and are helping in this project.
-Hardware:
Motherboard: Gigabyte Z68X-UD7
Processor: 2500k
RAM: Corsair Vengance LP
GPU: Evga GTX480
PSU: Antec HCP-850
SSD: OCZ Agility 3 60GB
Case: NZXT Switch 810 White
-Liquid-cooled:
Block CPU: Ek Supreme HF Plex-Nickel + Mounting Plate Nickel
Block GPU: Aquacomputer GTX480 Nickel.
Block Motherboard: Ek Nickel - Plex UD7
Back plate: personalized By Cold-Zero / Aquacomputer Single Slot
Radiator 1: Ek XTX 360
Radiator 2: Ek XTX 240
Radiator 3: Ek XT 120
Radiator ventilation: x6 DeepCool UF120
Case ventilation: Gelid 140mm
Pump 1: Laing DDC 1T Plus 18W
Pump 2: Laing DDC 1T Plus 18W
Reservoir 1: Ek Res X2 250mm Advanced
Top: Ek DDC Dual Top Aquacomputer
Fitting: Alphacool HF Nickel 16/10mm
Angled Fittings: Angled 45º, 90º Alphacool Nickel
Adapters: Alphacool HF G1/4 @ G1/4 Nickel
Extenders: Phobya G1/4 rotary Nickel
Plugs: Phobya Nickel
O-Ring: Phobya Blue UV
Grills: personalized By Cold-Zero
Tube: Masterkleer 16/10mm
Liquid: Mahyems Blue Berry
-Other:
Display: Phobya Thermosensor Azul
Adapter Display: XSPC 5.25" Temperature Sensor Frame
Sata Cable: x2 Mod/Smart White 60cm
Sleeve Kit Mod/Smart Basic White
Silent Blocks: Noise Blocker Blue
Thermal paste: Artic MX-4
Cables: Full Sleeve White / Blue
Adapter: Phobya 3 pin @ x6 3pin White.
Extension: Molex 4 pin Mod/Smart 40cm White.
-Photo of the week
-Current
Ficu is offline   Reply With Quote
Old 19th Apr 2012, 21:28   #3
Shazbom
Multimodder
Shazbom's Avatar
Shazbom has yet to learn the way of the Dremel
Nice sleeved extension. modpcuk from ebay right?
__________________
Current Work Log: Shazbom Waterworld 2 (15-07-20011)
http://forums.bit-tech.net/showthread.php?t=213165
Past Work Log:Shazbom Waterworld (23-01-2009)
http://forums.bit-tech.net/showthread.php?t=163363
Shazbom is offline   Reply With Quote
Old 19th Apr 2012, 22:12   #4
ASPHIAX
Hypermodder
ASPHIAX's Avatar
ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!ASPHIAX - it's over 9000!!!!!!!!1!1!1!!!
Nice start man !
Good photography too !
Subbed !
__________________
Sander van der Velden
ModWithMe Concept Founder
E. Sander@ModWithMe.com
FB. https://www.facebook.com/ModWithMe
ASPHIAX is offline   Reply With Quote
Old 20th Apr 2012, 08:41   #5
Ficu
What's a Dremel?
Ficu's Avatar
Yes
Originally Posted by ASPHIAX View Post
Nice start man !
Subbed !
Thanx!
Well, here the expected photos!
First of all, Many thanks to Frank for having gotten this Canarinfo I5 3570K CPU as part of sponsorship in this project.
I have to give thanks to Noah greatly Gigabyte Spain for having engaged in this way in our project, THANK YOU!
A photo of the "marriage"
And the bag from Gigabyte .. That cool .. no?
Saludos!
Old 20th Apr 2012, 08:44   #6
ASPHIAX
Hypermodder
ASPHIAX's Avatar
Nice package ! Congratz !
__________________
Old 20th Apr 2012, 08:58   #7
rak500
Multimodder
rak500's Avatar
rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.rak500 is a hoopy frood who really knows where their towel is.
Promisiing start! Can't wait to see it all built up!
rak500 is offline   Reply With Quote
Old 20th Apr 2012, 10:47   #8
Vetalar
*learning english*
Vetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming Saiyan
well when someone asks me 'bout geek pr0n i'll give him link to this thread... MOAR PIX!!!
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 20th Apr 2012, 22:12   #9
Ficu
What's a Dremel?
Ficu's Avatar
Thanx
Old 21st Apr 2012, 07:44   #10
Reconnec7ed
Minimodder
Reconnec7ed has yet to learn the way of the Dremel
Very nice project!
But are you sure your supposed to be posting about the 3570K? Could get your man in some trouble?
Reconnec7ed is offline   Reply With Quote
Old 30th Apr 2012, 21:15   #11
Ficu
What's a Dremel?
Ficu's Avatar
Y........ WC Pr0n!! Gracias a:
EK Supreme HF Plexi-Nickel + Mounting Plate Nickel..
EK Supreme HF Plexi-Nickel + Mounting Plate Nickel + Alphacool HF 16/13...
EK Supreme HF Plexi-Nickel + Mounting Plate Nickel + Alphacool HF 16/13 + Blue Berry..... Oufff!
O-ring Phobya.
I like Nickel?
Display Phobya ( x2 ) and XSPC adapter
Top doble DDC Aquacomputer
Silent-blocks Noise Bloker Blue y unos Leds Blancos de 3mm para el HF
Gelid 140mm
Phobya Flexi-Light 240cm White
Saludos!
Old 6th May 2012, 14:14   #12
Ficu
What's a Dremel?
Ficu's Avatar
Here we are back to show Coldzero material created by this project. Thank you Richard!
Bonus pic´s: Alphacool HF 16/13 + 0-ring Phobya Blue!
Un saludo.
Old 7th May 2012, 16:08   #13
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Project Log rule no. 2...
Moved to Modding.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 7th May 2012, 17:07   #14
echo three
Multimodder
echo three has yet to learn the way of the Dremel
There's some shiney parts there,
echo three is offline   Reply With Quote
Old 4th Jun 2012, 07:45   #15
Ficu
What's a Dremel?
Ficu's Avatar
Moved to Modding.
Thanx..
HF Mounting plate Nickel + M4 Inox
Old 20th Jun 2012, 09:59   #16
Ficu
What's a Dremel?
Ficu's Avatar
Of Canarinfo:
Radiator Ek XT120, EK FB Kit P67/Z68-UD7 y x2 Laing DDC 1T Plus
Of Antec:
Thanx Josep of Antec España!
Review:
Review: Antec High Current PRO 850
Of Corsair:
Thanx Gareth!
Old 20th Jun 2012, 12:41   #17
Vetalar
*learning english*
how are those deepcool fans? i've read some negative feedback for PWM version...
__________________
20 have a sleep
30 goto 10
Old 3rd Jul 2012, 13:23   #18
Ficu
What's a Dremel?
Ficu's Avatar
They are the best in performance the truth, but are very nice..
Well, the radiators are painted ... I have put various configurations of fans to compare, to see what do you think ...
DeepCool UF120
Corsair SP120 White ring
Corsair SP120 Blue ring
Ek XT120 + Corsair SP120 + Alphacool HF 16/10
Ek XTX 240 Instalado
Ek XTX Installed
XTX360 + Grill ColdZero
Thanx.
Old 8th Jul 2012, 13:58   #19
Ficu
What's a Dremel?
Ficu's Avatar
80% finish the issue of lighting!
Thanx!
Old 8th Jul 2012, 16:21   #20
Vetalar
*learning english*
man You've got wrong EK logo - no circles over... everywhere
__________________
20 have a sleep
30 goto 10
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
