Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 23rd Apr 2012, 10:05   #101
Blogins
Panda have Guns
Blogins's Avatar
Blogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpitBlogins is almost as Godly as yodasarmpit
My only aim is to destroy your GPU score LennyRhys!
Can I transfer my 3DMark license to a second PC? Only flaw in my plan at the moment! I have two fat 240 Radiators supported by dual Phobya Nano-2G and Delta FFB1212EHE 120mm fans. Your Gigaybte Special Edition 480 will be decimated! Although it is a lovely card
__________________
|Fractal Design Define R3, Black Pearl (Case)|ASUS P8P67 Deluxe (Motherboard)|Intel® Core™ i5-2500K (Processor)|
|G-Skill 8GB DDR3 1600mhz Sniper 1.25v (Memory)|ASUS GTX 670 / Gigabyte GTX 670 (SLI Graphics)|
|Corsair Professional Series Gold AX 850W (Power Supply Unit)|Asus Xonar D2X PCI-Express (Sound Card)|
|OCZ Vertex 3 120GB (Solid State Drive - Boot)|OCZ Vertex 3 240GB (Solid State Drive - Games)|
Blogins is offline   Reply With Quote
Old 23rd Apr 2012, 10:13   #102
LennyRhys
Silenced
LennyRhys's Avatar
LennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpit
Good luck
If you can get past 910MHz on the core I'll be very impressed
__________________
i7 930 @ 4.2 :: Gigabyte X58 USB3 :: 6GB Elpida @ 1528MHz 6-7-6-18-1T
GTX480 SE :: Toughpower 775w :: 320GB & 2TB :: Cherry G80-3000HSMGB
LennyRhys is offline   Reply With Quote
Old 23rd Apr 2012, 10:16   #103
Blogins
Panda have Guns
Blogins's Avatar
It's a champion when undervolted so I'm inclined to believe that gives me lots of headroom where overclocking is concerned. Have you tried undervolting your chip LennyRhys? My ASUS GTX 480 got down to 925mV and operated at stock clocks perfectly.
__________________
Old 23rd Apr 2012, 10:30   #104
LennyRhys
Silenced
LennyRhys's Avatar
I've not tried undervolting yet - I think I had it at 800MHz on stock volts (1000mV) and it was fine. The temperature is ridiculous at the moment though... idling at 55C because the thing is just caked in dust. I need to get the rocket blower and the hoover onto it!
Edit: I just remembered that using both monitors (30" and 20") pushes the idle temp up quite high. D'oh. It's 3760x1600
__________________
Old 23rd Apr 2012, 15:34   #105
Blogins
Panda have Guns
Blogins's Avatar
Installed a second 240 RAD in preparation for the Hydro Copper cooled ASUS GTX 480. At the moment it's cooling my E8500 and 680i Chipset very well with some more reasonable (quieter!) Phobya Nano-2G on the second RAD. Still can't beat the Deltas for that extreme edge though!
Sounds like your card needs some TLC LennyRhys. Give it a good dust off and some new TIM!
__________________
Old 23rd Apr 2012, 23:11   #106
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
Originally Posted by flame696 View Post
single card with the same settings i got:
Score: 724
FPS: 28.7
Min FPS: 13
Max FPS: 68.6
Score: 729
FPS: 28.9
Min FPS: 8
Max FPS: 70.2
those are some tough settings for the old girl!
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts.
The_Crapman is online now   Reply With Quote
Old 24th Apr 2012, 21:10   #107
Blogins
Panda have Guns
Blogins's Avatar
Just reassembled the Hydro Copper, fully cleaned and now decked out with Arctic Silver 5 on the VRM heatpipe (internal heatsink, not the VRM themselves!). Also used silicon grease around the edges of the waterblock and not on the seal itself. Little extra water proofing for piece of mind!
Used a little silicon grease on the water block screw threads and it makes them a damn sight easier to tighten! Hopefully get a leak test rocking this weekend and then I'll move onto the ASUS GTX 480 install! Loops all ready sitting and waiting for this GPU!
__________________
Old 28th Apr 2012, 16:10   #108
Teelzebub
Satan the one true God / Modarator
Teelzebub's Avatar
Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.
Finally got the TRI SLI set up again so what benchmark programs we using
At stock settings with 2x480's Heaven temps maxed @ 72c fans set at 58%
With 3x480's
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86
A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not
Teelzebub is offline   Reply With Quote
Old 28th Apr 2012, 17:15   #109
Madness_3d
Bit-Tech/Asus OC Winner
Madness_3d's Avatar
Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!
I'm gonna have to try and get involved in this overclocking soon :P from what I've seen so far my Asus looks to be the better clocker but to be honest neither of them look like they're great shakes in that department, I think they're both 1025mV stock voltage but we shall see, they both seem happy at 570 clocks 732/3900 core/ram but from what little testing I've done the EVGA bonked out at 800/3900 @ 1.1v
My cables have arrived but are stuck at the posties now until monday Ironically same day mine find their way here I get an email from corsair saying they're sending out spares on monday ^_^ Either way should be able to get some SLI going soon
__________________
XFXScorpio911 ¦ PHENOM II X4 965 @ 4.02Ghz ¦ SLI GTX 480 1536MB¦ ASUS CROSSHAIR II FORMULA ¦ 4GB OCZ REAPER 1066 5-5-4-8 2T¦ CORSAIR HYDRO H50 ¦ CORSAIR F60 ¦ WINDOWS 7 HP 64bit ¦ Musings On The Technical World ¦ Steam
Madness_3d is offline   Reply With Quote
Old 28th Apr 2012, 18:54   #110
Blogins
Panda have Guns
Blogins's Avatar
Leak test of the Hydro Copper failed, but not badly. My big hose managed to twist the barb loose, once it was properly tightened it is completely leak free! Has a real fast flow rate as well which bodes well for temperatures on the GTX 480. I'm going to dig out a small Delta fan that I previously used on the 680i Northbridge. I will be pumping some riskier volts through this card so the Delta will take care of VRM cooling with directed air flow.
__________________
Old 30th Apr 2012, 19:46   #111
Madness_3d
Madness_3d's Avatar
So yeah carrying on from my thread, Seeing interesting results so far,
Playing BF3 Maxed out at 1920x1200 with VSync on (I hate screen tearing) I am seeing lower temperatures and less noise with two cards than with one!
The reasoning being that the average GPU load on each card is only 65% according to GPUZ so less noise, lower temps and an absolutely silky smooth frame rate
Same story with Skyrim except even less load, even with Ultra, 8xAA and FXAA!
All in all by spreading the load over the two cards I've turned two hot running beasts into gentle creatures, until that is, you fire up something which takes both cards to 100%
Getting max temps of 93/88C on the two cards, under gaming mind (Metro 2033), I haven't dared try the likes of furmark on them :P Don't want to blow my PSU before I've even got started
__________________
Old 30th Apr 2012, 19:57   #112
LennyRhys
Silenced
LennyRhys's Avatar
Originally Posted by Blogins
My big hose
Try to keep the thread on topic pls Blogins
LOL
__________________
Old 30th Apr 2012, 20:04   #113
Blogins
Panda have Guns
Blogins's Avatar
It's hard to avoid innuendo when describing water cooling!
Also my GTX 480 is now underwater sitting at around 40 degrees in game. Time to beat your clocks LennyRhys!
__________________
Old 30th Apr 2012, 21:03   #114
LennyRhys
Silenced
LennyRhys's Avatar
Bring it
__________________
Old 30th Apr 2012, 21:41   #115
Blogins
Panda have Guns
Blogins's Avatar
What voltage does your GTX 480 offer 910MHz clocks LennyRhys?
__________________
Old 30th Apr 2012, 22:43   #116
Blogins
Panda have Guns
Blogins's Avatar
Just did a run at 920MHz on the core with 1100mV, this was stable throughout the 3DMark Vantage Benchmark. I lack a full license on this machine so no scores!
__________________
Old 30th Apr 2012, 23:59   #117
Blogins
Panda have Guns
Blogins's Avatar
Never thought I'd ever say this, but... deep breath, my GTX 480 overclock is PSU limited!
My little Enermax Liberty 400W PSU shut down at 600Watts! Left it for a minute and then I turned it back on with no problems whatsoever, just gotta love this PSU. This was at 1120mV on the GTX 480 with 930MHz on the core testing the metal with FurMark. I'll have to hook up my Enermax Galaxy 850W PSU externally to advance my testing!
__________________
Old 1st May 2012, 13:43   #118
The_Crapman
Attention watercooling officianados! I'm going to have a go at using an antec kuhler 620 to cool my 480. Full details can be found in the modding thread linked in my sig. Your help would be much appreciated
__________________
Old 1st May 2012, 14:13   #119
LennyRhys
Silenced
LennyRhys's Avatar
Can't remember off the top of my head but I think it was maxed out at 1.125v... however high the bios allows it to go via Afterburner basically.
I tried running it with higher clocks but it crashed, and it's definitely not PSU limited but very possibly heat limited!
__________________
Old 1st May 2012, 17:48   #120
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!Tattysnuc - it's over 9000!!!!!!!!1!1!1!!!
I only just found this thread! Typical - always late to the party.
I've got 2x480's in SLI (1 Zotac, 1xeVGA) both @ stock, but under water. Was on Sandy bridge, but sold up and went back to an RIIE S1366 board - because I love it.
Not sure if my cpu is 100% stable @ 4.2Ghz (i7 950) as my GPU folding clients crash after a while - that's some heat that these tykes kick out when they're going for it...
Tattysnuc is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
