#21 |
Multimodder
While waiting for the motherboard to come, so I can make the fourth part of the project, I decided to work on the cables that I’m going to need.
The first one I’m going to use is for powering the LED stripes. I needed to modify something, of course: ![]() The cable is meant for powering and regulating 3 fans but I cut out the regulating cable and modified it as a fourth power one: ![]() I had to apply some sanding the connectors: ![]() And then came the best part – sleeving: ![]() I had a SATA cable as well, so I sleeved it too: ![]() After finishing the cables, I took some pictures of the whole structure put together: ![]() ![]() Best Regards |
#22 |
Multimodder
I had some free time today, so I decided to make the cables connecting the motherboard to the turn on and restart buttons.
This is the result: ![]() ![]() And assembled: ![]() When I come to the final assembling, I will put heatshrink on the buttons and finish them. |
#23 |
Sir, your PC just bit me.
Looks awesome! What make is the dremel extender you have?
#24 |
Multimodder
Thanks mate.
I bought this dremel as a pack: the machine plus some other accessories. The extender was one of them. Best Regards |
#25 |
Modder
Nice work mate!
Tho don't you think the LED cables will be a bit long?
#26 |
Multimodder
Actually the connector that will be attached to the motherboard will be deeper between both plates and then the cables will be shorter.
#27 |
Multimodder
During the last few days I had some time to work on the project and this time I worked on the top most part (the fourth one) and I even had time to fix it to the rest.
![]() This time I decided not to bore you with detailed information because the process is the same, so I am just going to show you some key moments from the construction of the fourth part, which will cover the motherboard. ![]() Of course we have aluminum plates here too. ![]() Again, I needed some stainless steel tubes and bolts. ![]() And this is what all parts together look like. ![]() ![]() I am not sure if I like the top part. What do you think? Should I keep it like this or try to make it more aggresive? Best Regards |
#28 |
Multimodder
Today Cooler Master decided to sponsor me with the Cooler Master Excalibur R4-EXBB-20PK-R0 fan, which I intend to use for cooling the whole structure and the motherboard with all elements on it.
Thanks for the sample, Cooler Master.
#29 |
Minimodder
that's a lot of standoffs connecting the structure
#30 |
Multimodder
what is the fourth layer for?
#31 |
Multimodder
Yes, they are a lot, but all of them were custom made for less than 2 hours.
The fourth level will hold the Cooler Master Excalibur cooling the motherboard plus will have some visual effects that are not made yet. Some more new picture: ![]() ![]() ![]() ![]()
#32 |
Multimodder
After a few weeks’ wait, the motherboard kindly given to me by the Elitegroup colleagues finally arrived! I had planned to use the Elitegroup CDC-TI at the beginning but I assume it is not yet available, so Elitegroup sent me a CDC-I. The two boards have completely different structures; however I will accept this as a challenge and am going to use this one.
![]() The motherboard itself looks like this: ![]() The first model I had chosen was powered directly by an adaptor but this one uses power supply, so I decided to use PICO PSU This is the mod with mounted motherboard. Of course, this is just done for the test. ![]() ![]() ![]() I really want to thank all of the sponsors I have so far: ![]() ![]()
#33 |
Shut up and Mod
Interesting, very nice looking so far
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#34 |
www.^.nl
Love the lighting effect on the acrylic.
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#35 |
Multimodder
Thanks mate.
Believe me it will get even better... ![]() Yea the effect is great, but its really hard to make the light glows the same in every mm of the acrylic plates. |
#36 |
Multimodder
are you going to use a pci-extender for your vid card? (cause wouldnt the fourth layer block it otherwise?)
#37 |
Multimodder
Well this motherboard don't have PCIx at all. I will use the integrated video card.
#38 |
Shut up and Mod
^^^ I actually thought that was a given.
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen Last edited by Furball Zen; 23rd Jun 2012 at 14:11. |
#39 |
Multimodder
Today I got some free time and since I got a different motherboard sponsored by Elitegroup I had to think of and prepare a new way to power up the motherboard. For that reason I had to sleeve a 24 pin cable.
![]() I bought this as a regular 24 pin extender and modded it a bit by removing the 4 pin because I have 20pin pico PSU and the 4 pins will be useless. The process: ![]() The result: ![]() This is for now, more updates on the way. |
#40 |
Minimodder
awesome project!
Really like your idea about the acrylic! In my project I use black acrylic instead of aluminium and a clear illuminated acrylic too so I will follow your project very close. |
| Thread Tools | |
| View Mode | |
