Reply
Thread Tools View Mode
Old 29th Jun 2012, 05:05   #41
Dk_vr
Multimodder
Dk_vr's Avatar
Dk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the Dremel
Originally Posted by ying View Post
awesome project! and great work so far.
Really like your idea about the acrylic!
In my project I use black acrylic instead of aluminium and a clear illuminated acrylic too so I will follow your project very close.
Thanks for the good words.
In my project I had to use 5mm acrylic and if I had to use 2 x 5mm black acrylics it was going to be really big and that's not the idea. For that reason I went for 1mm aluminium plates, and since the leds strip is 8mm wide and the panels are just 7mm I had to integrate the lights inside.
Dk_vr is offline   Reply With Quote
Old 2nd Jul 2012, 18:56   #42
Dk_vr
Multimodder
Dk_vr's Avatar
This weekend I had a free day and the chance to go back to my hometown and use the workshop and I’ve decided to work on finishing the last part of the mod and install the motherboard and the cooling fan.
The workday started with disassembling the last part and install the 6 leds strip inside the acrylic. This time I had a machine to do the channel for the leds strip, the cable and the connector.
After 5 mins of cutting the part was ready and I started to do some measuring to install the fan. After more than hour and a half I had all holes drilled on both of the aluminium plates and later on the plexi part. First the holes were smaller but later I’ve decide to make them bigger so there are no bad noises.
And here is the moment when I found that the motherboard that Elitegroup sent me(made a mistake and sent me ECS CDC-I instead of CDC-TI) will give me some troubles. And unfortunately they popped up. After I installed the motherboard on the standoffs I saw that the pico PSU will stand just in front of the case. Except that there was no space to install the Cooler Master Excalibur fan which was sponsored by Cooler Master. For that reason I had to rebuild the mod and find a suitable position for the motherboard and for the fan. That took me some hours but I was able to see the result after I got back at home and the result was:
And all parts assembled:
After all was assembled I was so eager to find out how the lights will work:
After all parts were together I realised I have a working machine, yes still no hard drive but I could see it working. And this is the first movie of Project Black and White working
P.s. I am sorry but I don't know how to insert direct link to youtube video.
Last edited by Dk_vr; 4th Jul 2012 at 11:26. Reason: Now I know how to add youtube videos :)
Old 2nd Jul 2012, 19:09   #43
Fonne
Multimodder
Fonne has yet to learn the way of the Dremel
"Go Advanced" -> There you can see a Youtube buttom ...
Looks Great
Edit: And nothing happens :-S
Fonne is offline   Reply With Quote
Old 3rd Jul 2012, 10:21   #44
Mr3D
Modder
Mr3D has yet to learn the way of the DremelMr3D has yet to learn the way of the DremelMr3D has yet to learn the way of the Dremel
Great job man! I like how this is coming together. Tho the holes for the fan aren't those a little small/too few?
Mr3D is offline   Reply With Quote
Old 3rd Jul 2012, 14:13   #45
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
All you need is the video ID (XV7SHel2k5g for this one) between the YouTube tags.
I really like this project, it is really coming along nicely
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Last edited by Mosquito; 10th Jul 2012 at 15:18. Reason: removed my video post now that OP has it :-)
Mosquito is offline   Reply With Quote
Old 4th Jul 2012, 11:25   #46
Dk_vr
Multimodder
Dk_vr's Avatar
Looks Great
I had the same white screen too.
Thanks. Well the holes are just fine but I don't like how the circle of the holes on top fits, because it is ruinning the whole idea of the aggresive and with sharp edges looking project.
So I will probably try to modify this.
What you think, should I leave it like this or try to modify it.
Thanks for the info how to add youtube videos. I will definitely use it in future and thanks for the good words. I am really happy that you enjoy it.
P.s. Should I edit my old post?
Old 10th Jul 2012, 10:37   #47
Mr3D
Modder
I like the holes. Tho if you don't like them, change it. I dunno how tho.
I have a hard time with the fan holes too for my project.
Old 10th Jul 2012, 15:19   #48
Mosquito
Hypermodder
Mosquito's Avatar
Not a problem :-) I see that you have yours working, so I removed mine.
Can't wait to see more progress.
__________________
Mosquito
Old 10th Jul 2012, 20:00   #49
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
I think you should keep it simple like everything else.
There are too many holes for my taste and get all the attention!
I can't tell you what to do but a more "clean" approach?
Keep it up!
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 11th Jul 2012, 07:31   #50
Dk_vr
Multimodder
Dk_vr's Avatar
Yes I am thinking the same.
With these holes on top they become main element and that is not supposed to be like that.
Anyway I will probably try to rebuild the 4th part a bit modified and with other shape.
Thanks for the advice.
Old 7th Aug 2012, 23:07   #51
Waynio
Tetrep
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Subbed, voted, stars & rep
Nice looking project Dk_vr, light sandwich panels are awesome mate.
Waynio is offline   Reply With Quote
Old 13th Aug 2012, 11:13   #52
Dk_vr
Multimodder
Dk_vr's Avatar
No idea what those are but thanks. Today I will probably release a major update.
I didn't posted for a long time but I was on vacation last week and i am 99% done with the structure of the mod.
Stay tuned
Old 13th Aug 2012, 19:41   #53
Dk_vr
Multimodder
Dk_vr's Avatar
Long time has passed since the last update but in this update I will show to all of you some major changes including the top level totally rebuild.
Last week I spent my summer vacation in my home town and a few days at the workshop. There I’ve decided to totally rebuild the top level and finish some more things that I’d planned to do before.
Because the building process is absolutely the same I will skip the details and I will show directly the re-manufactured top part.
After I removed the old part and made this one I noticed that there is one spare hole on the third level and I’ve decided to make it bigger and install the Pico PSU connector for the power adapter.
All of that was done just the first day of my vacation. The next days, things got even more interesting.
After all parts were finally together I had to install the hdd/ssd bracket, arrange the cables and make the holes for the fan cooling the motherboard.
So, let’s get started:
First thing to do was to disassemble the whole build and install the hdd/ssd bracket.
Apart from that I still don’t have ssd and memory I got an ssd bracket used to attach a 2,5″ ssd to 3.5″ slot. To be able to attach it to the motherboard I had to drill some holes.
Mounted
Next thing to do was to install a 2,5″ HDD which I use just to make my plans and install the cables:
OK, I went to work on the mod but I forgot to pick up some mainboard screws so I had to improvise . My bad!
The cables are installed on the first part and later I will have to sleeve them too. Now it’s time to make holes on the second plate and attach the cables to the motherboard.
Some of the cables attached to the motherboard.
After that I had to assemble all of the parts together and the build looked like that:
This is for now, more updates on the way.
Old 16th Aug 2012, 12:39   #54
Mr3D
Modder
Looking great man! Tho you really need to do something about the ugly yellow color of the 24-pin on the pico!
Old 16th Aug 2012, 12:55   #55
[PUNK] crompers
Dremedial
[PUNK] crompers's Avatar
[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.[PUNK] crompers is a hoopy frood who really knows where their towel is.
nah, when its installed with the lid on you cant even see it!
loving the build btw
__________________
| Main Rig | TJ07B-W | 2600k @ 4.7Ghz | Sabertooth Z77 | 8GB Corsair Vengance | EVGA FTW 670 @ 1305Mhz | Samsung 830 128GB |1TB Samsung F3 | EK Supremacy CSQ | EK FC680 CSQ | Corsair HX650W | U2711 | Filco Majestouch 2 Tenkeyless | Xonar Essence STX | Beyerdynamic DT990 Pro 250ohm |
| HTPC | Lian Li Q11-B | AMD A10 5800k | ASRock FM2A75M-ITX | 8GB XMS3 2000 | 1TB Seagate | SFX 350W |
[PUNK] crompers is online now   Reply With Quote
Old 16th Aug 2012, 19:52   #56
Dk_vr
Multimodder
Dk_vr's Avatar
I will think about this but later.
Thanks for the good words. I am happy that you enjoy it.
Anyway:
It’s about time to post new pictures as I promised 3 days ago.
Next stage of the worklog is to make channels inside the plexi and on the aluminium plates so the fan can “breathe”.
If you look closely you will notice that the channels on the top and the bottom aluminium plates are with different size. That’s made on purpose.
So, after all the details were finished it was time to check how all things looks together.
The thing I saw made me think that I will have to upgrade the lights because all those holes make the light unstable.
Old 22nd Aug 2012, 07:22   #57
Dk_vr
Multimodder
Dk_vr's Avatar
After the last update I've decided to upgrade the lights to all of the levels and the result is:
Old 23rd Aug 2012, 02:23   #58
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Looking great .
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 28th Aug 2012, 20:40   #59
Dk_vr
Multimodder
Dk_vr's Avatar
Originally Posted by The boy 4rm oz View Post
Looking great .
Thanks mate I am happy that you enjoy it.
Anyway I've reached a point where I need help from you guys.
I wonder where to place a small text that will be cut on the aluminium plate with laser and will be glowing.
I've got a small sticker that I used to point where this text will be cut in the aluminium.
Please vote where you like it the most because I cannot decide by myself.
Option 1:
Option 2:
Option 3:
Option 4:
P.s. I am sorry but I have no idea how to create a real poll so I made it like this
Old 28th Aug 2012, 21:30   #60
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.
Option 3.
Absolutely loving the way this is going! The layered shape of the case is fantastic! Keep up the brilliant work!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - D-Link 320 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
