Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 18th Apr 2012, 22:17   #1
Tigernos
Resident Roman Soldier
Tigernos's Avatar
Tigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run CrysisTigernos can run Crysis
Windows for new build, but which one?
So I'm building a new system and I'm buying an OEM copy of windows, but which windows to get? It's going to be a gaming rig, nothing more nothing less. I might even install a web browser...
What are the advantages of going for Pro over Home? Or Ultimate over the both?
Answers on a post card
__________________
MY FIRST BUILD Case:Corsair Carbide 400R | MoBo:Gigabyte GA-Z77-D3H | CPU:Intel Core i5 3570K @ 4.5GHz @ 1.23v | Cooler:Arctic Cooling Freezer i30 | RAM:8GB (2x4GB) LP Corsair Vengeance Blue | GPU:Gigabyte GTX 560Ti 1.2GB | PSU:600W Corsair Gaming Series | Monitor:Dell U2412M
Tigernos is offline   Reply With Quote
Old 18th Apr 2012, 23:13   #2
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
Just for your information, so that you don't say you were not informed:
Windows 8 is coming end of the year.
It will have 2 editions only: Windows 8 and Windows 8 Pro.
Comparison table:
http://windowsteamblog.com/windows/b...-editions.aspx
Windows 8 Pro Consumer Preview (that means BETA) is available now (free), if you want to try it out: (release Candidate OR Beta 2, is expected to be release in June):
http://windows.microsoft.com/en-US/w...nsumer-preview
Note that this is a beta version, and will expire at some point in time (usually, based on
previous version of Windows in Beta, the last Beta/Release Candidate release expires 3 to 6 month after the final version is out). All features are in the beta version.
_________________________________________
Windows 7
You definitely want to get the 64-bit version of Windows, no question asks, else you won't be able to use anything about 4GB MINUS your video card memory (so in your case, about 3GB will be addressable, with the computer in your signature), also you'll lock down your 64-bit CPU into a 32-bit CPU, and lose all added security feature of your 64-bit processor, and loss all benefits of running your OS, codecs, and programs in 64-bits.
Here is a comparison table of Windows 7 editions:
http://en.wikipedia.org/wiki/Windows...mparison_chart
NOTE:
- Starter Edition is essentially free (or very low cost) Windows 7, that ONLY trusted OEMs are given, and ONLY for netbooks with max specs limits
- Home Basic edition is sold for emerging markets.
- Enterprise edition is for Volume License. In other words, companies that buys 1000+ licenses of Windows, and such. (The features are always been the same as the highest edition).
So the only editions that you have access and concerns you are: Home Premium, Professional, and Ultimate.
Most people Home Premium edition is more than enough.
Professional edition is for people wanting Windows Remote Desktop, Domain joining, data encryption, XP Mode, and/or advance backup features.
Ultimate edition is for those who want the Enterprise features, but only buying 1 license (so: advance domain features), and bit drive encryption (you need a motherboard with a TPM chip built-in, to use this encryption system).
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 18th Apr 2012, 23:14   #3
Teelzebub
Satan the one true God / Modarator
Teelzebub's Avatar
Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.
Get the Home upgrade, You can still do a fresh install with it and it wont be tied to the one rig as the upgrade has the full retail rights.
There's 3 methods of installing it I use the double install method. which is a perfectly legal method according to M$
I would do your research and not listen to some of the advice you will get on this subject everyone thinks they know best
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86
A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not
Teelzebub is offline   Reply With Quote
Old 18th Apr 2012, 23:54   #4
GoodBytes
GoodBytes's Avatar
Please don't recommend illegal activity, this is against Windows License agreement, which can make his license void, and because it's against a license agreement, it is also against forum rules. Doesn't mater if it works. You don't know if it will work with a new Service Pack, or Windows update, if MS chooses to fix this by-pass.
__________________
Old 19th Apr 2012, 00:25   #5
Tigernos
Tigernos's Avatar
So basically Home is the only one that applies to me as I don't actually need/want any of the extra features that Pro or Ultimate would give me.
I knew windows 8 was coming but I intended to have this build finished and playing by next month or early June depending on bookings I get at work (post school term break the schools are always slow to book me again) if it comes out before then I'll get it and if not I'll upgrade later. There shouldn't be a big rush to get into windows 8 and I'm sure games and such will stay compatible for a long while yet.
Thanks for all that info tho, I certainly learned a few more things I didn't know previously. (The Witcher is still downloading by the way. 7 hours and it's just over half of the 8.4GB download, my Internet SUCKS)
__________________
Old 19th Apr 2012, 00:30   #6
GoodBytes
GoodBytes's Avatar
Pretty much.
WAIT, you said you are student. Did you check for Student offers? If your college or university is part of MSNDAA, you have at least one Windows 7 license waiting for you to download and enjoy for free.
__________________
Old 19th Apr 2012, 00:42   #7
Tigernos
Tigernos's Avatar
Not a student, teacher. With a twist.
When I say I work in schools what I'm actually doing is dressing as a first century Roman legionnaire and teaching roman history in various schools around the UK. Or taking shook classes on tours of Chester (largest roman fort in Britain) if they come on a field trip to our city instead.
I'll link a picture tomorrow. I'm on my phone (damn technology) when im supposed to be sleeping as I have three classes to teach tomorrow morning. Hahah
__________________
Old 19th Apr 2012, 01:04   #8
GoodBytes
GoodBytes's Avatar
That sounds really cool. I love teachers that TEACH, instead of being in the front of class and reading a book, or passing through PowerPoint slides which has no idea what PowerPoint slide is, and uses the tool because he is too lazy to write on the board. Like trying to screw a a screw with a hammer. No wonder people say that PowerPoint should be banned (the problem is that before, it was the same crap, but with overhead projectors).
If I was a teacher (in computers field), I would so make my powerPoint slide properly.
Simple, few to no words, and to show WORKING and if possible INTERACTIVE diagrams for students to understand and simplify things. Explain stuff, be active, lively, even if I am over the top in class, and look silly. At least I have everyone attention, and everyone is learning.
I HATE teachers that goes "Open you textbook at page.." COME ON! Teach or leave.. I can read the book myself, thanks!
Anyway, I am ranting now.
All I have to say is that have now my full respect! +rep
__________________
Old 19th Apr 2012, 01:16   #9
Tigernos
Tigernos's Avatar
Thanks for the rep! I now have two green blocks! Go me! Haha.
As for interactivity, you can't get much more interactive than a guy stood in 25kg of iron in full authentic roman military attire. I even turn orange when it rains, it seriously almost insta-rusts.
__________________
Old 19th Apr 2012, 01:22   #10
GoodBytes
GoodBytes's Avatar
haha nice.
__________________
Old 19th Apr 2012, 01:30   #11
faugusztin
I *am* the guy with two left hands
faugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for president
Just one note - Home Edition is limited to 16GB max. Pro/Ultimate have 192 GB memory limit.
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro
Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04
faugusztin is offline   Reply With Quote
Old 19th Apr 2012, 01:52   #12
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.
Oh man, that sounds like an amazing job. I'm starting to regret not studying Archaeology for my degree, my heart really isn't in what I'm doing now.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M
Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 19th Apr 2012, 07:45   #13
Tigernos
Tigernos's Avatar
IMO there's no better job. As for not studying archeology I wouldnt regret it too much, the majority of people who have an archeology degree aren't employed in the field anyway, there are very few jobs to be had as the majority of the government don't want to pay to dig up the history around them. At least you have work!
__________________
Old 19th Apr 2012, 07:59   #14
noizdaemon666
I've been away far too long
noizdaemon666's Avatar
noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.noizdaemon666 is the Cheesecake. Relix smiles down upon them.
It isn't illegal and Microsoft would have no way to prove how you installed Windows.
Besides all Windows 7 discs are the same so they'd have to change every single Windows 7 disc in the world to stop it.
I don't see how it can be against forum rules when Microsoft make the Upgrade edition do a clean install automatically if no previous version is detected or the previous version can'tbe upgraded.
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU
noizdaemon666 is offline   Reply With Quote
Old 19th Apr 2012, 09:15   #15
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for presidentRichCreedy should be considered for president
it is technically illegal, if microsoft could be bothered, they could prosecute for using an unlicensed operating system, are they likely to, no probably not.
the reason they make it possible to do a straight install, is because you can't do a straight upgrade of some versions of windows.
its the same thing with oem windows, as a home builder, you aren't supposed to buy oem, you're supposed to buy retail.
buying a legitimate license, doesn't mean you are correctly licensed, if you don't follow the license terms you agreed to by opening the packaging.
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 19th Apr 2012, 10:18   #16
3lusive
Ultramodder
3lusive's Avatar
3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.3lusive is a hoopy frood who really knows where their towel is.
I couldn't care less if people exploited this loophole because Microsoft do everything corporately possible to avoid paying tax on that software.
Why do you think their software licensing branch is based in Reno, Nevada? It's so they can avoid paying taxes because software licensing isn't taxed in that state, but in Washington state it is, so by artificially recording it in Reno they have avoided approx $770 million in taxes over 13 years (the software is developed in Redmond, Washington). This is just one very small example of how they avoid paying taxes, but it extends to the rest of their business.
Furthermore, if you knew anything about Microsoft's tax policies you would know they are one of the worst offenders globally, with multiple violations of tax evasion across various countries (in India they were found guilty of tax evasion and fraud).
Does this mean it's ok to pirate their software? No. But it's ironic that some people are so quick to denounce someone for simply playing inside the rules (not officially illegal), but are completely silent when Microsoft avoids billions of tax globally each year on the very (overpriced) software you are so keen for them to make profits on.
So do we really have to pick on the pirate when the emperor hardly plays fair game too, and does so to a far far greater extent.
__________________
Antec 300 | Asus P8H67-M Pro R3 | i5 2500K | 16GB XMS3 RAM | GT 430 Zone | 60GB F60 SSD | 1TB F3 + 500GB HDD | CX430W PSU | Logitech G500 + C510 | Win7 Ultimate x64
3lusive is offline   Reply With Quote
Old 19th Apr 2012, 10:26   #17
RichCreedy
Hey What Who
RichCreedy's Avatar
microsoft are playing by rules that governments have allowed, rightly or wrongly. if the rules allow them to avoid taxs they will do it, i bet apple also do the same thing, you will find many a switched on business doing the same.
__________________
Old 19th Apr 2012, 13:24   #18
GoodBytes
GoodBytes's Avatar
Playing Robin Hood or a-like, is no excuse.
If you don't like Microsoft policies (not paying tax) then do not buy and DO NOT use their product. They follow the law, and nothing stops other companies (btw, they ALL do, even the small mom and pop shop... how many people buy stuff for home, and deduct them for their store, including cars, to reduce or not pay taxes), to exploits the system. Is it wrong, morally, yes. But the law wording, doesn't say you can't do this. Law maker won't correct them, because who hires people? and who politically support them? Businesses.
I don't go "Adobe software are too expensive, it cost them 1/4 of the price to make... so now I'll pirate their software!". This is wrong. The reason why the price is high, is because people have no problem paying that much for the produce.
__________________
Old 19th Apr 2012, 13:58   #19
Tigernos
Tigernos's Avatar
I can't really say much on the matter as I know damn all about the situation with Microsoft and tax evasion (my accountant does it for me) but the way I see it, as long as the grey areas and loopholes exist people will exploit them, I know I would, wether its morally quesionable won't factor in when you can save x pounds dollars or whatever on doing it one grey but legal way rather than the shiny white version.
It's kinda like when I filter my motorcycle down between the lanes in traffic, not technically illegal as there's enough room for me to "overtake" however if I were to try it in high speed traffic I'd be jumped on by every police officer who saw me. I suppose what I'm saying is its a matter of severity. You can dance in the shady areas of law as long as you don't go too crazy.
Personally I'm a cynic to some degree and won't trust anything that isn't 100% authentic. So though I could pirate a copy of win7 I'd rather pay my £70 for it and have the backup and support there as well as buyers rights and whatever else to fall back on should it all go belly up.
__________________
Old 19th Apr 2012, 14:34   #20
terrorbyt
MultiModder
terrorbyt has yet to learn the way of the Dremelterrorbyt has yet to learn the way of the Dremelterrorbyt has yet to learn the way of the Dremelterrorbyt has yet to learn the way of the Dremel
Pretty much.
I'm unaware of this, I'm in my first year of university, in UK
terrorbyt is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
