Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 20th Apr 2012, 13:55   #1
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
How quiet is your water pump?
I have an EK DCP 4.0. An inexpensive pump that gives good head.
It's not fitted in case but on a mount I made alongside rad and res sitting by open window. The pump needs to sit on low density pond filter foam in order to stop the vibration reaching the wooden window sill. The pump makes a low level (quiet) grinding noise audible if you put your ear within a few feet. It's a quiet pump overall. No high frequency noise.
So what about some of the more expensive pumps like the Laing D5, do they produce a high frequency whine?
Is there a high capacity pump that is near silent (no high frequency and minimal vibration)?
feathers is offline   Reply With Quote
Old 20th Apr 2012, 14:32   #2
slaw
At Argos buying "gold"
slaw's Avatar
slaw has yet to learn the way of the Dremelslaw has yet to learn the way of the Dremelslaw has yet to learn the way of the Dremelslaw has yet to learn the way of the Dremelslaw has yet to learn the way of the Dremelslaw has yet to learn the way of the Dremelslaw has yet to learn the way of the Dremel
Hey
I have a MCP 355 fitted to a xspc bay res and it makes a fair bit of noise. I think its due to me not being able to screw the res down due to the place of the mounting holes in my case. I have now set the pump to 7v which makes a lot of difference but its not silent.
If your after quiet, i would look at the new pumps from alpha cool. Alphacool do some a nice bay res that can take 2 of them which looks quite nice.
__________________
Gigabyte GA-X58A-UD3R
Intel Corei7 920 @ 4GHz
12GB Corsair Dominator
GTX 480
slaw is offline   Reply With Quote
Old 20th Apr 2012, 14:35   #3
Gurdeep14
Supermodder
Gurdeep14's Avatar
Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.Gurdeep14 is a hoopy frood who really knows where their towel is.
LOL
sorry, ill leave now
p.s.
I have two D5's in my system, at max speed resting on a silicon mat and they are quite noisy
__________________
Intel Core i7 920 D0 @ 4Ghz HT | XFX HD 7970 Core Edition 3GB | ASUS Rampage Extreme II | 12GB Corsair Dominator CM3X2G1600C8D | Enermax Revolution 1250W | ASUS Xonar D2X | 256GB Crucial M4 | 256GB Samsung 830 |2 Samsung F3 1TB | Silverstone TJ-07 |
Gurdeep14 is offline   Reply With Quote
Old 20th Apr 2012, 14:37   #4
dead beat
Rippin six 4 life
dead beat's Avatar
dead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for president
Yeh the Alphacool pumps that I have used in the past have all been silent. I'm using a pair of Koolance PMP-400's now which are also silent.
__________________
ASUS ROG Maximus IV Extreme-Z68 | Intel i7 2600K @ 5.1Ghz | 2x EVGA GTX680's SLI (water) | 8GB Corsair Dominator GT RAM @ 1866Mhz | Corsair AX1200 PSU | Crucial M4 256GB SSD | 2 x Samsung Spinpoint F3 HDD's | Dimastech Easy bench Dual V2.5 | Dell 3007 WFP-HC 30" monitor | Custom dual radiator waterloop
Photography gear: Nikon D800 | Nikkor 24-70mm f2.8 | Nikkor 70-200mm f2.8 VRII | Nikkor 35mm F2/D | Nikkor 50mm 1.8D | Nikkor 85mm 1.8G | Nikon TC-14E II | SB-700 Speedlight
dead beat is offline   Reply With Quote
Old 20th Apr 2012, 14:42   #5
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.
I'm using the DCP 4.0 as well, so I can't really comment, same nasty grinding noise as you hear, but much minimized when I turn the voltage down to just above stalling. I have a DDC I bought a few months back, but haven't gotten around to fitting it-I'll probably do it when I add in a GPU block.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M
Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 20th Apr 2012, 14:43   #6
feathers
Banned
Originally Posted by slaw View Post
Hey
For a short loop I guess that's ok but my choobing is several metres long (3 perhaps). I would imagine it's hard isolating the pump motor when fitted to a bay res. If the pump is screwed tightly then the vibration is transmitted through the case so the entire case will hum. The hard disks in my cosmos case slot into vertical trays. The trays have soft rubber mounts. If I turn the screws tightly then the soft rubber grommets have no effect, all the vibration goes through the case via the metal screws that mount hard disk to the slide in tray. Screw it in loosely and the rubber grommets have more of an effect helping to isolate the hard disk motor.
Originally Posted by Gurdeep14 View Post
LOL
4.1 metres of head I believe.
:0
Old 20th Apr 2012, 14:49   #7
Plodder
Modder
Plodder has yet to learn the way of the Dremel
Ive got a Laing D5 Vario. i find it quietest on setting 3, but its easily the noisiest thing in my system still. It makes a faily audible humming noise which is pretty irritating.
Plodder is offline   Reply With Quote
Old 20th Apr 2012, 15:16   #8
Marvin-HHGTTG
Marvin. I don't care what ^ says...
Marvin-HHGTTG's Avatar
Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!Marvin-HHGTTG - it's over 9000!!!!!!!!1!1!1!!!
Laing D5 with an EK 2.0 top, and it's absolutely silent. When I was leak testing after bleeding the loop it makes no noise whatsoever (well, it's not audible to me) - obviously I've soft mounted it, and this results in an excellent pump that you easily forget exists.
Marvin-HHGTTG is offline   Reply With Quote
Old 20th Apr 2012, 15:24   #9
Spreadie
No disassemble!
Spreadie's Avatar
Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.
Yeah, D5 Vario and the same top here.
If I whack it up to max, I can hear a slight hum but only if the fans are turned down low - hardly likely though, I only max the pump when I'm benching with the fans maxed too.
It's sitting on a 1/2" thick piece of packaging foam, secured by some double-sided sticky foam. i.e. the ghetto version of the Shoggy Sandwich.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60
Spreadie is offline   Reply With Quote
Old 20th Apr 2012, 16:00   #10
feathers
Banned
Ok so thus far it seems some have noisy pumps and the most common type of noise is low frequency vibration. This is hardly surprising especially for those with pumps inside case since cases can act as sound amplifiers. The surprise so far here is the D5 vario with EK top. A quiet pump it seems. I like my pump at max speed due to the size/length of my cooling setup.
Old 20th Apr 2012, 16:13   #11
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on you
MCP350 is the loudest thing in my pc. Not so much noise of the pump itself, but the sound of water moving is fairly loud. I have a tight cpu only loop with about 60cm of tubing, block, rad and res. As hard as it pushes the water when it comes back into the res it has a jet effect and looks something like a jacuzzi.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx
| creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 20th Apr 2012, 16:28   #12
dead beat
Rippin six 4 life
dead beat's Avatar
Sounds like you have air in your loop. If you bleed it all out then the loop should be silent.
__________________
Old 20th Apr 2012, 16:29   #13
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
wait what are we talking about here..
good subject- like lysol has a jacuzzi going on.. maybe one of those other pumps I hear guys use
thehippoz is offline   Reply With Quote
Old 20th Apr 2012, 16:49   #14
feathers
Banned
Old 20th Apr 2012, 17:36   #15
IvanIvanovich
I'm pretty sure there is not air trapped. Air getting trapped is already unlikely due to the way I must fill it, and I know all about bleeding.
When it powers on you can see the jet of water in the res before it turns white from rapid motion. It's just the whooshy water moving noise. It probably only seems loud to me since it is the only audible thing in my pc. My fans are super quiet near silent which are the only other moving parts.
__________________
[end of line]
Old 20th Apr 2012, 17:41   #16
digitaldunc
Soylent green is horses!
digitaldunc's Avatar
digitaldunc has yet to learn the way of the Dremeldigitaldunc has yet to learn the way of the Dremeldigitaldunc has yet to learn the way of the Dremeldigitaldunc has yet to learn the way of the Dremeldigitaldunc has yet to learn the way of the Dremeldigitaldunc has yet to learn the way of the Dremel
Have dual DDCs in a bay resevoir.
They make a mid pitched hum but aren't overly intrusive -- however I removed my optical drives a few days ago as the pumps were somehow making them resonate with distracting vibrations and remounting didn't seem to make a difference.
I've heard anecdotal evidence that suggests bay reservoirs are the worst for these types of problems -- I'm considering ditching the DDCs and getting a pair of D5s as I'd be interested to see what difference the increased flow makes.
__________________
Event-horizon: i7 2600K @ 4.5 @ ~1.3v | 16Gb Corsair Vengeance @ 1866 9-10-9-24-2T | 2 x 580 1.5Gb (SLI) 772/1002 | Asus P8P67 Deluxe | Crucial M4 256Gb | Spinpoint F3 1TB | Corsair HX1000 | ZM-MFC1 Fan controller | XSPC Dual res | 2 x DDC 18W | Black ice stealth 360 | ThermoChill PA120.4 | EK Supreme HF Nickel | 2 x EK 580 Plexi | 7 x Scythe Gentle Typhoon 1450RPM | Modded TJ07
digitaldunc is offline   Reply With Quote
Old 20th Apr 2012, 18:15   #17
thetrashcanman
Angel headed hipsters
thetrashcanman's Avatar
thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.thetrashcanman is a hoopy frood who really knows where their towel is.
I've got Dual D5's in one of these http://specialtech.co.uk/spshop/cust...pid-15044.html
put both pumps on 3 or 4 and once you bleed the system, which is a pain in the arse with a bay res, (also pumps generally make more noise in a bay res due to transferring vibrations through the case and not having a way to damp them) and tbh I can barley hear both pumps once the side panels on, bear in mind my computer sits on my desk about 30cm away from me.
__________________
i7 3930k/watercooled on 360 rad/Asus Rampage IV Extreme/16Gb Corsair Dominator GT 2133Mhz/Gtx 480/2 x Corsair Force GT 240Gb RAID0 /Silverstone TJ11/Enermax Platimax 1500W
thetrashcanman is offline   Reply With Quote
Old 20th Apr 2012, 18:24   #18
Big Elf
'Black Noise'
Big Elf's Avatar
Big Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for president
Eheim 1048 - Quiet at slow speeds, irritating buzzy whine when run at full speed.
EK DCP 4.0/Phobya 400 - Easily the nosiest pumps I've had at full speed even when fully decoupled (hanging by soft tubing). At 5v they're very quiet.
Swiftech 655/Laing D5/Alphacool 655 - Noise levels vary from pump to pump, none of them have been quiet at full speed but still generally quieter than most other pumps but with a noticeable whine. Setting 2 and below are very quiet.
Swiftech 355 - Only ever run at full speed and whines a bit, not too bad though.
Swiftech 35X - Extremely quiet at slow speeds (about 1600rpm which is where they spend most of the time). A pair of them create a resonance, even when decoupled and are noisy at higher speeds. A single one is extremely quiet at full speed.
Big Elf is offline   Reply With Quote
Old 20th Apr 2012, 18:40   #19
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
I use a 7 year old Laing DDC Pro (10W) mounted on a double set of velcro, which is dead silent still.
Mankz is offline   Reply With Quote
Old 20th Apr 2012, 18:47   #20
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpit
I have 2 x Laing D5 with EK 2.0 top and 1 x Laing D5 in a reservoir (not in the same system, of course), with no sound dampening and can only tell they are on by putting my hand on them to feel for vibration They are all turned up to full speed.
debs3759 is offline   Reply With Quote
Reply
Tags
breasts, head, kitten, pump
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
