Old 23rd Apr 2012, 08:27   #1
CytheriaHill
What's a Dremel?
CytheriaHill's Avatar
CytheriaHill has yet to learn the way of the Dremel
Xbox 360
How do I make my Xbox 360 wireless using a wireless network and a router instead of the expensive Xbox adapter?
I have an Xbox 360 and wireless internet in my building. I do have a Linksys braodband router to use to make my Xbox wireless instead of buying the expensive Xbox wireless adapter. Any help please. Thank you!!
CytheriaHill is offline   Reply With Quote
Old 24th Apr 2012, 10:21   #2
adzc1987
Supermodder
adzc1987's Avatar
adzc1987 has yet to learn the way of the Dremeladzc1987 has yet to learn the way of the Dremeladzc1987 has yet to learn the way of the Dremel
The only way i can think of is some sort of device that runs off the wireless but acts like another router?
Like using internet connection sharing on a laptop with Wifi then pluggin xbox into the LAN of the laptop
Wifi > Laptop > Xbox?
Im not sure if a device exists tho.
adzc1987 is offline   Reply With Quote
Old 24th Apr 2012, 10:33   #3
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
You can create a Bridged Wireless/LAN connection on a laptop which will allow the Xbox to connect to the internet.
You don't need anything fancy to do this just a Network cable and a laptop.
Go to Control Panel>Network & Internet>Network Connections. You will see two or more Network Connections. A Wireless Connection and a LAN Connection. Assuming you are connected to the internet one will be active and the other wont.
Highlight the LAN and Wireless Connections. And Right click on either one of them. There in the list it should says Bridge Connections This digitally connects Wireless & LAN Connections.
Now using the Network cable plug it in to your Laptop LAN and XBOX LAN Ports. I know it took some fiddling with settings. Even maybe inputting the settings manually. But I did do it once.
I have given you what i think you need to do this, but there is an issue in that the laptop shares the network connection and will take priority over it so whilst this works in theory it may not be the best way to get a Network Connection to your XBOX.
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
MrDomRocks is offline   Reply With Quote
Old 24th Apr 2012, 11:26   #4
Jedra
Supermodel
Jedra's Avatar
Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.
Something like this will do the job - far cheaper than the official Xbox version.
__________________
ASUS P6X58D-E - Intel Core i7 930 - Thermaltake FRIO - 12GB Corsair (6x2G CMD12GX3M6A1600C8) - Corsair AX1200 - 2GB Sapphire Radeon HD5970 OC - 256Gb Crucial SSD - X-Fi Titanium Fatal1ty Pro - Silverstone Fortress FT02R-W
Steam Profile ---------- XBL:Jedra ---------- PSN:Jedra ---------- BF3:Jedra7609 & Jedra
Jedra is offline   Reply With Quote
Old 24th Apr 2012, 13:38   #5
adzc1987
Supermodder
adzc1987's Avatar
Thats the sort of thing i was thinking of, just didnt know what it was called lol.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
