Reply
Thread Tools View Mode
Old 23rd Apr 2012, 08:34   #1
skitzab1
Multimodder
skitzab1's Avatar
skitzab1 has yet to learn the way of the Dremelskitzab1 has yet to learn the way of the Dremelskitzab1 has yet to learn the way of the Dremel
Storm Fortress
hi guys this is my first work log so i dont know much about using this forum
it will be an intel base build and the green team for vga a mix of ek and xspc cooling for now
and this is what i have to work with for the now
what it was
as u can see the color theam for now is blue and black
but as the mobo may change soon the color may aswell
any ideas or criticizem
im a newbie to build logs so any help is welcome i have been modding for over a decade
my first mod was done to a 486 dx2 66mhz with a woping 16mb of ram
dim switches to overclock i think i got it to 73mhz
the first hertal the water-blocks did not fit the cards so i made them fit !!
some sleaving
and time to cut
cut up and test fitted mobo tray rotation 90*
and some pron
i have been working on replacing the back im am trying to use as much of the silverstone case as i can so im using the floor of the silverstone case
and im also trying to work out the PSU position
first idea
second idea
im thinking this ^
i have extended the psu mount 45mm out the rear of case
fitted skin in rear of case will be cutting rad mount in
and window desine gonna ponder on the window for a few days before i cut
and also i will be only using materials from the 2 cases no outsourcing sheet metal or plexi the only real things outsourcing tools and paint /sand paper /pop rivets
im thinking this mite work
i thort of this
the face will be cut in aswell
is this where the theme takes a massive detour crap iv been doing blue black aqua
and it looks like its going to take on a halloween theme
hope you all are like the way things are going it seams to be changing as i go who knows how this will end up ..
and thanks for all the comments keep them coming it seams to make me work harder( get more done)
update
XSPC give u 2 of these face plates in there tank kits and so forth so why not put the other to use
keep in mind ther will be 2 ssd on the plate
this will be bolted together with hex bolts
CENTER]BooM!!!!!!!!!
i evan shocked my self
[/center]
skitzab1 is offline   Reply With Quote
Old 25th Apr 2012, 08:37   #2
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Good start +sub
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 25th Apr 2012, 08:45   #3
skitzab1
Multimodder
skitzab1's Avatar
Originally Posted by Fuganater View Post
Good start +sub
thanks man for taking the time i will be trying to update day by day ...
glad u like it and thanks for the sub
Old 25th Apr 2012, 11:23   #4
Fuganater
Supermodder
Fuganater's Avatar
Don't worry about the quantity of updates. Just the quality.
__________________
-Fugatech-mods-
-Facebook-
Old 25th Apr 2012, 13:30   #5
skitzab1
Multimodder
skitzab1's Avatar
dont worry bout that im pedantic about my builds this thing has changed so many times as its been going along.
i just like something that i have done than something els i think of looks better
modding and building is a full time thing for me at the moment no work
but when it comes to spelling and grammar im no-good at that.
so please bare with my hard to understand statments ..
. but i think the pics tell the story
thanks for the comp!!! aswell
Old 25th Apr 2012, 17:48   #6
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
very cool so far.. excited to see where it goes.. subbed
whyte is offline   Reply With Quote
Old 26th Apr 2012, 03:40   #7
paultan
R E V E N T O N
paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.paultan is a hoopy frood who really knows where their towel is.
like it!
paultan is offline   Reply With Quote
Old 26th Apr 2012, 15:07   #8
skitzab1
Multimodder
skitzab1's Avatar
XSPC RAYSTORM (INTEL)
XSPC RAYSTORM INTEL ALUMINIUM BRACKET
LAING DDC-PUMP 12V DDC-1PLUS 18W X 2
WC DUAL DDC CASE LT
Hardware Labs Black Ice GTS 280 X 2
MAGICOOL EXTREME DUAL 180
NANO G-14 PWM BSE X 4
SILVERSTONE 180mm AIR PENETRATOR X 2
res tank not desided yet this has been purchesed and should be here in a few days
Old 28th Apr 2012, 21:14   #9
skitzab1
Multimodder
skitzab1's Avatar
Not finished but sneek peek!
Just tape holding it together at the moment took ages just to pull it all apart again and ther us a little i have to add to the top for 2 drive bays
man i wish this was not sold this is really coming along well
Old 28th Apr 2012, 22:48   #10
330td
Multimodder
330td's Avatar
330td has yet to learn the way of the Dremel
This front grill is a neat idea
Will you stick with these red fans?
330td is offline   Reply With Quote
Old 28th Apr 2012, 23:41   #11
skitzab1
Multimodder
skitzab1's Avatar
I am thinking that this is gonig to be a cm storm theme.
It is black and red. so thay may get used or may not.
Ther is 2x 140x280mm rads going in the front
Old 30th Apr 2012, 16:00   #12
skitzab1
Multimodder
skitzab1's Avatar
going to be droping the rads in tonight if anyone is interested in watching.
my skype is skitzab1
ill be starting probly 30 min from now so um yer just add me if u r interested in watching and hanging out !!!!
Old 1st May 2012, 07:08   #13
skitzab1
Multimodder
skitzab1's Avatar
Old 1st May 2012, 18:43   #14
skitzab1
Multimodder
skitzab1's Avatar
again stopped until further notice due to attitudes of bit tech members
Old 1st May 2012, 19:07   #15
dbradford32
Multimodder
dbradford32 has yet to learn the way of the Dremel
This looks pretty awesome! Don't stop on the account of others attitudes... Seriously, if anyone else is going to give you attitude for something you are doing, then ignore it and keep plugging on! Seriously, if every piece of criticism I had been given, made me give up, I wouldn't continue modding. You are who you are as an individual, and what you do is up to you. I would much like to see where you are taking this, so please don't quit!
__________________
Yesterday is history, Tomorrow a mystery, today is a gift, which is why it is the "present".
dbradford32 is offline   Reply With Quote
Old 1st May 2012, 19:10   #16
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
That ^
Although, I don't know what you're talking about attitude wise... I have seen nothing but positive and/or encouraging posts in this thread so far... am I missing something?
Edit: Never mind, I see most of your other threads turned into flaming... well, flaming at any rate. Sorry to see that happen. Do what you must, I guess.
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 1st May 2012, 19:25   #17
skitzab1
Multimodder
skitzab1's Avatar
Originally Posted by Mosquito View Post
That ^
yer this one has been fine but i do have a few others.
check this one out and read thrue it it will explain and the pm.s iv been getting is off the chain
http://forums.bit-tech.net/showthread.php?t=230148
im so sorry about this Mosquito but until things change.
if u wish to follow this build u will have to find it on a norther forum
Old 1st May 2012, 19:25   #18
skitzab1
Multimodder
skitzab1's Avatar
That ^
soz double post
Old 1st May 2012, 19:51   #19
dbradford32
Multimodder
PM me where you will be continuing this mod... I would like to follow it...
__________________
Old 2nd May 2012, 08:07   #20
skitzab1
Multimodder
skitzab1's Avatar
yer man its sweet its continuing im over it
picked a bad night ...
Originally Posted by ex4n View Post
mate im very impressed. looks like a lot of work and planning has gone in and it shows. love to see mod work which is more than just drilling a few holes.
i love the psu shroud, and how you've extended it out the back, and then fit a rad on the back too where the mobo used to be. the rad on the rear looks like it was meant to fit there.
this is looking like a real beast, keep it up
thanks ex4n.
as its still in bare metal form and working out cooling the res is not gonig where it was sitting in the pic i dont like it :mad:
bit more cutting and drilling than onto cleanup sanding----paint
and im moving in a week lols....
lots of work to be done over the next few days 5 days till wonka tower arrives at my door flat packed he he 5 days to finish this one
:tongue:
man i love short dead lines
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
