#1 |
Supermodder
Force deletion of a partition
ok someone gimme a hand with this before i rip my eyebrows out (not much hair left)
uninstaled ubuntu which has aparently created a few particians for me :| reinstalled windows on C however one of my hardrives is appearing in disk manager as particianed partician 1 is 457.77Gb partician 2 is 7.99Gb - AND has "system, active, primary partician" the system bit means it can be formated back into a single disk. however there are NO files on that Hd on either partician. im assuming its a remnant of ubuntu is there a way to force format the disk? there is NOTHING on my entire computer save windows 7 (ult 64) and drivers so lost data isnt an issue. can anyone help before i have a complete and utter nervous breakdown with this. been at it (and google) for 3 hours.
__________________
3X 22" Samsung monitors | Gigabyte P55 UD4 | i5 750 @ 2.6Ghz | ATI HD5770 | 8Gb Corsair dominator | XClio wind tunnel (heavy modded) | Windows 7 Ultimate 64 Bit | Western Digital 500GB HDD X3 + Mybook external | CM Storm | Zero motivation to upgrade |
#2 |
Co-Mumble Ruler!!
in Disk Manager, right click on the hard drive you wish to change the partition, it should show Expand/Shrink/Delete Partition in the list. Delete all Partitions and then format the HDD. This will make it an unpartitioned drive and then partition it as a single drive. You will have to assign a drive letter to use the HDD.
Hope that helps.
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
#3 |
Margon Man
I'm not sure you can do above from windows as the drive you are wanting to format is your system drive.
Make a recovery cd from backup and restore, boot that and go into the command prompt and do it all from diskpart. http://technet.microsoft.com/en-us/l...=ws.10%29.aspx - that link gives you all the options etc. with diskpart. edit: just read that it isnt your system disk. If you cant do it from disk management, then you will be able to do it from diskpart, which you can run from a command prompt in windows - no need for recovery CD.
__________________
i7 920 - 12GB - 5870 Keycool 87 Modded Clears - Cougar Attack Reds - KBT Oni Browns - Ducky DK1087 Blues - Cherry G80-3700 Blacks |
#4 | ||
Supermodder
SOLUTION: anyways so i FINALLY figured it out. i put my ubuntu CD back in the drive and loaded it up from disk, then using the disk managment tool in ubuntu i was able to format the drive. meant i had to reinstall windows (not an issue, it was a fresh install anyway) appreciate the help chaps.
__________________
#5 | |
Margon Man
__________________
#6 |
Co-Mumble Ruler!!
Ahh I see I may have misread the OP. Gratz on getting it all sorted mate!!
__________________
#7 |
Supermodder
yer it turned out that way. i THOUGHT it was a system file that ubuntu had just hidden somewhere beyond hidden folders. but no, was that wonderful MS again. gotta love em......or go chuck norris on em, one of the two.
__________________
#8 |
Super Moderator
Moderator
So, summarise the thread: Install windows, try and delete system partition, assume Microsoft are the stupid ones for not letting you hose an install?
#9 | |
Supermodder
install windows, windows installs boots files on none windows drive, THEN assume MS are the stupid ones for not even allowing me to see the files that they have installed onto the wrong HDD so i have no idea why i cant format. forcing me to load an alternative OS to format. try and keep up Krikkit.
__________________
#10 | |
Co-Mumble Ruler!!
__________________
#11 |
Good news everyone!
I've been caught by a Windows 7 install dumping system files on a random drive once before. I can't for the life of me work out whether that is a bug or by design. I removed the drive for use elsewhere and it rendered the PC unbootable, put it back and found the offending files. I'm lucky I hadn't formatted the drive before I next booted the PC it had come from, or I might have ended up borking that install permanently.
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 Why. |
#12 |
Margon Man
another thing windows will let you do, is install the os onto a dynamic disk, it will then continue after the install reboot to finish the install, it will then never boot again! because you cant boot an os off a dynamic disk. Why it doesnt tell you its a dynamic disk and you are wasting your time installing onto it, I will never know. Really, it should tell you ,and let you change it.
For the record though, I quite like microsoft - and really, it doesnt have that many problems that aren't PICNIC's (Problem In Chair, Not In Computer)
__________________
#13 | |
Hey What Who
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands |
#14 |
You're only supposed to...
We call it the PEBKAC Error:Problem Exists between keyboard and chair.
__________________
Right now, life feels good, tomorrow, who knows? |
#15 | |
Supermodder
.really appreciate the help though guys, thanks for taking the time.
__________________
#16 | |
ARM Evangelist
GParted is a non-destructive on-the-fly disk/partition management tool. You can resize, move, remove, add, etc, partitions on the fly; in most cases this will preserve your existing data - though, of course, if you're deleting a partition you will lose that data...! If you're only resizing or deleting partitions, it's usually pretty quick; moving a partition, or resizing it to the left does take a good while though... By "resizing it to the left", I mean this: say the partition you want to resize takes up the last part of the disk, like this: Code:
-------||| Code:
-----||||| Code:
|||||||--- I use GParted quite often when I want to install Linux on any of my machines and so far I've never lost any data using it. There is always the chance that something will go wrong (loss of power, random crash/hardware failure, etc); if that does happen mid-way through an operation it will hose your entire partition table, rendering the data useless and leaving your drive needing a complete wipe. Be sure to back up any critical files before doing this.
__________________
What's that? You don't care about my site? I don't care that you don't care - I'm going to spam you with the link anyway. Why yes, I do have a YouTube channel on which I put out Minecraft videos on a somewhat "regular" basis, thank you for asking. |
#17 |
fast as you can and don't fall off
Acronis Disc Manager trial version allows you to do this sort of thing for 30 days before requiring payment
__________________
i7 3930 @ 4.7Ghz : Asus Rampage IV Extreme : 16Gb Corsair Vengeance @ 2133Mhz : 512Mb Crucial M4 : ANTEC High Current 1200W : 2 x GTX570 SLi : Swiftech Apogee HD : XSPC dual bay res / pump : Custom water loop with 1 x 360 rad, 1 x 140 rad, CPU, GPU SLi, North and South blocks : CM Storm Spawn mouse : Logitech G15 : Creative X-Fi USB : Corsair Obsidian 800D : Crappy DGM 26" 1920 x 1200 monitor : Sennheiser PC350s : Belkin Nostromo : Alarming beer habit |
| Thread Tools | |
