#1 |
What's a Dremel?
i5 Stupid Overclock
Hi
I went a bit over the top with my 2500k O/C today, and was wondering if this voltage could do any damage to the CPU? http://valid.canardpc.com/show_oc.php?id=2342341 I'm using a Noctua NH-D14 to cool it's sweaty little bonce, but this chip seems to be holding up quite well! Thanks |
#2 |
Banned
LOLwank. Nice overclock. 1.68v? I thought I was pushing it at 1.52 but I use offset voltage so it doesn't stay high. +0.175 in bios.
I guess u could do with LN2. U wouldn't wanna keep it at that voltage long. I guess u didn't do a cpu burn test did u? |
#3 |
Hypermodder
Voltage is sky high, course it will shorten it's life
#4 |
MD of Mutant Zombie Armies Inc
that is an awful lot of volts for a sandybatch, considering a lot of them can get to 5ghz on just 1.4v! what temps are you getting under load?
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts. |
#5 |
Grr... Grumpy!!
It won't have increased its life expectancy I'm sure.
From what I've seen I'm pretty sure around 1.4-1.45 for everyday is border line. I went to 1.6v for a quick bench run on a 2600k but actually managed my highest clock at 5.3Ghz @ 1.5 something volt. I don't think there is any way for sure to know if its been damaged in any way, generally thing its something down to the more you hammer away the more likely it will curl over on you. Take it is still running ok now? This is aimed at a quick shot at top clocks, rather then a 24/7 OC?
__________________
-: MM UF0 Duality :- 2700K, 16GB Ballistix Tracer 1600, P67A-GD65, RAID0@ 2x120GB Vertex3, 580GTX, AX1200 :- -: Dual Loop Watercooling :- 2x Laing D5, 2x PA120.3, EK 580GTX Fullcover, EK Supreme HF, EK TubeRes :- |
#6 |
What's a Dremel?
It's running fine, I've been running Prime for an hour and nothing went smurfy, so I can only assume it'll continue. I just wasn't sure if it would slowly damage it or just make it keel over. Something tells me this isn't where I'm going to stop though...
#7 |
It's a tool.
I'd be too scared to put a 2500k under any kind of load at that voltage! Unless of course I had money to throw away. Which I don't.
__________________
My System: i5 2500K @ 4.7Ghz | MSI P67A-GD65 (B3) | 16GB Crucial Ballistix Sport 1600MHz | Corsair H-50 Push-Pull with Silent Eagle 2000's | Silverstone Raven RV03 | EVGA 670 FTW | Dell SP2309W | Antec 750W TruePower Blue | Win 7 x64 | Crucial 64GB C300 for OS | Samsung 830 256GB for Active Games & a 1TB Samsung for Steam. Perphiperals: Roccat Kone+ Max V2 | CMStorm Quickfire Pro with Cherry Reds | Cyborg F.L.Y 5 stick for flying and a Logitech DF GT for driving. |
#8 |
What's a Dremel?
I don't have the money either. I just tried a 54x and a 101 base clock and I think I pissed off the O/C gods. I've gone back to 5.3 but the volts are down now. Hopefully there won't be a puddle of silicon in the bottom of my case any time soon! I may have to look into that replacement plan Intel has.
#9 | |
Banned
Is it you? Are you back with a new system?
#10 | |
Good news everyone!
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 Why. |
#11 |
Banned
No but you just reminded me of someone I know online who opened the door to his computer room and found it filled with smoke. Had been a leak of crappy Feser UV coolant that caused a fire and the entire PC was destroyed. Are Feser still making coolant?
#12 |
Good news everyone!
More importantly, why do I still laugh out loud whenever I recall the time I was trying to be "cool" with a young female relative and referred to Fazer from N-Dubz as Feser in a text message?
I am a 30 year old geek who hates N-Dubz.
__________________
#13 |
I Mod, Therefore I Own
1.68 is a bit nuts for any long term survive like 2-3 weeks and the mobo will just fry itself and your chip
#14 |
Ndubz are a good case for enforced sterillisation.
__________________
#15 |
Co-Mumble Ruler!!
Thats pretty awesome and scary to say the least. I can't hit 4.5ghz on my i5 though it did it once before. Oh well.
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
#16 |
That is indeed crazy, however am I the only one who'd be trying anything to get that last little 0.1MHz to push it over the 5300 barrier?
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi AMD FX-6300-Gigabyte 990AX-UD3-MSi GTX660-Momentus XT-be quiet! E7-600W-Avexir 2x4GB 1600 Share And Enjoy! |
#17 |
Resident Roman Soldier
I was considering a mild OC with my new build, just for a little more oomf. Perhaps when I'm due an upgrade and will be scrapping the PC I might try something like this, until then my stance is: You're nuts. Have fun!
__________________
MY FIRST BUILD Case:Corsair Carbide 400R | MoBo:Gigabyte GA-Z77-D3H | CPU:Intel Core i5 3570K @ 4.5GHz @ 1.23v | Cooler:Arctic Cooling Freezer i30 | RAM:8GB (2x4GB) LP Corsair Vengeance Blue | GPU:Gigabyte GTX 560Ti 1.2GB | PSU:600W Corsair Gaming Series | Monitor:Dell U2412M
#18 |
Butt-kicking for goodness!
1.68V is huge. When I was benching mine 1.536V was my voltage for 5.3GHz, I would've thought you could manage 5.3 with a max of 1.6V.
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors BT Feedback |
#19 |
Likes cheese
That is crazy voltage, I benched 5.3GHz @ < 1.5v
http://valid.canardpc.com/show_oc.php?id=2162091 I think you'd want to tweak with a few of the other settings to get that stable at a lower voltage.
__________________
Intel Core i5 2500k @ 4.5GHz / ASUS P8Z68-V/GEN3 / ThermalTake Frio / Corsair Vengeance LP 8GB / MSI R6950 Twin Frozr III - Power Edition *Unlocked* / ASUS Xonar DS / Antec TruePower New 650W / Crucial M4 64GB + 256GB / 2 x Samsung SpinPoint F3 1TB / Fractal R3 / Logitech G15 / Logitech G500 / Dell S2209W / Dell E172FP BF2 | BF:BC2 | BF3 | Eve Online | Xbox Live | PSN | Steam - Siuxia |
#20 | |
Good news everyone!
__________________
| Thread Tools | |
