Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 24th Apr 2012, 10:02   #1
legoman
breaker of things
legoman's Avatar
legoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for president
Is this tempting or am i just mad to get a HTPC case
Been nosing about the lian li site which is never a good plan an spotted Lian Li PC-C60
http://www.lian-li.com/v2/en/product...25&ss_index=62
Am i losing the plot in wanting a HTPC that can take the hardware in my sig? Cooling wise its very similar to what i have now just it looks very tasty and could be an interesting base for a mod. I know my CPU cooler is too tall but that can be sorted quite easily and i can shoehorn my GPU in easily enough. What do people think? Could it be good or am i just crazy?
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW
legoman is offline   Reply With Quote
Old 24th Apr 2012, 10:08   #2
Shirty
Good news everyone!
Shirty's Avatar
Shirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run Crysis
If it feels right and you can afford it then why not? It'll be like going back to the mid-90s before towers were popular!
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock Z77E-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500
Originally Posted by Nexxo View Post
Shirty puts it succinctly: you must be crackers
Shirty is offline   Reply With Quote
Old 24th Apr 2012, 15:14   #3
legoman
breaker of things
legoman's Avatar
Feels right but I think id end up wanting something more fun. Id love a cube case but there's no normal ATX ones about their all mATX or ITX.
__________________
Old 24th Apr 2012, 15:22   #4
TaRkA DaHl
Ultramodder
TaRkA DaHl's Avatar
TaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpit
Cube ATX would be huge.
Currently rocking a Silverstone LC17, similar size to that. But mine is used as a media PC and sits in a unit under the tele, fits in very nicely.
I just need to get a low profile after market CPU cooler as this is too loud... and a couple of quiet 80mm fans.
TaRkA DaHl is offline   Reply With Quote
Old 24th Apr 2012, 15:26   #5
Shirty
Good news everyone!
Shirty's Avatar
If you want me to talk you out of it I'd say that it probably won't be great for cooling hot components compared to a decent tower case.
If you want a modding project you could convert your Dragonlord so that it lies on its side like an old school desktop. It'll be much cheaper
__________________
Old 24th Apr 2012, 22:09   #6
legoman
breaker of things
legoman's Avatar
True, it does look good though! ill have a play with the case i have in a bit. i still fancy a new case though
__________________
Old 25th Apr 2012, 09:08   #7
legoman
breaker of things
legoman's Avatar
This isnt going well, my graphics card fits, and looks small in there
Why you so tempting silly case! Anyone able to recommend a normal case that will hold my sig. Note the GPU is nigh on 30cm. Smallish windows always welcome.
__________________
Old 25th Apr 2012, 09:30   #8
Shirty
Good news everyone!
Shirty's Avatar
Probably a silly question, but have you had a good look here? It's by no means exhaustive, but reading through a few reviews will give you a good idea of what to look for.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
