Old 25th Apr 2012, 20:15   #1
Ghosthud1
What's a Dremel?
Ghosthud1 has yet to learn the way of the Dremel
Returns
Hi ccl
i purchased a motherboard from you in store last august and i was wondering how i would get a return as i dont have the receipt anymore :/
it is a asrock extreme4 motherboard that produced a PCI-E fault and now doesn't power on, i have testing the rest of the components in a friends computer and they work just fine.
Ghosthud1 is offline   Reply With Quote
Old 25th Apr 2012, 22:49   #2
Yorkie
What Goes On In His Head!?
Yorkie's Avatar
Yorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpitYorkie is almost as Godly as yodasarmpit
Should be able to pull it up on your account history if you pop in
__________________
daveplays.co.uk <--- What am I Playing
System Specs : AMD Phenom 960T (Unlocked) ~ MSI890GXM ~ 12GB Geil Corsa ~ OCZ Agility 3 120GB ~ AMD 6870
Ducky Shine with Blacks / Ducky Dragon with Browns
Yorkie is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
