Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 27th Apr 2012, 05:51   #1
Mac_Trekkie
Source Engine's #1 fan!
Mac_Trekkie's Avatar
Mac_Trekkie has yet to learn the way of the DremelMac_Trekkie has yet to learn the way of the Dremel
Can't choose on a router
Our old Lynksys SRX router is old and either AT&T is throttling us, or the router is causing me to go from 700 kb/sec download to under 100 at random intervals. If it is AT&T we'll switch to FIOS, but I figure I'd try the router first and even if that's not the problem, it's still a good excuse to get a wireless N router so I can finally set up a decent networked backup from the media computer.
Only problem is: I'm completely lost. I have no idea what would make a decent daily living router. I can choose one on the fly that will be acceptable for one reason or another, but I just don't know for a long term every day unit.
Only thing I know for sure is we need wireless N 300mbps speeds and more than 4 ethernet ports, as we have 5 devices we need plugged into it. Also we need WPA2 as there's a park next door and I don't want to get leeched so easily. All our computers are run off of wi-fi (about 6 at last count, usually with whatever I am building for work downloading the latest Windows updates as well.), so it's pretty important we get something reliable. An easy to use UI would be nice, too. Ability to attach a USB interfaced device would be nice, but not critical. Price is pretty much up in the air. Any help would be appreciated!
__________________
The Brass Balls: i7 870 @ 4.2ghz | Cooler: CM Hyper 212+ | 8gb G.Skill Ripjaws DDR3 1600 | GPU: ZOTAC GTX 560 Ti 448-core 1,280mb | Motherboard: MSI P55-GD65 | Case: ThermalTake Element G | ThermalTake 850w PSU | Samsung Spinpoint F3 1tb | Corsair Nova 32gb SSD
Mac_Trekkie is offline   Reply With Quote
Old 7th May 2012, 18:41   #2
Mac_Trekkie
I don't like to bump, but the router is giving me more and more problems, could I get a little help, please?
__________________
Old 7th May 2012, 18:54   #3
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.
i personally like netgear routers, netgear feature comparison for adsl2+ wireless routers.
they come with 4 ports, you can either add a switch, or get one of the 8 port prosafe routers FVS318N, but you would need a seperate modem for that one i use 2 dm111p v2 as modems on my network.
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 7th May 2012, 21:57   #4
Snubbs
CustomPC Migration victim....
Snubbs's Avatar
Snubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for presidentSnubbs should be considered for president
I'm a fan of netgears too. I own a DGN2200 which has been great so far. Seems stable and good wireless range (n300).
__________________
¦ i5 760 watercooled ¦ MSI P55-GD65 ¦ 4GB Crucial & 4GB Hyper DDR3 8-8-8-24 ¦ Inno3D GTX580 OC ¦ Crucial C300 128GB & Samsung 830 256GB ¦ 2x500GB F3's RAID0 ¦ ThermalTake Chaser MK-I ¦ Logitech G15v2 & SteelSeries Ikari ¦ Win8Pro&Win7Pro ¦
If I am without tool, I am without hope
Snubbs is offline   Reply With Quote
Old 7th May 2012, 22:15   #5
lysaer
Suck my unit! Kirk lazarus (2008)
lysaer's Avatar
lysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for presidentlysaer should be considered for president
I have been very impressed with the linksys stuff since Cisco brought them out. I feel netgear had failed to stay as current.
I've used Belkin as well and I've never been impressed with their gear so I wouldn't recommend it.
Aside from that you can go up to stuff like edimax but it just depends what you want to spend, consumer level right now I'd go with linksys.
Sent from my HTC Sensation using Tapatalk 2
lysaer is online now   Reply With Quote
Old 7th May 2012, 22:35   #6
hamza_tm
Mod Master
hamza_tm's Avatar
hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.
There was one make that IIRC is the daddy of routers, Billion or something?
Expensive, but the reliability and power makes up for it and your requirements seem pretty serious
__________________
Whisper quiet gaming: 2500k@4.4Ghz | P67a-GD53 | Vengeance 8GB 1600Mhz | Force3 120GB | M4 256GB | WD15EARS 1.5TB (Icy Box USB 3.0) | BenQ XL2411T 144Hz (no moar IPS xD) | X-Fi XtremeGamer | Corsair 550D | GTX680
CM Storm Quickfire Rapid MX Brown (Filco caps) | Steelseries Xai (yay) | Sennheiser PC360 | Steelseries 9HD
hamza_tm is offline   Reply With Quote
Old 7th May 2012, 23:48   #7
MarkW7
Total Noob
MarkW7's Avatar
MarkW7 has yet to learn the way of the DremelMarkW7 has yet to learn the way of the DremelMarkW7 has yet to learn the way of the DremelMarkW7 has yet to learn the way of the DremelMarkW7 has yet to learn the way of the DremelMarkW7 has yet to learn the way of the DremelMarkW7 has yet to learn the way of the Dremel
Owned about 4 Belkin routers for some reason.. a G+ MIMO one was good until it kept dropping connection, the rest were junk.
Also the majority of router come with 4 ethernet ports, are you after one with more or are you willing to use a switch?
__________________
MarkW7 is offline   Reply With Quote
Old 8th May 2012, 00:14   #8
Mac_Trekkie
Yeah a switch sounds like the best option at the moment. We currently have a Linksys, and it's served us well, so I might try for another one of those. Thanks for all the replies, everyone.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
