Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 27th Apr 2012, 08:26   #1
jamesn
Multimodder
jamesn's Avatar
jamesn has yet to learn the way of the Dremel
Looking for a new driving game...
hi all,
i am looking for a new driving game please. what would you recommend? really want good graphics and good physics.
thanks!
__________________
Case > Fractal Define R3 CPU > Intel Core i7 3.4Ghz 2600K@ 4.6Ghz PSU > Corsair 850HX
Motherboard > Asus P8Z68-V PRO GEN3 RAM > 16GB Corsair Vengeance Cooler > Antec Kuhler 920
SSD > 240GB Samsung 830 GPU > GeForce GTX560 Screens > Dell 3008WFP@2560x1600, HP 2210i@1920x1080
jamesn is offline   Reply With Quote
Old 27th Apr 2012, 08:36   #2
Gunsmith
Maximum Win
Gunsmith's Avatar
Gunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for president
Shift 2 with UCP 1.1 prerelease
__________________
The King of Crysis
// This is currently not used anywhere (David: and I don't see what this would be used for. Our hero is not Jesus).
m_stats.isWalkingOnWater = false;
Gunsmith is online now   Reply With Quote
Old 27th Apr 2012, 08:39   #3
jamesn
Multimodder
jamesn's Avatar
cool, will have a look. what is UCP?
EDIT: is there a demo before buying?
__________________
Old 27th Apr 2012, 08:45   #4
Gunsmith
Maximum Win
Gunsmith's Avatar
UCP is the unofficial community patch that the fans have made since EA dumped the game. there's no demo but you can buy the retail version for dirt these days.
__________________
The King of Crysis
Old 27th Apr 2012, 08:55   #5
jamesn
Multimodder
jamesn's Avatar
cool, will give it a shot. where can i get the latest patch from? can find plenty of links, but not to 1.1
__________________
Old 27th Apr 2012, 08:58   #6
Gunsmith
Maximum Win
Gunsmith's Avatar
you'll need to patch the game to 1.2 and then you can get ucp from here
READ CAREFULLY HOW TO INSTALL IT
__________________
The King of Crysis
Old 27th Apr 2012, 09:00   #7
jamesn
Multimodder
jamesn's Avatar
cool, looking forward to giving it a go.
is the patch up to the game an official patch?
__________________
Old 27th Apr 2012, 09:06   #8
Gunsmith
Maximum Win
Gunsmith's Avatar
official patches only went to 1.2, you'll need that as a base for UCP
__________________
The King of Crysis
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
