Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 17th May 2012, 19:49   #41
faugusztin
I *am* the guy with two left hands
faugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for president
I wonder if this is a CPU-Z bug or is my i5-3570@stock@P8Z77-I Deluxe running that low at total idle and at load (OCCT, Large data set) ?
In UEFI interface it is idling at 0.976V.
EDIT: AIDA is reporting values like 0.64-0.656V too.
EDIT2: ASUS Sensor Recorder says 0.632V as well.
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro
Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04
faugusztin is offline   Reply With Quote
Old 20th May 2012, 16:00   #42
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by NetSphere View Post
Anyone have any idea how much of an overclock you can get before having to increase voltage?
Or how much to not bottleneck a GTX680?
they use the 590 and similiar for reviews like this- shows off sli and crossfire scaling with the bus.. you should be fine net..
thehippoz is offline   Reply With Quote
Old 28th Jul 2012, 15:13   #43
hlajo
What's a Dremel?
hlajo has yet to learn the way of the Dremel
Hey i am a bit confused with the Shogun 2: Total War CPU Test resoult, is the only CPU Test means that you guys tested it with the intergrated GPU on the processors?
hlajo is offline   Reply With Quote
Old 28th Jul 2012, 16:18   #44
hlajo
What's a Dremel?
Hey, i am a bit confused with the Shogun 2: Total War CPU Test, is the only CPU test means that you guys tested it with the integrated GPU on the processor insted of the GeForce GTX 590?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
