Old 1st May 2012, 10:26   #1
KRONOS
As simple as that,well I never
KRONOS's Avatar
KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.KRONOS is the Cheesecake. Relix smiles down upon them.
Hole cutting.
Very new to modding so really dipping my toe here. I want to add a hole for a Mnpctech Pro-Line Vandal Resistant Power Switch or a Standard SPST On/Off Toggle Switch, bought from coolermiester and am wondering what is the best tool for cutting a 12-13mm hole in metal. At the moment I am putting together a test bench and want to add a power switch.
I know you can get a tool with various cutters for wood but is there something similar for metal?
Sorry folks the vandal switch is more 18mm and the off/on is around 12mm.
__________________
Steam ID. Mr Fraggle (UK)
Silverstone FT03/ /Gigabyte Sniper M3/I5 2500K/Corsair H60/8GB Ballistix Smart Tracer PC3 12800/Asus Direct CU 11 GTX 670/128GB Crucial m4/2 x 1TB HDD/ SST-ST60F-P PSU/Dell U2711/Ducky Shine 2/Logitech G400/.
Prodigy/ Asus P8H61-1/G840/(2x2GB) Crucial Ballistix DDR3 Blue LED/Kingston 128GB/500GB WD/HD4870/Corsair CX500/Dell U2410/CM Storm QuickFire.
KRONOS is online now   Reply With Quote
Old 1st May 2012, 10:35   #2
biojellywobbles
Multimodder
biojellywobbles's Avatar
biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.
There is a similar thing form metal but for only a 12-13mm hole you should be able to find a large drill bit I would think. Either that or drill a smaller hole and widen it with a dremel. Do you have a drill press or good electric hand drill to use?
biojellywobbles is offline   Reply With Quote
Old 1st May 2012, 10:48   #3
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Large drill bit
Small hole saw
Dremel
If you dont have the right bit, just drill a load of smaller holes around the outside to punch out the bit you don't want, and then file the hole down until the switch fits
Mankz is offline   Reply With Quote
Old 1st May 2012, 10:53   #4
bdigital
Is re-building his PC again
bdigital's Avatar
bdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpit
My advice.....don't bother with a standard still bit. It could end up messy.
Get a step drill bit, which is a cone shape. Means you can drill perfect round holes. I used one on my sign rig mid plate and was very pleased.
__________________
My photography website: http://www.polarityphoto.co.uk Please share! || Follow me @polarityphoto on Twitter||
Check out my Apline White TJ07 - Case Mod and Water cooled build. http://www.flickr.com/photos/6188486...7631486959032/
bdigital is offline   Reply With Quote
Old 1st May 2012, 11:02   #5
KRONOS
KRONOS's Avatar
bobby you are a genius, as I have one of those, I take it you mean one of these? http://www.ebay.co.uk/itm/STEP-DRILL...item4ab66578ff
__________________
Old 1st May 2012, 11:07   #6
Teelzebub
Satan the one true God / Modarator
Teelzebub's Avatar
Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.
This is what I use got mine on ebay but you should be able to get them from Machine Mart Get a slightly smaller size and file it to size
http://www.tool-wise.com/product_cat...aws/index.html
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86
A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not
Teelzebub is offline   Reply With Quote
Old 2nd May 2012, 13:58   #7
Dk_vr
Multimodder
Dk_vr's Avatar
Dk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the DremelDk_vr has yet to learn the way of the Dremel
Thats very useful tool but depends on how thick is the surface that he is going to drill.
For example if he is planning to make a hole in 10mm acrylic it won’t work because the steps of this step drill are too small and the drilling may end in ruined detail.
This one is better
Dk_vr is offline   Reply With Quote
Old 2nd May 2012, 14:00   #8
bdigital
bdigital's Avatar
that's the one matey. I have a set of 3 which cater for all sizes
P.m. make.sure you start the hole of slightly with a standard drill bit. The cone ones won't start the hole off.
__________________
Old 2nd May 2012, 14:13   #9
KRONOS
KRONOS's Avatar
Done it this morning,worked perfectly,as it happened the maximum size of the cone drill was just what I needed.
__________________
Old 2nd May 2012, 14:19   #10
bdigital
bdigital's Avatar
Great to hear mate. Great little tool to have
Sent from my GT-I9100 using Tapatalk
__________________
Old 2nd May 2012, 14:39   #11
Big Elf
'Black Noise'
Big Elf's Avatar
Big Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for presidentBig Elf should be considered for president
I've got one of those cone things, I always wondered what it was.
Big Elf is online now   Reply With Quote
Old 2nd May 2012, 14:58   #12
kelvinb
BF3 Username - D0rmarth
kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!kelvinb - it's over 9000!!!!!!!!1!1!1!!!
Apologies for the thread ninja but I was wondering if you could answer a question for me please bdigital as I noticed you have done some epic PSU sleeving
My question was posted here http://forums.bit-tech.net/showthread.php?t=230298
__________________
kelvinb is offline   Reply With Quote
Old 2nd May 2012, 15:09   #13
KRONOS
KRONOS's Avatar
No stopping you now big Elf now you know what is for.LOL.
But seriously I found that its safer if youmake sure that you have a block of wood under where you are drilling. Gives the metal support and lessens the chance of a bend or bow in the metal.
__________________
Old 2nd May 2012, 15:18   #14
Big Elf
'Black Noise'
Big Elf's Avatar
I've found that the only modding I'm good at is sleeving. I can't cut a straight line to save my life.
Old 2nd May 2012, 15:23   #15
KRONOS
KRONOS's Avatar
My straight line cutting is pretty naff also, but I'm sure with practice it would improve,unfortunately do not have the space for large projects or even small for that matter.
__________________
Old 4th May 2012, 12:51   #16
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Hi KRONOS, We use 3/4" Hole saw attachment for the Mnpctech Vandal PC power switches
If drilling into small piece, like this 5.25 bay cover, Best use 3/4" hole saw in conjunction with Drill press, with small piece clamped down. Otherwise a Power Drill will suffice.
mnpctech is offline   Reply With Quote
Old 4th May 2012, 12:59   #17
KRONOS
KRONOS's Avatar
Lack of space prohibits a drill bench but thank you for the comprehensive images. I think I will need to invest in a selection of hole saws.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
