Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 1st May 2012, 13:05   #1
Jhonnie62
What's a Dremel?
Jhonnie62 has yet to learn the way of the Dremel
X58 Motherboard and dual card
Hi all
As i run in a triangle with hardware config I need help
As Mother Board is a x58 t3eH8.
Installed is Win7 64Bit
I try to get 2x Geforce 8400GS paralell to run.
Sofar with one Installed and driver "296.10-desktop-win7-winvista-64bit-english-whql"
works normal.
If i install the second comes follow fun
The bios and so on start up, no errors or what ever
If it becomes to start Windows The fully Pc make a restart.
Anybody has a Idea what can be the reason (Bios , Dirver...)
Thanks for help in forcast
Jhonnie
Jhonnie62 is offline   Reply With Quote
Old 1st May 2012, 21:44   #2
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.GoodBytes is the Cheesecake. Relix smiles down upon them.
Is the second card works?
Try swapping your currently installed GPU, with the other one, and try. Does it work?
Can you please provide us with your FULL system configuration, and power supply model and wattage?
Your motherboard has a 8-pin ATX connector. Did you plug the appropriate 8-pin connector? Or you plugged a 6-pin instead?
Also the Geforce 8400GS does NOT support SLI mode. So you won't get any parallel benefits, other than being able to connect an additional monitor (no games on it).
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 2nd May 2012, 05:06   #3
Jhonnie62
What's a Dremel?
Thanks for your fast replay
Hardware config:
Motherboard: X58 T3eH8
Basic I/O System(BIOS): Phoenix - AwardBIOS v6.00PG
Central Processing Unit(CPU): Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Physical Memory X 3
4GB
4GB
4GB
Hard Disk X 3
Hitachi HDP725050GLA360 ATA Device (465.76GB)
ST3160215AS ATA Device (149.05GB)
(4GB)
Video Card: NVIDIA GeForce 8400GS
Monitor: BenQ G900W (Analog) , BenQ G900W (DVI)
Audio Device X 6
Bluetooth Hands-free Audio
NVIDIA High Definition Audio
Realtek High Definition Audio
Network Adapter
Local Area Connection - Marvell Yukon 88E8052 PCI-E ASF Gigabit Ethernet Controller (Media disconnected)
Local Area Connection 2 - Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller (Media disconnected)
Bluetooth Network Connection - Bluetooth Device (Personal Area Network) (Media disconnected)
Wireless Network Connection 5 - Wi-Fi Wireless LAN USB Adapter #4 (Connected)
Keyboard: USB Input Device
Mouse: Logitech HID-compliant Cordless Mouse
Hardware Score (Base score: 3.3)
Processor (Calculations per second): 6.8
Memory (Memory Operation per second): 7.4
Graphics (Desktop performance for Windows Aero): 3.5
Gaming graphics (3D business and gaming graphics performance): 3.3
Primary hard disk (Disk data transfer rate): 5.9
Power supply is a 550W , connect to the 8 Pin Socket on the board.
As you ask I have test both GPU's. WORKS as Single
I have also test the combination of all 3 PCIE Slots.
Its all time same effect. Boot Menu start Win7 and he do a Restart.
Next I have try to remove Power consumer. Mean CD rom and second HDD.
same effect.
One think i have found in the Manual for Power.
The 1st and the 3rd PCIE Connector has on the top of the Slot also a 4 Pin 5/12V input!
Its is in the manual written if use 2 grafic card better to connect this to the Power supply.
I have to check where it is and where is the cable.
As info: before was a Radeon HD4800 Installes ( was gone in the Nirvana ).
Gaming is not a reason for me . I need the system with 2 VGA and 2 DVI for Development and demos. Thats all.
Jhonnie
Old 2nd May 2012, 08:53   #4
Jhonnie62
What's a Dremel?
Hello
sooo i check little deeper.
if its become to start Windows in grafic mode i get follow Post code:
CF 1 Insufficent DRAM voltage -> Increase DRAM voltage
2 Incompatibe Memory modules -> remove/reinstall DRAM Modules
3 Overclocking Tigth DRAM timing (system unstable) -> load default DRAM speed
4 Bios Issue -> Update Bios
DRAM Speed is on Auto
DRAM Voltage is in 1.56 V
3 Banks , each has 2 DRAM slots. Use all 3 banks with one 4GB Module in the green socket
Kingston 4GB PC3-10600 CL0 240 -Pin Dimm
hmmmmmmmm. looks like funny.
I have also try with Optimize Bios default .
And drive with only one Module 4GB
Jhonnie
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
