Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 1st May 2012, 20:31   #1
Mighty Yoshimi
Motormouth
Mighty Yoshimi's Avatar
Mighty Yoshimi has yet to learn the way of the Dremel
Computer is Finished, Cable management tips required!
So I've finished my computer off now that the second 680GTX finally came. Cable management just isn't my strong point and probably never will be Has anyone got any tips? As you can see it's a dogs breakfast
__________________
CPU = i5 2500K @ 5ghz, RAM = 16GB, GFX = EVGA 680 GTX 2Gb SLI, Sound = Asus D2X Xonar, Cooling = H100
Mighty Yoshimi is offline   Reply With Quote
Old 1st May 2012, 21:04   #2
Mongoose132
Smiles are free-Use 'em :D
Mongoose132's Avatar
Mongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run Crysis
Get extension cables for the CPU 8 pin, PCIe etc, move all the power cables to the back tray (If there's room)
Bit Techs old guide: http://www.bit-tech.net/modding/2005...idying_guide/1
You can buy individually sleeved cables from Corsair and other companies, looks much better than the tangled mass above
__________________
Meow
Quaacck on Steam/BF3/Xbox Laiiveee
Mongoose132 is offline   Reply With Quote
Old 1st May 2012, 21:26   #3
dead beat
Rippin six 4 life
dead beat's Avatar
dead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for president
I don't know if you can with that motherboard, but it's a good idea to space the two cards out, to get better cooling to the top GPU. Also, you only need to use one SLI bridge.
But yes, as Mongoose pointed out, try to run the cables behind the motherboard tray. You will probably need extensions for some of them.
__________________
ASUS ROG Maximus IV Extreme-Z68 | Intel i7 2600K @ 5.1Ghz | 2x EVGA GTX680's SLI (water) | 8GB Corsair Dominator GT RAM @ 1866Mhz | Corsair AX1200 PSU | Crucial M4 256GB SSD | 2 x Samsung Spinpoint F3 HDD's | Dimastech Easy bench Dual V2.5 | Dell 3007 WFP-HC 30" monitor | Custom dual radiator waterloop
Photography gear: Nikon D800 | Nikkor 24-70mm f2.8 | Nikkor 70-200mm f2.8 VRII | Nikkor 35mm F2/D | Nikkor 50mm 1.8D | Nikkor 85mm 1.8G | Nikon TC-14E II | SB-700 Speedlight
dead beat is offline   Reply With Quote
Old 1st May 2012, 21:26   #4
dead beat
Rippin six 4 life
dead beat's Avatar
Double post.
__________________
Old 1st May 2012, 21:34   #5
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!
Root the cables through the grommet next to the psu and for the pcie power connectors, take them out in the grommet next to the gpus and for the 24pin one, take it out next to that connector.
The 8 pin cpu power as it didn't reach around the motherboard on mine, so I just stretched it across as I couldn't be bothered with an extender.
fdbh96 is offline   Reply With Quote
Old 2nd May 2012, 19:34   #6
Mighty Yoshimi
Motormouth
Yeah i did try to run them behind but too short! So I need to get extenders.
Yeah I realise I only need one SLI bridge, but could not get SLI to register at all with The one that came with the motherboard. It seemed a bit dodgy, and had folded back on it's self, So I fitted the orange one from my 7900 gtx SLI build which seemed to work and just didn't take the other one off Unfortunately the only place I could get the 680s in was right beside each other because of lane speeds. Temps still never go over 81 deg c though so not too bad!
I will order some extenders and see if I can work out something clever to do with the fan cables and repost! Thanks
__________________
Old 2nd May 2012, 19:38   #7
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
It looks better than this...
feathers is offline   Reply With Quote
Old 2nd May 2012, 19:53   #8
Mighty Yoshimi
Motormouth
o.O that's a lot of cables! Haha I feel slightly better about mine now!
__________________
Old 2nd May 2012, 20:03   #9
SonnyJim
Multimodder
SonnyJim's Avatar
SonnyJim has yet to learn the way of the Dremel
Could the 8-pin CPU connector reach if the PSU was mounted with the fan-facing down?
__________________
i5 2500K @ 4.4Ghz l Gigabyte Z77X-UD3H l Prolimatech Armageddon l 8GB G-Skill Sniper l SLI GTX 580 x 2 l 256GB Samsung 830 SSD l Enermax Revolution87+ 850 W PSU l CM 690 II Advanced l BenQ G2222HDL l CM Storm Quickfire TK Cherry RED Keyboard l CM Storm Sentinel Advance Mouse
SonnyJim is offline   Reply With Quote
Old 2nd May 2012, 20:04   #10
Cerberus90
petrolhead
Cerberus90's Avatar
Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!Cerberus90 - it's over 9000!!!!!!!!1!1!1!!!
For the love of god feathers, please make that image smaller, took me about 2 minutes for it to fully load!
__________________
Steam: Cerberus90
| Q6600 @ 3.2GHz | Asus P5K Premium | 4GiB Patriot 1000MHz | 256GB Samsung 830 |
| Gigabyte GTX460 @ 830/2000 | Fractal Core 3000 | 24" BenQ G2420HD |
Cerberus90 is online now   Reply With Quote
Old 2nd May 2012, 21:00   #11
feathers
Banned
Sorry dude, I forget some people still on 56k dialup. I only just upgraded last week.
Old 2nd May 2012, 22:04   #12
Cerberus90
petrolhead
Cerberus90's Avatar
I'm on 3Mb, but 3kx4k is still ridiculous for a forum page.
It seemed slower than I would have thought though, maybe it was the hot-linking.
__________________
Steam: Cerberus90
Old 3rd May 2012, 08:01   #13
Williz
Supermodder
Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.Williz is a hoopy frood who really knows where their towel is.
You tend to do cable managment before plugging everything in! Anyway try to route as many ables as possible behind the mobo tray. You may need to get extenders if you want to be ultra fussy about routing (I use a couple of extenders for my GFX cards)
__________________
Silverstone RV-02 White edition / Asus Crosshair V / AMD 1090T Phenom @ 4 GHz
RAM 16Gb G.Skill RipJaws Z 1.5v DDR3 @ 1600 / 2x XFX 6870 Black Editions
1x Crucial M4 64Gb /4 x 1Tb Samsung (Need to check what models)
PSU = Seasonic 760w GOLD rated
Williz is offline   Reply With Quote
Old 4th May 2012, 05:38   #14
Elton
Proud Model M User
Elton's Avatar
Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!
Zip ties. Hide it in the motherboard tray.
__________________
There's good ideas and then there's terribly great ideas.
Elton is offline   Reply With Quote
Old 4th May 2012, 20:54   #15
Jaysonw23
Modder
Jaysonw23 has yet to learn the way of the Dremel
That's what I did
__________________
i7 2600k @4.2 GHz |16 GB Corsair Vengance Ram @1600 MHz | GA-Z68-UD3H-B3 mobo | Corsair H100 Heatsink | EVGA GTX 560ti 1GB | Corsair 750TX PS
Jaysonw23 is offline   Reply With Quote
Old 5th May 2012, 06:22   #16
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Route the cables behind the motherboard tray like has been mentioned already and get some cable extensions because they come in handy.
8 Pin Mobo X1
6 Pin VGA X4
24 Pin Mobo X1
They make the world of difference inside a case, and you could even go for some braided Sata and Sata power lead's aswell if you wanted.
This is what they could help you achieve and what the back side of you pc would like like.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is online now   Reply With Quote
Old 6th May 2012, 07:26   #17
Mighty Yoshimi
Motormouth
Wow thats super tidy management! I need to do that when I find the time! Pictures of the watercooling make me miss my old water cooling loop. I just did away with it because every gfx upgrade costs 70-90 more
Also is that a phobia res? I found my phobia res just leaked out the top a lot.
__________________
Old 6th May 2012, 13:41   #18
MSHunter
I *am* a Dremel
MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!MSHunter - it's over 9000!!!!!!!!1!1!1!!!
Cable-management is a long process of trial and error for me. It takes me under 20 min to build a PC but for great cabling I'll spend over an hour to get it just right.
Edit: Any one know where to get super short SATA power cables? for mATX Cases where the power supply is back to back with the PSU? (like 1-2 cm length.)
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 6th May 2012, 17:20   #19
damien c
Mad FPS Gamer
I normally spend as much time as is needed to keep the insides of the pc as tidy as possible from cables.
The res is a Phobya one, and doesn't leak but probably because I make sure I tighten everything up to within a inch of it's life
__________________
Old 6th May 2012, 18:09   #20
docodine
docodine's Avatar
docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!
A decent level of neatness is possible without buying cable extenders and stuff:
Does your RAM reallly need cooling? Have you tried your rear fan as an intake? Might get better CPU temps that way, and you could remove the RAM cooler possibly.
What case is that?
__________________
Intel i7-3820 @ 4.65GHz | GeForce GTX 480 | 4x4GB Vengeance | Asus Sabertooth X79
Silverstone TJ07 | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet
docodine is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
