#1 |
Creepy Rudolph Discout Sale
P5KC Overclock
Hi guys,
I got a P5KC motherboard with a case that I bought, which I think had a flat bios battery. Replacing the battery and putting in a CPU and cooler managed to get the system to run for a wee bit. But the overclock is set to a rediculously high level, something like 4.5ghz, which is too much for the CPU in it to handle. Is it possible to flash the bios with a slower clock rate? The thermal shut down activates too quickly to change it, so another way to do it would be nice. Cheers Enterobsidian
__________________
"Is a dream a lie if it don't come true? Or is it something worse?" Bruce Springsteen Searching Distant Seas
#2 |
The modding head is firmly back on.
Just go in to the Bios and find the bit that says reset to defaults and everything will go back to stock settings. No need to flash the bios.
#3 |
Not sure if I'll have enough to do to find the resets for it. You wouldn't happen to know what the steps are, would you?
__________________
#4 |
It's big, and it's clever.
Just go into the BIOS and reset it. I'm not sure what you mean by "Not sure if I'll have enough to do to find the resets for it". Press DEL when booting, go into BIOS, and just look for "reset to optimised defaults" or something similar. Save settings... reboot. Seriously... it takes less than a minute. Have you tried downloading a manual for your board?
Just go here and select your OS (although to get a manual you can select any OS you like... it's the same manual)... then download a manual PDF. It will talk you through what you need to do there. If you're struggling to get into and resetting the BIOS for whatever reason, seriously... you don't want to go anywhere near flashing it
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623 EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered MOON | Thecus N3200pro 3TB RAID5
#5 |
Hunting Wabbits since the 80s
I have this exact board and I +1 Pookey's advice in the post above.
Hold down DEL before pressing the power button and it'll POST on default settings ignoring the overclock. Then use the Reset options on the BIOS menu. Its there. I've used it many times
__________________
Datacentre architect and engineer extraordinaire. Maybe. Cheeky referal link for Plus.net - £6.49 introduction offer, free setup available, and they are well good. I use em and recommend to all my friends and family |
#6 |
Ultramodder
Is there no clear cmos header?
__________________
Silverstone PS07B | Maximus V Gene | i7 - 3770K | 8Gb Corsair Vengeance LP DDR3 1600Mhz | H70 | 2*OCZ Vector 3 240Gb | EVGA GTX680SC |Seasonic 660XP2 *Silverstone TJ07|Rampage 3 Extreme | i7 950 @ 4.0 | 12Gb Corsair DDR3 1600mhz | 2*GTX 570 CUII | Akasa 1000W Powermax | 480 rad; all under water |
#7 |
Source Engine's #1 fan!
He said quite clearly that the thermal cutout is activating before he can do anything in the BIOS.
OP: Look for a set of 3 pins with 2 of them connected by a little plastic piece, that is the clear CMOS header. Switch the plastic piece to the other side of the pins for 10 seconds, then put it back. This should reset your BIOS to default settings and remove the overclock.
__________________
The Brass Balls: i7 870 @ 4.2ghz | Cooler: CM Hyper 212+ | 8gb G.Skill Ripjaws DDR3 1600 | GPU: ZOTAC GTX 560 Ti 448-core 1,280mb | Motherboard: MSI P55-GD65 | Case: ThermalTake Element G | ThermalTake 850w PSU | Samsung Spinpoint F3 1tb | Corsair Nova 32gb SSD |
#8 |
Undercooked chicken giver
Something is a miss
a dead cmos battery would mean the board should be at stock settings anyway?
__________________
One//i5 3570K 4.5Ghz//Z68X-UD4-B3//8gb DDR3//EVGA 670 F.T.W.//HX850W//CM690ii//2x128 V200 SSD//Xonar DG// Two//i5 2500K 4.5Ghz//Assrock Z68 Gen3//8gb DDR3//MSI 7970//TX750W//Akasa Mirage//128 Vertex+ SSD//Xonar DG//
#9 |
Ultramodder
The OP only said he thought it was a dead cmos battery. Presumably that wasn't the case, else you would be quite correct.
__________________
#10 |
With that board.... holding DEL whie powering up and keeping it pressed forces defaults. If it's thermal tripping before even THAT can happen it's more serious that an overzealous overclock. If it was just clocked too high, it would fail post, and force defaults anyway... you know... "Overlock failed, hit F1 blah blah..."
Instagib has a great solution we all overlooked... probably because it's SO obvious. clear CMOS header... it's marked CLRTC and it's in the bottom right of the board. http://dlcdnet.asus.com/pub/ASUS/mb/...e3155_p5kc.pdf section 2.2.4 on the diagram. [edit] They recommend removing the battery AND setting the clear CMOS jumpers at the same time.
__________________
#11 |
We all did?
__________________
#12 |
Well.. he was the first to mention it in the thread.
__________________
#13 |
Hi guys,
I haven't had much time to look at the board recently, so I'll try to get it sorted over the weekend. The thermal trip goes pretty quickly, so I'll try the Del key method and see what that returns. If not, then I'll just scrap the board. I suspect the previous owner was running water and a silly high clock multiplier, so I need to drop it down to stop the thermal trip from activating. Cheers Enterobsidian
__________________
| Thread Tools | |
