Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 2nd May 2012, 07:28   #1
alastor
I Mod, Therefore I Own
alastor's Avatar
alastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysisalastor can run Crysis
Call of Duty - Black Ops II
Disappointed, there was so much more they could have done with the black ops cold war storyline. Playing with/as an octogenarian Woods doesn't sound like much fun either.
__________________
Main Rig: C2D E6850 (3.0GHz) : Asus P5E (X38) : 4GB XMS2 PC6400 : HD4870 512MB : Enermax 620W : 2 x Samsung F1 1TB : Antec P182
My Flickr : My XBOX
alastor is offline   Reply With Quote
Old 2nd May 2012, 08:03   #2
SMIFFYDUDE
Mod Master
SMIFFYDUDE's Avatar
SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!SMIFFYDUDE - it's over 9000!!!!!!!!1!1!1!!!
Christ! The graphics look older than the guy in the chair.
__________________
Cooler Master HAF 932 | ASUS Rampage II Extreme | i7 930@4.1 | Corsair H50 | 12GB OCZ PC3-12800 Gold | Palit GTX 560 Ti 2GB | Corsair TX650M | HP LP2475w | Speedlink Medusa NX 5.1 | Logitech MX518 | Logitech G27 | Windows 7 Home Premium 64bit
Steam:
SMIFFY -
World of Tanks: mps85
SMIFFYDUDE is offline   Reply With Quote
Old 2nd May 2012, 08:29   #3
Gunsmith
Maximum Win
Gunsmith's Avatar
Gunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for presidentGunsmith should be considered for president
oh ffs not another one.
__________________
The King of Crysis
// This is currently not used anywhere (David: and I don't see what this would be used for. Our hero is not Jesus).
m_stats.isWalkingOnWater = false;
Gunsmith is offline   Reply With Quote
Old 2nd May 2012, 08:31   #4
samkiller42
Considered for President!! Moi??
samkiller42's Avatar
samkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for presidentsamkiller42 should be considered for president
What did you expect?
Sam
__________________
The Laptop: Dell Vostro 3450, SB i3 2350m, 8GB DDR3, 256GB 830 SSD, Intel 6235 Wifi N/BT 4.0, Dell 5550 3G/GPS
The Server: Phenom 2 x6, 8GB DDR3, 3TB Seagate, 2TB WD Green, 2*1TB Samsung F1
samkiller42 is offline   Reply With Quote
Old 2nd May 2012, 08:32   #5
Mongoose132
Smiles are free-Use 'em :D
Mongoose132's Avatar
Mongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run CrysisMongoose132 can run Crysis
Call of Duty 9: Modern Warfare 3: Black Ops 2: Electric Boogaloo
__________________
Meow
Quaacck on Steam/BF3/Xbox Laiiveee
Mongoose132 is offline   Reply With Quote
Old 2nd May 2012, 08:41   #6
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
Bahahaha! That looks so poor. Genericfest 2012.
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is offline   Reply With Quote
Old 2nd May 2012, 09:18   #7
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.lilgoth89 is the Cheesecake. Relix smiles down upon them.
am i the only one that looked at that and thought
call of duty black ops battlefield 2142 ?? im guessing not :P
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850
lilgoth89 is offline   Reply With Quote
Old 2nd May 2012, 09:20   #8
Ending Credits
Bunned
Ending Credits's Avatar
Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!Ending Credits - it's over 9000!!!!!!!!1!1!1!!!
I agree, looks rubbish.
But at least Treyarch seem slightly innovative, unlike IW.
__________________
Originally Posted by lp1988 View Post
We can conclude that Ending Credits has a niche for ejaculation related quotes.
Ending Credits is offline   Reply With Quote
Old 2nd May 2012, 09:38   #9
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
Just shows what happens when u allow consoles to dominate and hold back gaming.
feathers is offline   Reply With Quote
Old 2nd May 2012, 10:15   #10
Gunsmith
Maximum Win
Gunsmith's Avatar
for once feathers im going to agree with you.
__________________
The King of Crysis
Old 2nd May 2012, 10:29   #11
kingred
Surfacing sucks!
kingred's Avatar
kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!kingred - it's over 9000!!!!!!!!1!1!1!!!
I swore I saw the starship enterprise flying over head.
Here is a list of things which I think of with this videogame "evolution":
  • Stolen ideas from DX:HR
  • Yellow filter (Instead of Brown and Bloom)
  • Same game engine
kingred is offline   Reply With Quote
Old 2nd May 2012, 10:45   #12
Kenny_McCormick
Play hard, go pr0n
Kenny_McCormick's Avatar
Kenny_McCormick has yet to learn the way of the DremelKenny_McCormick has yet to learn the way of the Dremel
I'm so sad... This is getting even worse. But one day they'll realize that the next game must be:
__________________
Sorry for my bad english
Kenny_McCormick is offline   Reply With Quote
Old 2nd May 2012, 10:49   #13
Orca
BF3: 0rcaGT
Orca's Avatar
Orca has yet to learn the way of the DremelOrca has yet to learn the way of the DremelOrca has yet to learn the way of the DremelOrca has yet to learn the way of the DremelOrca has yet to learn the way of the DremelOrca has yet to learn the way of the Dremel
This looks crap, but the COD kids will nonetheless eat it up. Shame really each to their own I guess...
__________________
Workstation: Mac Pro [ 2*3.2Ghz, 16GB, M4 256GB, HD 5770 ] SR80i/Gigaworks T40 II
Gaming Rig: RV02 [ P8P67 Pro, i5-2500k w/H50-1, 850W Black Edition, 8GB XMS3 DDR3, M4 128GB, GTX 570, Xonar Xense ] PC350
Orca is offline   Reply With Quote
Old 2nd May 2012, 11:17   #14
Dwarfer
Banned
Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.Dwarfer is a hoopy frood who really knows where their towel is.
Meh, I've never understood the hyper around COD especially of late. Surely if they want to play a fast paced twitch shooter there are many other 'Free' online games out there such as Alien Arena and Quake Live (which personally is far greater and has a better, mature audience!
Dwarfer is offline   Reply With Quote
Old 2nd May 2012, 11:21   #15
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpit
you forgot the new, and legendary Tribes Ascend.
ah, the memories of Tribes 2..... my first FPS.
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 2nd May 2012, 11:26   #16
Nealieboyee
Packaging Master!
Nealieboyee's Avatar
Nealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for president
Mo' money......
__________________
Bonnie
i3-2100T | H61M-P31 | 4GB DDR3 1333MHz | 60GB OCZ Agility 3 SSD | GTX 260
Nealieboyee is offline   Reply With Quote
Old 2nd May 2012, 11:27   #17
Gunsmith
Maximum Win
Gunsmith's Avatar
o_O
i was there when wolfenstien was first released.
__________________
The King of Crysis
Old 2nd May 2012, 11:37   #18
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
You said mature audience, half the kids that play MW3 etc etc arent mature but kids.....this is another generic game for console. And should not be taken seriously by anyone owning a PC.
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
MrDomRocks is online now   Reply With Quote
Old 2nd May 2012, 11:52   #19
Jedra
Supermodel
Jedra's Avatar
Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.Jedra is a hoopy frood who really knows where their towel is.
Did they miss a game genre in that video?
Do you think if we pay the ransom they will stop?
Thankfully Arma 3 should be out around the same time - I know who's having my money!
__________________
ASUS P6X58D-E - Intel Core i7 930 - Thermaltake FRIO - 12GB Corsair (6x2G CMD12GX3M6A1600C8) - Corsair AX1200 - 2GB Sapphire Radeon HD5970 OC - 256Gb Crucial SSD - X-Fi Titanium Fatal1ty Pro - Silverstone Fortress FT02R-W
Steam Profile ---------- XBL:Jedra ---------- PSN:Jedra ---------- BF3:Jedra7609 & Jedra
Jedra is offline   Reply With Quote
Old 2nd May 2012, 11:55   #20
Dwarfer
Banned
Arma 3 is a simulation not an arcade game, they don't even belong in the same debate lol
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
