#1 |
Pipebender
SR2 Build
I have been lusting after an SR-2 rig for some time and now i am in the position to get one.
After much consideration and head scratching,i went for the Little Devil V8 inverted HPTX case. I realize that this build may seem disjointed,it has been running for a while on other forums.. Sorry about that..anyway... ![]() ![]() ![]() I was VERY tempted by the caselabs MH10 but the shipping costs and VAT crippled that idea...£700 for a case is unacceptable to me!! Hardware: Board: SR-2 ,MIPS mobo block with VRM block and 2 Watercool HK 3's (black) CPU: x5650 Hexacores Ram:12-24Gb Corsair or G Skill....not decided yet GPU: 3x 7950...this really depends on the availability of reference layout cards Storage: 2x Force GT 120Gb SSD (1 for OS,1 for games and everything else) 1x 2tb HDD for storage PSU: 1200w Silent Pro,maybe Strider 1500w ![]() ![]() ![]() ![]() ![]() This rig will be dual loop and 24v,the reasoning behind this is the restrictive rads will make a D5 cry if left on its own to do the work! As usual SpecialTech is my vendor of choice for this....anyway TO THE PR0N!! Cooling: 2x 360 AMS rads with D5 1x 480 AMS Dualcircuit rad 2x Bitspower 200mm Res (depending on how much room the PSU takes up) 2x Watercool HK blocks in Black 1x MIPS SR-2 mobo block 2x 24v D5 pumps 1x Koolance 24v twin pump controller Koolance Copper pipe fittings ![]() ![]() ![]() ![]() ![]() ![]() ![]() Some components may change but this is how i see it coming together. A little bit of progress... Double wires FTL. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Off come the stock EVGA plates for the cut down version (supplied,EVGA are thoughtful like that) ![]() Watercool back plates.. ![]() Mounting hardware.. ![]() Right then..... Whats this? ![]() Magoo also wants to know what it is. ![]() ![]() ![]() ![]() ![]() The SR-2 is a huge board but is tiny in there ![]() ![]() ![]() ![]() Chrome plated.....yum! PSU done,just the molex and sata to do... ![]() ![]() Also swapped the fan panel around so Silent Pro looks the right way up... Ok,first hitch of the day,looking at the clearance of the PSU to the AMS rad and have discovered they wont fit. 146mm wide rad=PITA! ![]() So the Dual psu extender is required after all. ![]() Also,the bloody 24 pin is too short,24 pin extender GO! My doubts about the Chrome flaking off the tube was put to rest.... ![]() Today i had a look at the bending required,no sniggering at the back please. You may have been wondering what the red tape was for? it is the 0 line for the bend,i can work out the length required to get 2 90 bends to meet to set out dimensions ![]() To get this.. ![]() Got some push fit fittings to make the test fitting. ![]() ![]() ![]() I may even keep using these fittings,they look ok and are 1/3rd the price of the koolance fittings. Downside is i dont trust push fit fully,not like a proper compression fitting. The tails have not been cut yet,i want the piping at the same level. So,i need to get the Ram in and see what i can chop off... Or i could use 45's...
#2 |
What's a Dremel?
Wow. How did you do the bending? That looks real slick. I prefer the 90's myself, but they both look amazing. Nice work!
#3 |
Pipebender
A set of 10mm benders,about £20 for a good set of rothenberger ones,cheap ones have poorly aligned guides.
#4 |
Pipebender
These are the fans i have chosen,in the 2350 variant....must have....must have.....must have..
![]() Also in 140 for the case!
#5 |
Hypermodder
Looks awesome, Ive got an obvious soft spot for SR-2's so Im watching this intently!
__________________
Project in progress: Bitfenix Prodigy Stacker
Interior Des(k)ign | BitPac | Bitfenix Prodigy Stacker Modding is addictive!! |
#6 |
Multimodder
This looks very nice
__________________
The Beast: Silverstone PS-07 | i7 970 @4.2 | Rampage Gene II | 12GB Vengeance RAM | H80 | GTX 560-Ti 448 |
#7 |
Side bewb.
This build got me wet!!
__________________
Bewbs. |
#8 |
Master Modder
Love hardware builds like this. Now if my wife would only let me spend dough like that on a new rig!
__________________
JAllen Labs GT1000- 3770K, 32GB Dominators, MSI 570GTX, Samsung 840 Pro 256GB SSD, 4 drive RAID 0 and 3TB storage in a Silverstone Fortress GT03, Logitech G9X Gaming mouse on Razer eXact Mat, Custom built Fostex studio monitors, Yamaha amp, Onkyo Tuner and Garrad turn table. |
#9 |
I Endure
Don't worry about the push fits, they're far more secure than any compression. If they weren't, Legris stuff wouldn't be used in just about every machine we ran at JVC. I'm using them for the same thing in my build. Steel tubing there too.
#10 | |
Pipebender
Tubing is Copper,plated in chrome,easier to bend and easier to cut with a 10mm autoslice. Thanks Guys for your comments so far,i appreciate it. Is it bad to be looking to another build already? Got a few ltrs of Novac 649 for some immersion action next year.... |
#11 |
The German
It's so shiny
This looks like it will be fun. Could you please tell me how those fans perform, once you have managed to test them a little. I saw them the other day and thought I might give them a go
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#12 | |
Pipebender
Will post results. |
#13 |
Multimodder
Yeah SR-2 this mobo is like a legend !!! Ill keep an eye on you
Good Start bro.
#14 | |
Pipebender
Have excuses ready. She asked me why i needed 1200w power supply. The answer? I will not be using it at full capacity,its for efficiency . ![]() Happy days! |
#15 |
Fenrir The Wolf
Awesome!!!!
#16 |
Supermodder
those corsair fans :OOOOOOOOOOOOOO
__________________
Main rig: CPU: Phenom II 955 @ 4ghz cooled with a H50GPU: HD 5850 Powercolor (Bricked) awaiting new card to hold me out till AugustMotherboard: Gigabyte 890xA-ud3 RAM: 4gb ddr3 1600 OCZ @1600 |
#17 |
↓ Don't trust that face!
I've seen your build already. I came to see Mr. Magoo again.
__________________
#18 |
Making You Feel Old Since 2010
Case, chrome pipe and everything else made me cream myself.
![]() I'm just not keen on the sleeving.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#19 |
Never stuck with stock@Hotmods.net
I'm rather impressed how that LD Cooling case totally dwarfs the SR-2.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#20 |
Pipebender
| Thread Tools | |
| View Mode | |
