#261 |
Pipebender
The best of Multiplay i47
![]() ![]() ![]() Sharing stand space with Coolmiester was great,class builds and mine didnt look too much out of place... Got good feed back on my build,which was really good and encouraging! |
#262 |
Professional Sleever & Modder
Is there any buildlog on the blue/white CosmosII build ?
All the builds looked just stunning !
#263 |
Keep calm & mod on. =)
Was that a LAN compo B?, congrats.
![]() ![]() Crazy beast rigs.
#264 |
Pipebender
#265 |
Pipebender
I just got sent a pic of my rig at i47,a rare shot of the sleeping beast...
And a nice mention on [H] http://www.hardocp.com/news/2012/12/...r_case_mod_day |
#266 |
Car lover and Speed Junkie
i can hear the dinos roaring out of the case now!
#267 |
Pipebender
Working on the OC now..
Stock GPU's,OC'd X5650s ![]() Still got a lot more in the tank too..... ![]() 6th place for now.... |
#268 |
Pipebender
I have decided to take this rig a bit further...
Im going to be clearing the drive bays and using one of these... ![]() http://www.carcomputer.co.uk/index.p...-frame-monitor Hooked up to an Aquaero with Aquaero controlled D5's and fans.... I tend to do this,build something then pick holes in the stuff i dont like till i get to what i want |
#269 |
Multimodder
An incredible, insane build mate, congratulations. If money was no object I’d like to have a go at something like this and would DEFINITELY use the LD-V8 range. Sadly, money isn’t no object. LOL!
#270 | |
Pipebender
So the Aquaero plan starts to come together.... ![]() ![]() Thanks Specialtech for this bit of kit! Slowly getting all the bits i need to start modding this case properly. |
#271 |
God i wish i could afford that... mobo is cheap but the processors are what kill your wallet..... course budget just makes it a challenge!
#272 |
Never stuck with stock@Hotmods.net
Got the very same Aquaero model, only with the waterblock installed. I hope it's as good as I plan for it to be.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#273 |
Pipebender
#274 |
What's a Dremel?
Still jealous of it.
#275 |
Pipebender
Dont be,this board can be hormonal sometimes,owning a SR-2 isnt all plain sailing.
And Tri Sli is a PITA..... On the plus side,she is a brute and looks great in there! ![]() Hopefully the screen is coming next week so ,once Arctic Water is finished, I can crack on with this. |
#276 |
Steering a Boat in Holland
Nice. Can't wait to see the updates...!
__________________
"The Quiet Rig": Maximus IV Extreme Z - i7 2600K @ 4.5GHz - Frio - 8Gb Ballistix Sport @ 1600 - Sapphire 7970 @ 1150/1550 - M4 256Gb - LG Blu-Ray - Seasonic G Series 650W - Fractal Design R4 - Asus VS247H - Logitech MX5000 - Digidesign 003 - KRK Rokit 5 G2s
#277 |
Pipebender
More goodies have arrived but this is all im showing you till the rest of it arrives....
![]() Magoo approves this post. |
#278 |
Pipebender
TO THE PRON!!
A nice stack of Aquacomputer lovelyness ![]() Some Alphacool BP clone pass thru's....damn sight cheaper! ![]() ![]() If you want your Aquaero to run multiple fans then this is a must,Aquaero Waterblock. Tidy machining as you expect. ![]() Aqualis res,pump mount version. ![]() Pump top to match...D5 version. ![]() I did say i was going dual loop right? ![]() Those pump rings are going red for sure! ![]() So....I have my 12/10 E22 ultraclear but im waiting for c47's to tidy it all up and im swapping out the blocks for MIPS Iceforce CPU blocks. Im running a lot of the tube under the midplate and using pass-thrus,im bending all the mobo tubing tho,expect a detailed method and plans for the jigs and formers that i will be using shortly. Last edited by B NEGATIVE; 1st May 2013 at 19:05. |
#279 |
Tech-Kid
Dem goodies :I
#280 |
Holy mother of sweetness.
Would you by any chance have been inspired by Seanimus' build over at overclock.net?
__________________
| Thread Tools | |
| View Mode | |
