#21 |
↓ Don't trust that face!
Pray to God he never learned the 'toy poodle takedown.'
__________________
#22 |
Professional Sleever & Modder
please dont use those ugly fitting for the pipes !
#23 |
Pipebender
Been a bit of a change to my rads choices,seeing as the AMS is TOO damn big,i am using XSPC RX 480s instead....
#24 |
Pipebender
Some of the loop which came today..
![]() 24v capable D5's ![]() Bitspower Res..why would you buy anything else?? ![]() Some of the fittings.. ![]() Dual 24v pump controller ![]() 2 480 XSPC rads... ![]() Special mention and thanks to Coolmiester at XSPC for 1 of the 480 rads and to Steve at Specialtech for getting in AMS rads in especially for me that i cant use...i know he spent a good few hours trying to source these for me. ![]() ![]() Still waiting for one more 480 rad and 2 Koolance D5 tops then i can get going on the loop. Ordered more 10mm Copper pipe today so i can get on with the pipework. Last edited by B NEGATIVE; 21st May 2012 at 09:47. |
#25 |
Pipebender
I have 180 bends on the loop which counts out using the double o-ring fitting (phobya/BP sli fitting),these are push fit with a lock ring,much more secure and reliable. Looks,in this instance,are secondary to performance.
#26 |
Thinking about which mod to do 1st.
i'd not come across the "single use Koolance Pipe fittings" before that you are using. +rep for bringing them to my attention!
#27 | |
Pipebender
You can get them in the UK here. http://specialtech.co.uk/spshop/cust...pid-15374.html |
#28 | |
Never stuck with stock@Hotmods.net
Also, it's slightly refreshing to see somebody NOT using Bitspower, EK or Feser fittings.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#29 |
No power, no glory
Can't wait to see this finished! keep up the work
#30 |
Pipebender
Snug as a bug...
![]() ![]() You can see why the AMS rads that i wanted wouldnt fit.... |
#31 |
Pipebender
Spider at SpecialTech sent me his old Ram....for free no less!
Many thanks to the miserable old git,i really appreciate it. ![]()
#32 |
Pipebender
Moar pipe bending today,got the spacers i forgot to order!
ST got my stuff out fast as usual. ![]() ![]() ![]() Taking shape now... |
#33 |
Do you even mod, bro?
Love the build, except for those cables! Yuck!
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#34 |
Supermodder
Nice start man! I really like that you will use metal pipes that will make it a very unique thing!
I prefer the 90° bends over the 45° bends btw, 90° just looks better
#35 |
Multimodder
Oooh! Those pipes are sooo cool! Like the look of the loop. mod on!
__________________
sorry for my English |
#36 |
Pipebender
Delivery turned up with goodies...
![]() This PSU screams Quality,very nice choice i think...plus the cables look easy to braid with no double wires! Result! ![]() ![]() ![]() a free fan you say? some enermax 'stadium light' job... ![]() Specs for the unit.. ![]() Dominator GT's and a Force GT SSD.. ![]() I wont be using the airflow fans tho.. ![]() ![]() Looks mint dont it. ![]() ![]() ![]() So....time for some work! |
#37 |
The German
That piping just looks so nice
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#38 |
I am just sleeving one of those for a custumer ![]() https://www.facebook.com/media/set/?...9463545&type=3 |
#39 |
Question: What are the compression rings on those fittings made of? -HDPE or brass?
__________________
#40 |
Multimodder
Not BAD
SR-2 King of PC
| Thread Tools | |
| View Mode | |
