#161 | |
Pipebender
http://www.aquatuning.co.uk/product_...ck-nickel.html For now anyway......
#162 |
Pipebender
I am letting the Pics do the talking here...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Loop finished! |
#163 |
Do you even mod, bro?
OMG!
Sometimes I wish you could swear on the BT forums.
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#164 |
Moderate Modder
if that beast doesnt power the next Luna Mission I'll be on to NASA asking why
Q. The piping, do you solder to the compression fittings or do they seal without ? or is it a hardware plumbing dept search, fittings with 1/4thread I would have to look for ?
__________________
Watering down PC's since 2009.... |
#165 |
Pipebender
I used Aquatuning cheap and cheerful 10mm OD push fits....they are not bad at 1.70 a pop.
#166 |
Multimodder
Wow, this is one sexy build!
#167 |
The German
It looks oh so good
awesome work
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#168 |
Pipebender
Leak test underway,not a drop so far!
#169 |
Moderate Modder
Thanks. Been meaning to ask that question for ages
__________________
#170 |
I think we can make that fit
Beautiful job I am looking forward to seeing this beast power up.
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses |
#171 |
Folding@Home CC Captain 2010/11/12
Schweeeeeeeet
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ | |
#172 |
Pipebender
#173 |
Minimodder
Just lurving this one- so much I am just in the process of redoing my dual loop TJ07 build
What are you going to do for the GPU power connectors? I would love to see a bridge of sometype a bit like a SLI block- would totally reek of awesomeness! |
#174 |
What's a Dremel?
Thanks for the pipe guide. Will be handy. I have started to get the bits together. Still trying to refine my idea's. No fix idea yet.
The build looks amazing. |
#175 | |
Pipebender
Stay tuned. |
#176 |
Just out of curiosity does your PSU have enough power on 1 rail to power all those beast or are you going to pull from multiple rails?
__________________
#177 |
Pipebender
#178 |
Pipebender
Disaster! one of the pumps has literally popped out of the top on my SR2!! Seems Koolance struggle to machine two threads that match,the pump shroud wiggles in the threads and just lets go!
Thanks to ninja reactions and the 3 cups of coffee earlier i whipped out the power before it flooded everything,thank christ i put the pumps in the rad bay underneath or this could of got expensive. identical issue. http://www.xtremesystems.org/forums/...e-D5-top-issue Koolance is now on my poop list. Cant even RMA them as i have painted the mounts and shroud,thankfully Specialtech just offered to sponsor me 2 of the new rev 2 model. This is why ST are the only guys to go with for watercooling gear. Not the best morning,i was looking forward to some 1440p BF3......... SpecialTech to the rescue!! ![]() ![]() ![]() You can clearly see the difference in the pump mounting compared to the rev 1. ![]() The new top just bolts in the traditional manner rather than the screw in shroud method. The tops are different dimensions tho so im going to have to ditch the copper between the pump and res and go with a bit of black tube instead....otherwise it means re doing the res mount and generally more trouble than its worth. Thanks again to Specialtech,who came thru for me in a very tight situation. |
#179 |
Sorry to hear about the pumps, but at lease you didn't loose any of your rig. Congratz on getting someone to sponsor you for the pumps. I know you have a lot tied up in the rig already. Now get the pumps back in and start testing again.
__________________
#180 | |
Pipebender
A little 1hr leak test and i will fire her up |
| Thread Tools | |
| View Mode | |
