#1 |
May contain traces of sanity.
Project Sinister Colossus: Phase One [3/5/12]
Okay before I start I will state right away that this is not going to be a particularly exciting build log initially, I'm using this as a learning project. Ideas/suggestions and helpful constructive criticism are more than welcome
![]() This project will likely be a long one, with several phases; Phase one will be the initial setup, experimentation and operation. Phase two will be implementing the lessons learnt from phase one, improving the look/feel of the case and upgrading some of the hardware and cooling. Phase three will be, hopefully, implementing custom fabricated parts to further optimize. So here's the spec: Case: BitFenix Colossus (Black) PSU: Corsair HX850W Motherboard: Asus Z77 SaberTooth CPU: Intel I5 3570K Ivybridge GFX: EVGA Nvidia GTX680 Superclocked Signature Edition Sound: Asus Xonar DX2 SSD: Crucial M4 128GB HDD: Seagate Barracuda Optical: Samsung BluRay Custom Cooling: CPU waterblock: Aquacomputer Cuplex kryos Delrin Radiator: Phobya G changer 240 Pump: Laing DDC Pro (With Alphacool sound isolation box and top) Res: Alphacool Bayres Fans: Scythe Gentle Typhoon 1850 Controlled by an Aquacomputer Aquaero 5 ![]() So here we go with Phase One. Something essential for all mod projects... ![]() Started with braiding the cables, trying a few different styles. I'm not a fan of each wire having it's own braiding which seems to be a strange fad at the moment... I thought the idea was to make cables more manageable and tidy.... and the current fad seems anything but. [/rant] In the case where it needs to split at the end, suggestions on which looks better (top or middle)? ![]() Some initial cable routing. To help work out where everything goes, I found a cheap motherboard on ebay, was an absolute bargain. Seems legit? ![]() Test fitting of the radiator ![]() And an early look at the top front. ![]() A look at my pump/top mid assembly. ![]() And the silencing box. ![]() SO MANY SENSORS. Not sure how I can tidy this. Suggestions? ![]() ![]() As you know the Colossus has some very unique styling, but opaque side panels. You can get a windowed side panel but that means sacrificing some lights. Fortunately I had a spare side panel so I carefully extracted the lights and attached as so (test fitting) to the inside of the window panel. Not sure how to properly do this but will update on this when I have a better solution. And that's it so far. More later
#2 |
(At current I think this thread is better moved to the Hardware Section rather than the project logs given how mod-light this project is so far
Would apprieciate if a mod could move it )Anyway. ![]() I HAVE BEEN WAITING FOR THIS SO LONG. FINALLY HAVE ONE ![]() ![]() Here it is installed with the waterblock. ![]() Connected everything up, gave it a leak test... and success! Everything works!![]() WE HAVE BIOS! Wooo. Temperature isn't insane either so here's hoping I put the block on right. Just need to... tidy up the mess I've made building this thing now... More to come soon! |
| Tags |
| bitfenix, colossus, watercooling |
| Thread Tools | |
| View Mode | |
