Thread Tools | View Mode |
#1 |
Modder
A mITX build for my mom (19:th October, Soon finished, some overall images)
Some of you may remember me from L3p L4n build, i designed the Mars II waterblock. Anyways, now I'm making a mITX build for my mom.
I'm planning to use a ASRock Z77E-ITX motherboard with a low power Sandy or Ivy CPU, a HD 7750 GPU (Or NVIDIA similarity). This will be a scratch build (pic below) ![]() Okay, so let's begin!(I actually started some weeks ago but created the thread now) ![]() Got myself a package! It is a 150w Pico-PSU and a 120W AC-DC converter.![]() And some connectors and buttons too. ![]() ![]() So the first thing i did was to exchange some of the connectors on the brand new PSU... ![]() I like the result! (More connectors will be exchanged later.) ![]() And a package from Nils! ![]() ![]() ![]() So i got a Slim DVD without faceplate from eBay... ![]() ...what i didn't know was that it came without a eject button. ![]() ![]() I need to fix that, and i think the cables to the button should be soldered there somewhere. Need to pull out my DMM and measure some spots so i can find the solder points for the eject button. ![]() And i can probably solder some LEDs there. ![]() ![]() Got a Slimline SATA cable too! ![]() ![]() But i can't stand the color so let's exchange the cables to black ones! ![]() ![]() Here is the housing. ![]() And all the pins and stuff. Will hopefully solder new cables this weekend. :thumbsup: ![]() Cleaned the caps! Need to buy black paint so i can paint the connector. ![]() ![]() ![]() Hope you like it!
#2 |
www.^.nl
I will be his first follower!
![]() This guy rocks with his cam
__________________
Preparing: Raz3r D3sk Finished : L3p Parvum - Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#3 |
The Keeper of History
Good start. I watch how you will do SATA cable.
john
__________________
My deepest gratitude to this community.
#4 |
Beyond Complexity Lies Simplicity
Lovely start !
__________________
Current Build : BORG COSMOS II Current build : 2001 - A Case Modyssey Finished build : IMPERIAL AT-AT Finished Build : USS EURISKO - Intrepid Mark II Class www.asphiax.wordpress.com |
#5 |
Modder
#6 |
Making You Feel Old Since 2010
Great start, loving this!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#7 |
Professional Sleever & Modder
why just not but a connector from stefan or nils ?
Subbed and +rep
#8 |
Modder
Thanks guys!
Kosovar: Because it wont fit. The pico 24-pin is smaller than a regular 24-pin.
#9 |
What's a Dremel?
I think it'll be a great gift =) Unique in the world. Besides, great pics like always and when I look at how you dissassemble everything like you're playing with a kid's toy...it's just great. Awesome and keep going!! Will be following this closely!
#10 |
Supermodder
good start, im following! =)
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#11 | |
, go and buy some black Plastic Dye and boil the connector into the dye 2-5 minutes
#12 |
01110001 01110101 01100001 01100011
Sub'd
Looking forward to this
__________________
Mod of the Month Nominee February 2010: A380 Mod Sponsors: www.mnpctech.com, FedTech In Progress: The Anti-Mac Sponsors: www.mnpctech.com, BOXX NVIDIA ION Contest Spider PC Engineer at RedHarbinger:http://www.facebook.com/redharbingerinc |
#13 |
Never stuck with stock@Hotmods.net
Suuuubbed - this can't become anything but good.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#14 |
Minimodder
very interesting !
love mini itx the drawing is made with solidworks ? |
#15 |
modeteer
paint will chip quickly mate, you might trying a RIT dye or something or (if you can find it) there is a product by Plasti-kote called Ultra Vinyl Dye that is fantastic. I've used it before but it can be hard to find. The product softens the plastic and causes the material to open up (like pores on your skin) and it absorbs the color from the product.
#16 |
Modder
Thanks guys! Love the positive feedback!
![]() Sixfoot: Kosovar showed a site where i can buy dye so that is ordered. I think it was called iDye or similair. ![]() Okay, so small update before i go to bed. ![]() The slimline SATA cable is done! Turned out OK, could be better tho. The molex part will be removed, that one is just for testing. ![]() Soldered. ![]() Glue. ![]() Finished. As i said, it is only okay. ![]() ![]() ![]()
#17 |
I think it looks fine, but when you HAD the plug opened, why didn't you expand the holes around the cables a bit and then concealed the ends of the sleeving INSIDE the plug? In that way you could have eliminated the need for heat shrink for that end of the cable.
But you're perhaps not going to use sleeving at all?
__________________
#18 |
Modder
I will sleeve some of the things but not this because it won't be seen anyways.
#19 |
Modder
Ontopic: Thumbs up for the commitment and the hard work. I would never go about soldering my slimline SATA cable
![]() Offtopic: Do you mind if you share with me the thought process behind choosing a mITX for your mom? To clarify: I was thinking that my parents need a new PC, instead of the bulky 775 ATX machine they have now. They have pretty basic needs: firefox+word+skype, not even watching HD movies. And I was wondering between mITX and laptop or netop. And I started leaning towards a laptop. So now you see. It'd be nice to hear someone else. |
#20 |
Modder
Thanks mate!
![]() How about a i5-3570K for your build? |
| Tags |
| mitx |
| Thread Tools | |
| View Mode | |
