#1 |
Hey What Who
dual display 1 x tn panel
How cool is this Microsoft Research
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands |
#2 |
GIFted
#3 |
Source Engine's #1 fan!
We have a 46" autostereo monitor that works the same way for work. It's terrible for 3D. Absolutely terrible. For this purpose, unless you sit EXACTLY in the right spot, you're going to get image leaking and distortion and color washout, nay, color destruction. 3D without glasses will come along, but it won't be using this technology. And for this purpose, the Sony Playstation 2 player screen is better than this tech, as you don't get your colors wiped out if you move 2 inches and you can sit next to the other player.
__________________
The Brass Balls: i7 870 @ 4.2ghz | Cooler: CM Hyper 212+ | 8gb G.Skill Ripjaws DDR3 1600 | GPU: ZOTAC GTX 560 Ti 448-core 1,280mb | Motherboard: MSI P55-GD65 | Case: ThermalTake Element G | ThermalTake 850w PSU | Samsung Spinpoint F3 1tb | Corsair Nova 32gb SSD |
#4 |
How many wifi's does it have?
Doesn't some car have this already? One for the driver and the other for the passenger.
Don't get me wrong, it's really cool, but on a desktop environment... but now, instead of having a nice image, you have 2 really crummy ones.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#5 |
Hey What Who
the car one is based on a patented parallax barrier, this is based purely on the way TN Panels work
__________________
#6 |
Multimodder
While it does look nice - I agree a single crisp image is prob better than 2 crap ones - I imagine viewing angles are limited as well
__________________
"Overkill" is just another way of saying "future-proofing" |
#7 |
I ate Bhindi Bhaji.
The Range rover has it. Film on one side sat nav on the other.
| Thread Tools | |
