Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th May 2012, 11:43   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Micron announces its first DDR4 modules
Micron has announced sampling of its first DDR4 modules
http://www.bit-tech.net/news/hardwar.../micron-ddr4/1
brumgrunt is offline   Reply With Quote
Old 8th May 2012, 13:21   #2
SpAceman
Supermodder
SpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpit
I hope early adopters aren't going to have to deal with those stupid motherboards with support for multiple memory types. I hated those DDR2/DDR3 combo boards.
__________________
i7 4770K | Asus Z87-Pro | 16GB Gskill DDR3-1866 | EVGA GTX 760
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | Corsair TX750
Dell U2412M | LG W2253TQ | Ducky DK9008 Pro PBT MX Cherry Greens | Naos 7000 | Logitech X-540 5.1 | Logitech G930
SpAceman is offline   Reply With Quote
Old 8th May 2012, 14:11   #3
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
We'll have a clean break in terms of memory support since the memory controllers are integrated into CPUs. From current rumours, Haswell will still be DDR3, but the next tock Skylake will support DDR4. It still has some way to go before coming to the market in significant numbers.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 8th May 2012, 15:31   #4
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
Why? Like sure in the long run they're a horrible choice, but they're still convenient. Much like those AMD motherboard that supported either 754 or 939.
Regardless, I could have sworn I read that DDR4 was going to be skipped and companies were going to move straight to DDR5. We have the technology to do that and its GOING to happen, so why not just skip it? Either way, I'm beginning to feel more and more uncomfortable about RAM these days because latencies are getting to be hideously bad. I realize that isn't as important today as it was several years ago, but I feel like there's a point where there'll be something like DDR8 and it turns out to be slower than previous generations, even though it'd be theoretically much faster speed.
What I'd personally prefer to see is on desktops, ditch these large DIMMs for the smaller SO-DIMMs, with more memory channels. SO-DIMMs generally have the same capacity limits as DIMMs yet they're so much smaller, so you could fit so many more of them on the same motherboard. So think of it like this:
8 DDR3 2GB SO-DIMMs in quad-channel
OR
4 DDR4 4GB SO-DIMMs in dual-channel
I personally feel the first setup would heavily outperform the 2nd, and it'd probably be cheaper.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 8th May 2012, 18:22   #5
r3loaded
Ultramodder
r3loaded's Avatar
You were probably thinking of GDDR4/5 memory, which are both based on DDR3 but with low-level modifications to suit the parallel, high-bandwidth nature of GPUs. Only a few Radeon 2000/3000 series cards used GDDR4 iirc.
__________________
Old 8th May 2012, 19:50   #6
yougotkicked
A.K.A. YGKtech
yougotkicked's Avatar
yougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremel
@ schmidtbag: I dont' know about converting to SO-DIMMs, but I definitely like the idea of moving to a quad-channel standard. I could imagine a design standard where full-size DIMMs are still used, but each module has two discrete memory banks communicating over separate channels. this way a single physical module would communicate at dual channel speeds, so the basic 2 module arrangement would deliver quad-channel bandwidth. This would theoretically be easier than shifting to SO-DIMMs (mobo makers would not have to change as much, and each module would be able to use the same power circuitry) while opening up quad-channel memory performance to SFF systems. With the shift to 30nm parts it should be more than possible to fit all the needed parts onto a single DIMM (my samsung 30nm DDR3 DIMMs are ~1/2 standard height once you ignore the contact plates for both).
__________________
Intel I5 2500K @ 4.5Ghz on air ::::: 16GB DDR3 @ 1866mhz 9-9-9-27-1T
Asus P8Z68-V LX ::::: NVIDIA GTX 680
128 GB intel SSD, 1 TB Samsung Spinpoint F3 HDD, 2x 1 TB WD drives in Raid 1
2x 2 TB WD drives in Raid 1, 160 GB Hitachi Deskstar HDD
yougotkicked is offline   Reply With Quote
Old 8th May 2012, 20:06   #7
schmidtbag
Ultramodder
Actually I like your idea a lot better haha, but I don't see how switching to SO-DIMMs would be any more difficult than switching from DDR3 to DDR4. I would think that although the sockets are physically the same size and probably serve similar purposes, I doubt they work similarly electronically.
Old 8th May 2012, 20:26   #8
mo2580
Minimodder
mo2580's Avatar
mo2580 has yet to learn the way of the Dremel
these amd motherboards did they have 2 seperate sockets or was it 1 socket and both processors could be installed on the same socket?
mo2580 is offline   Reply With Quote
Old 8th May 2012, 20:35   #9
schmidtbag
Ultramodder
They usually had 1 socket by default, typically 754, and since there wasn't room to fit a 2nd socket, they had a custom-made slot (just above the AGP/PCI-e slot) that looked much like an AGP slot where you could buy this external card that allowed you to mount a socket 939 CPU. Then you had a bunch of jumpers to change so the mobo would know which CPU socket to use. I know asrock was one of the companies that did this but maybe another one did. These motherboards were surprisingly cheap too. You can find these boards on ebay, but I've never seen where you can get the 939 expansion card. I never bothered getting one of these.
Old 9th May 2012, 08:58   #10
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
I missed those entirely...and now I kinda want one just because it's bizarre. But only if I could find the 939 card, too.
And is it just me, or has the DDR4 spec taken freakin forever?
fluxtatic is offline   Reply With Quote
Old 9th May 2012, 18:50   #11
schmidtbag
Ultramodder
Yup they're very bizarre, especially if you see the 939 card in use.
I feel like DDR2 survived longer than DDR4, there's still new-ish laptops out there that use it. But anyways, DDR4 is kinda pointless, I doubt there will be a significant performance improvement when using it.
Old 9th May 2012, 23:05   #12
SpAceman
Supermodder
Because redundant RAM slots make me angry. When I was looking for a decent spec DDR2 motherboard (back when DDR3 was new and crazy expensive) it seemed like every single board I came across with specs and pricing I liked had support for both types and therefore redundant slots either way. Lucky for me I managed to get myself the wonderful board in my sig.
__________________
Old 9th May 2012, 23:30   #13
yougotkicked
A.K.A. YGKtech
I was thinking mostly in terms of Manufacturers having to change board layouts. Even though the circuitry probably changes substantially gen to gen, Manufacturers are used to working with the general dimensions and orientation of full size DIMMs. Switching standards would require them to learn how to fit SO-DIMM slots on their boards, which could require making a new standard connector for SO-DIMMs (I don't think there's a vertical oriented slot made for them, heat spreaders wouldn't fit the slanted mount they use for laptops, and RAM makers have sternly refused to stop using spreaders despite nobody who knows anything wanting them).
If the 30nm DDR3 parts I use are anything to go by, the die shrink should allow for speeds upwards of 2500Mhz with ease. We won't know until the DDR4 standard is official, but we could see a pretty major boost in transfer speeds. Hopefully this standard will include more overhead than DDR3 did, I don't want a precedent to be set where we get a new RAM standard every 1.5 generations of CPU architecture, makes things more complicated than they need to be.
__________________
Old 21st May 2012, 09:21   #14
DDR4standard
What's a Dremel?
DDR4standard has yet to learn the way of the Dremel
LRDIMMs at end-of-life and DDR4 copying NLST IP
The HP Gen8 DL360p and DL380p have support for Netlist (NLST) HyperCloud memory.
This is the memory DDR4 is going to copy (license).
LRDIMMs are already copying it - but have implemented it with asymmetrical lines - leading to latency issues - and inability to deliver 1333MHz at 3 DPC.
With HP Smart Memory HyperCloud - you can get 1333MHz at 3 DPC at 24DIMMs on the 2-processor DL360p and DL380p servers.
LRDIMM buffer chipsets are only made by Inphi (IDTI and Texas Instruments have delayed and backed off respectively). Inphi was the most aggressive against Netlist (NLST) - however they have recently failed in their challenge of NLST IP in patent reexaminations at the USPTO - NLST IP '537 and '274 have been reaffirmed by the USPTO with ALL claims intact - which reflects poorly on Inphi in NLST vs. Inphi.
LRDIMMs thus face legal risk (of possible recall ?).
DDR4 also copies NLST IP - but have chosen to also copy the symmetrical lines and distributed buffer approach.
JEDEC should eventually license NLST IP for DDR4 prior to finalization.
DDR4standard is offline   Reply With Quote
Old 21st May 2012, 09:27   #15
DDR4standard
What's a Dremel?
Old 21st May 2012, 10:01   #16
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
Originally Posted by DDR4standard View Post
...snip...
...snip...
Double post. And whaaaaaa......? lol
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 21st May 2012, 15:50   #17
DDR4standard
What's a Dremel?
Sorry for double posting.
Basically LRDIMMs and DDR4 are both going to be using NLST IP (search for the article “Netlist puffs HyperCloud DDR3 memory to 32GB – DDR4 spec copies homework”).
LRDIMMs are currently only being made by Inphi, have high latency issues and under-perform as well. So they have failed in copying someone else's IP (no wonder - Inphi hired former MetaRAM CEO as "Technical Advisor" who some years back ALSO conceded to Netlist and went out of business), plus have been unable to copy correctly.
DDR4 does a better job - as they are doing a better job of copying the Netlist IP (expect JEDEC to license prior to DDR4 finalization).
Old 21st May 2012, 16:01   #18
DDR4standard
What's a Dremel?
The technology in LRDIMMs/NLST HyperCloud is called "load reduction" and "rank multiplication".
Currently you only need it at 3 DPC with Romley (as 16GB RDIMMs 2-rank are cheap and work well at 1 DPC and 2 DPC).
3 DPC usually used for virtualization/data centers (lots of memory per server for all the VMs you want to run).
When 32GB RDIMMs arrive, however the need for this technology will shift to 2 DPC also (i.e. more mainstream even) - because 32GB RDIMMs will be 4-rank (as 2-rank cannot be made for a couple of years because of lack of 8Gbit DRAM die).
Both LRDIMMs and NLST HyperCloud are available from IBM and HP. HyperCloud is called IBM HCDIMM and HP HDIMM (HP Smart Memory HyperCloud) - delivers 1333MHz at 3 DPC. HP ships it with their virtualization servers DL360p and DL380p only at 3 DPC (i.e. fully loaded 24 DIMMs per server).
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
