Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 9th May 2012, 11:25   #1
joao paiva
What's a Dremel?
joao paiva has yet to learn the way of the Dremel
Is there any way to remove solvent from acrylic/plexiglas?
Hi everyone, I was trying to "glue" some acrylic sheets for a model, and I am having some major problems applying the solvent to the joint parts... so some solvent came out of the joint part leaving a stain....is there anyway to remove it?
thank you in advance
joao paiva is offline   Reply With Quote
Reply
Tags
acrylic sheets, remove, solvent
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
