| View Poll Results: What is the best option? | |||
| SSD (suggestions of value vs preformance) |
19 | 90.48% |
| Add 12 GB kit and fill all the slots |
0 | 0% |
| Buy 24 GB kit (MB Max) |
0 | 0% |
| Just over clock (video cards or CPU) please provide comments |
2 | 9.52% |
| Voters: 21. You may not vote on this poll | |||
Thread Tools |
#1 |
I think we can make that fit
SSD OR MORE RAM
Currently I am running and I7 920 6GB of TRI channel ram and 2 80GB WD blue HDD in Raid 0 on a EVGA E760 3way Classified board with 3-260GTX in SLI and a 9600 for Physx. The rest of the rig is in my SIG. I notice when I'm gaming on WOW (don't start bashing on it) in 25 man Raids my FPS take a serious hit down in to the 20-30 FPS range, and the game starts lagging. My ping is fine down in the 40-50 MS range so that's not the issue. So I am trying to figure out what will benefit me more a SSD or upgrade ram from 6GB to 18GB or 24GB or buy a new video card and drop the SLI?
P.S. Computer during gaming is using over 3GB of ram. Comments/Suggestions please.
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses Last edited by Mechh69; 9th May 2012 at 18:12. Reason: had to add additional information |
#2 |
будет глотать вашу душу.
More ram will do nothing for you in 32bit games. SSD would be most beneficial overall, but won't help your FPS either. How about a more recent GPU? One good current GPU instead would be a much better way to go.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx | creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270 |
#3 |
Hypermodder
Wouldn't the CPU be a bottleneck in 25-man raids? If not then I'd say a GPU upgrade. RAM wouldn't help. SSD would be great, but wouldn't improve FPS in multi-man WoW raids.
__________________
Antec 300 | Gigabyte GA-P55M-UD2 | Core i5 750 @ 3.6ghz | Corsair XMS3 4GB 1,600Mhz | XFX HD5850 | 120 GB Corsair Series Force 3 SSD | 2x 1TB Samsung F3 (Raid 1) | Titan Fenrir | BenQ G2220HD 21.5" Widescreen | Corsair VX550W My website: Computer Lover |
#4 |
CPU usage does go up during 25mans but it's not maxed by any means.
How do i edit the poll?
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses |
#5 |
Supermodder
SSD and more Ram, Ram kits are pretty cheap.
__________________
Silverstone RV-02 White edition / Asus Crosshair V / AMD 1090T Phenom @ 4 GHz RAM 16Gb G.Skill RipJaws Z 1.5v DDR3 @ 1600 / 2x XFX 6870 Black Editions 1x Crucial M4 64Gb /4 x 1Tb Samsung (Need to check what models) PSU = Seasonic 760w GOLD rated |
#6 |
I Mod, Therefore I Own
Get an SSD.
That 9600 is more than likely acting as a bottle neck as Physx goes.
__________________
I5 2500K @ 4.8ghz l MSI GD53l 8GB corsair 1600mhz l Asus 5870 v2 NZXT Phantom Red l Zalman X10 Quiet l 60GB Crucial M4l F3 1TB Spinner l X-Fi Titanium Fatal1ty l 700Watt Thermaltake l Samsung IPS231 l Steam: murraynt |
#7 |
So should i just pull the 9600/disable it as a Physx card?
__________________
#8 |
I would anyways. System will run cooler and consume less power.
Did you ever try overclock that CPU?
__________________
#9 |
The 9600 I have not tried to OC the other three are OCed from the factory I could probably push them a little further but not sure how much.
__________________
#10 | |
![]() Rip out the 9600 Get an SSD Overclock the CPU. Do you have an aftermarket heatsink or the stock one?
__________________
#11 |
Supermodder
Go for the SSD. You won't regret it.
#12 |
After market CPU Cooler the Scythe Mugen 2 with 2 120 in push pull.
__________________
#13 | |
![]() 3.4ghz should be easy
__________________
#14 |
Ill try it out and see what it does when i get home and ill let you know how it works out. Off to find the OC thread on the 920 again.
__________________
#15 |
wow only uses 2 threads at max anyway - 1 for sound unless you `hacked` to re-enabled hardware sound ; get a faster ard - i use an X6 1090T (3.6ghz) with 8 gig ram , and with the 64bit client the game is using 1 gig , and i actually have nearly 2 gig doing nothing.
so more ram wont do squat. SSD? faster zoning - even with the 1st gen ssd i have i have to wait usually for the server to catch up - but it doesnt help with fps. what settings in game you use? - i would honestly look at a new video card , use 1 of the gtx 260`s for physx and get something like a gtx 560ti
__________________
i have a 3dfx voodoo5 6000 |
#16 |
moo
Yep, overclocking the CPU will make the difference in a game like WoW, none of the upgrades you suggest will help - unless WoW doesn't support SLI (can't really remember) in which case it could benefit slightly from a newer graphic card than your 260.
__________________
Main System & HTPC Specs |
#17 |
Modder
I have to agree with the people saying drop your physx card and overclock your cpu based on personal experience in wow.
On a side note im not sure why your game is lagging if you are not dropping below 20-25 fps. |
#18 |
goodateverthinger
SSD & Overclock for more FPS
#19 |
I see activity on all 4 cores in wow while playing at least that's what the CPU Meter shows when I get home tonight ill pull the 9600 work on the OC and monitor the CPU/Thread usage and post the results. Thanks for the advice guys. I appreciate it.
__________________
#20 |
Supermodder
Don't get more ram, thats just trowing away monney, a ssd will help you a little, you could check how fast your hdd's are atm, my old drive had a read speed of 35mb/s that holds you back alot!
Considering the GPU upgrades every one said, yes you could do that! Even a gtx550 will max out WoW. What fps are you aiming for? is a minimum of 30 good enough or do you want a constant of 60+ fps? |
| Thread Tools | |
