Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th May 2012, 08:40   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Titan Fenrir Siberia review
Titan's latest cooler is a huge, with a split heatsink design to cool your CPU and motherboard.
http://www.bit-tech.net/hardware/201...beria-review/1
brumgrunt is offline   Reply With Quote
Old 10th May 2012, 08:50   #2
dactone
dact-one
dactone's Avatar
dactone has yet to learn the way of the Dremeldactone has yet to learn the way of the Dremeldactone has yet to learn the way of the Dremeldactone has yet to learn the way of the Dremel
it makes you think ,do company's even test there products in the prototype stage ?
__________________
2500k-Asus p8z77-Gtx 560 ti-Bit fenix prodigy
dactone is offline   Reply With Quote
Old 10th May 2012, 09:01   #3
Jaybles
Hypermodder
Jaybles's Avatar
Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!Jaybles - it's over 9000!!!!!!!!1!1!1!!!
I feel like I should point out it isn't a unique design.
Prolimatech Genesis
__________________
i7 950 @ 3.8 1.192v|Noctua NH-U12P SE2|Asus P6X58D-E|12 GB DDR3 1600|1TB Samsung Spinpoint F3|Samsung 830 64GB|XFX Double D R7950|Asus Xonar DG|Antec Quattro 850w|Bitfenix Colossus|Dell U2311H|Dell E173FP
Steam|PSN:nythraln
Jaybles is offline   Reply With Quote
Old 10th May 2012, 09:20   #4
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Jeez, what a monstrosity. I can see people buying it if it was the mutt's nuts, but there's no way I'd put up with the amount of obstruction it creates inside the case; regardless of how it performed.
I'd like to be able to change my RAM without having to remove the motherboard.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|16GB|256GB M.2|500GB SSD|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Old 10th May 2012, 09:35   #5
hyperion
Hypermodder
hyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyanhyperion is a Super Spamming Saiyan
I think that an enthusiast would not be depending on the cpu cooler to cool the motherboard, and if you're going big then you might as well go for a noctua D-14 or something like that. It's not low-profile or high-performance either. I think the concept for this cooler was wrong, unless the concept was to market a gimmick.
hyperion is offline   Reply With Quote
Old 10th May 2012, 09:45   #6
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Prolimatech Genesis
You are correct; it wasn't very good either though.
Baz is offline   Reply With Quote
Old 10th May 2012, 09:46   #7
tonyd223
king of nothing
tonyd223 has yet to learn the way of the Dremel
How much? You having a laugh or what? And, just for a laugh, bet it doesn't perform well if you remove the fans and use it as a passive heatsink, because there's no space to put your normal case fans in...
tonyd223 is offline   Reply With Quote
Old 10th May 2012, 09:47   #8
Baz
I work for Corsair
Baz's Avatar
It's odd how the heatsink market has changed. When I started at bit-tech, 60 for a Thermalright Ultra Extreme wasn't seen as a bad investment, but the success of liquid coolers has pretty much made high-end heatsinks redundant. /discuss
Old 10th May 2012, 10:01   #9
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
Its obviously been named after the Siberian summer months, think I'll stick with me Frio a while longer yet
PingCrosby is offline   Reply With Quote
Old 10th May 2012, 10:15   #10
David
RIP Tel
David's Avatar
Good point. We need another "Freezer 7 Pro moment" - Something cheap, easy to fit, relatively compact with great performance - to revive the HSF market. I'd buy one for one of my spare rigs.
However, I wouldn't touch an air cooler in the 40+ price range, but I am a WC fanboy and so probably not the most objective chap to ask.
__________________
Old 10th May 2012, 10:16   #11
warejon9
Multimodder
warejon9 has yet to learn the way of the Dremel
Maybe it performs better in an open test bench? Due to it looking like it might have struggled due to the lack of case airflow around it? Either that or the front 120mm fan blows hot air onto the send radiator.
warejon9 is offline   Reply With Quote
Old 10th May 2012, 10:39   #12
Siwini
What is 4+no.5?
Siwini's Avatar
Siwini has yet to learn the way of the DremelSiwini has yet to learn the way of the Dremel
Push/pull configuration would definitely help
__________________
Win7 Pro 64Bit | I7 860 @4.0Ghz XSPC RS240 | Gigabyte P55-UD5 | 8GB G.Skill 1600 7 8 7 24| Crucial C300 64GB SSD | 2x 1TB Samsung F3 RAID0 | Asus GTX 570 | Asus Xonar DS 7.1 | Logitech Z-2300 | Corsair CMPSU 850 ATX | Xigmatek Utgard | Dell U2410
Siwini is offline   Reply With Quote
Old 10th May 2012, 10:48   #13
echo three
Multimodder
echo three has yet to learn the way of the Dremel
this
__________________
3570k @ 4.5 | 16 GB corsair lp 1600 | 128 GB Samsung SSD | corsair 850 ax | corsair h100 with 4x corsair static pressure in push pull | corsair 650d | asus GTX 670 directCU II top | Asus P8Z77-V PRO
echo three is offline   Reply With Quote
Old 10th May 2012, 10:57   #14
Saivert
Supermodder
Saivert has yet to learn the way of the Dremel
I wouldn't buy this cooler for sure.
But. I would love if Bit-tech focused on the clearance near/above RAM slots.
The cooler in this review seems to be designed to allow good space for RAM modules but I didn't really get a sense of it from the pictures. Maybe take out the motherboard and give us a side shot.
A lot of coolers clash with RAM modules that has tall heatsinks like Corsair Vengeance do.
__________________
- I'm the troll who bumps page 2 topics -
Saivert is offline   Reply With Quote
Old 10th May 2012, 11:06   #15
Almightyrastus
Rule #9
Almightyrastus's Avatar
Almightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming Saiyan
One thing I would like to see from HS manufacturers is to produce a template for a paper model of the same size and shape of the finished unit, nothing super detailed just a simplified blocky model so you can try it and see if there will be any conflicts.
I wouldn't have thought it will be a hard thing to produce as they will no doubt already have an accurate 3D CAD model of the HS
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever.
Almightyrastus is online now   Reply With Quote
Old 10th May 2012, 11:24   #16
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan
The above is a damn good point, if I could've printed off a blocky outline of my Archon before i bought it and used that to check sizing; I'd've saved a damn good bit of time, it only barely fits in my Raven as is.
I think half the issue is that Copper and Aluminium are getting more expensive, so the good materials aren't that amazing.
I think the best heatsink out there at the second in a reasonable pricerange is the Frio, tbh. The recipie is proven. All that's needed is to make it cheaper still.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Strix Soar | 2X SLI Gigabyte Windforce 670 | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | 2x Hynix SL301 250GB RAID0 | 2x WD 3TB RED RAID0 | Lite-on Blu-ray ROM
Dell U2913WM | Sennheiser HD 518s | Microlab Solo8C Speakers | Logitech G13 | Ducky Legend (MX Blues) | Func MS-3
.//TuNdRa is offline   Reply With Quote
Old 10th May 2012, 11:46   #17
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
h80 performs better costs less and is an easier install you would have to be mad to buy this
rollo is offline   Reply With Quote
Old 10th May 2012, 11:51   #18
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
My silent running water cooled PC with EK CPU block, Eheim pump and slimline 320 rad is running 24/7 for over two years now without a refill. It never gets above 34c on load, running on a six core AMD Phenom (non overclocked) In fact before my rebuild two years ago. it was running the same block/pump/rad combination 24/7 since late 2003 on a AMD 4800+.
So I can say that my experience with the same WC setup is almost 9 years. And until now any aircooler the industry has invented never reach the temps I get with my trusty 9 year old WC setup. Let alone survive that long.
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 10th May 2012, 11:54   #19
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
So are they assuming people who use and abuse computers don't know how to read a review on the internet?
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 10th May 2012, 12:23   #20
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
This "cooler" sums up why I detest air cooling.
feathers is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
