#1 |
Since ZX81
HELP! - Remove EK Nickel plating from copper?
Ok, I have a pair of EK FC-470 blocks, One is the older block with the shitty nickel plating on it, the other is copper.
I also have a nickel backplate as well as the black one. All bought second hand and outside of warranty. I would like to remove the nickel from the block, down to its original copper and remove the nickel from the backplate to paint it the same as the black one...phew. Apart from these being the horrible EK gash nickel plating, Does anyone know how I can strip them at home, easily. I have searched the net and there are many references to chemicals which I'm not really qualified to be breating in ![]() A big shiny internet Blue Peter badge for helpfull reply's!!
__________________
Sent from Discovery One using HAL 9000 __________________________________________________ _________________ Rig under construction |
#2 |
Grr... Grumpy!!
Personally I'd go with a weak)ish) Hyrdochloric Acid. I use 30% Hydrochloric acid & Hydrogen Peroxide (mixed 1 part acid 2 parts peroxide) for PCB etching. Not too dangerous if you work sensibly, wear nitryl gloves and glasses.
I've also quickly googled it and given i've used Hydrochloric acid before I would say its home safe, you just need to work steady and safely, respecting the dangers at all times. The only issue I can forsee is it would also eat the copper so you would have to take care with the time its subjected to the solutions and pitting may be a factor - also even removal of the nickel as areas removed quicker than others would expose the copper for longer - Not sure I'd try unless it was something I didn't care too much around messing up.
__________________
-: MM UF0 Duality :- 2700K, 16GB Ballistix Tracer 1600, P67A-GD65, RAID0@ 2x120GB Vertex3, 580GTX, AX1200 :- -: Dual Loop Watercooling :- 2x Laing D5, 2x PA120.3, EK 580GTX Fullcover, EK Supreme HF, EK TubeRes :- |
#3 |
'Black Noise'
I'd be interested how you get on with this.
#4 |
Since ZX81
Cheers everyone.
I managed to get a second copper block, And now have two plexi tops for them. So i'm giving up on the nickel ones. Thread closed
__________________
| Thread Tools | |
| View Mode | |
