Reply
Thread Tools View Mode
Old 11th May 2012, 00:49   #1
ALS
Multimodder
ALS's Avatar
ALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming SaiyanALS is a Super Spamming Saiyan
Velociraptor
Hi all.
Project named Velociraptor. Small, fast, predatory.
Hardware.
PowerColor HD7950 PCS, i5-2500k (later replaced by i5-2500S), ECS H67H2-I, 2,5" HDD, SSD.
Power consumption and PSU.
Enermax about similar config (HD7950/i5-2500k/Green HDD/SSD/etc...):
ok, check it (I use a DIY power meter) :
so, power consumption :
1 - 3DMark11 (Extreme level)
2 - OCCT ("Power supply mode" until 2 minutes)
baby FSP300-60LD working well, but Chieftec CFT-700-14C not need a big ventilator, enough small 6-cm at 7,5volts).
But I need more quiet PC and I choosed a "golden" FSP AU-700 - lightweight, powerful and cold.
Becouse it works with my config without any active cooling :
Case
Material - aluminium. А several variants, I chose the first :
ALS is offline   Reply With Quote
Old 11th May 2012, 01:16   #2
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
Looks interesting. But why did you use a H67 board with a 2500k? You won't be able to overclock, therefore not taking advantage of the cpu's massive headroom.
Z68 boards for mini-itx are awesome.
But looks interesting, i love SFF builds, i'll be watching.
__________________
Main Rig: i3 3220 ~ GTX 970 Strix ~ 8GB Vengeance Ram ~ EVGA Supernova G2 750W ~ P8H77-m le ~ Samsung 830 128GB SSD ~ Steelseries GCv2 ~ Razer imperator ~
Darkwisdom is offline   Reply With Quote
Old 11th May 2012, 06:46   #3
ALS
Multimodder
ALS's Avatar
The motherboard previously has been used in my HTPC, I didn't buy her.
Also, in this case there may be problems with cooling the overclocked components.
Old 11th May 2012, 08:43   #4
Mindphaser
Multimodder
Mindphaser's Avatar
Mindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpitMindphaser is almost as Godly as yodasarmpit
Welcome to the major league!
Mindphaser is offline   Reply With Quote
Old 11th May 2012, 13:01   #5
ALS
Multimodder
ALS's Avatar
Mindphaser,
Old 12th May 2012, 19:22   #6
ALS
Multimodder
ALS's Avatar
Old 13th May 2012, 00:04   #7
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
King of micro-mini mods? Yes, im in.
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen ~ Admin at Xoxide Forums
Furball Zen is offline   Reply With Quote
Old 13th May 2012, 08:10   #8
ALS
Multimodder
ALS's Avatar
King ? Maybe
Old 14th May 2012, 11:05   #9
ALS
Multimodder
ALS's Avatar
Old 16th May 2012, 18:52   #10
philosopher
I use a Dremel to clean the teeth
philosopher's Avatar
philosopher has yet to learn the way of the Dremelphilosopher has yet to learn the way of the Dremel
Hallo, comrade !!!
Glad to see your project here!
Maybe you can help me to find the optimal location of the power supply relative to other components? My project has been stalled because of this ...
philosopher is offline   Reply With Quote
Old 16th May 2012, 19:08   #11
ALS
Multimodder
ALS's Avatar
Hi
I can (maybe), but my English...
See you at modding.ru
Old 17th May 2012, 10:54   #12
Williz
Supermodder
Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.Williz is definitely a rep cheat.
Looks promising for such a tiny mod +1
__________________
Corsair Carbide 540 / Asus Crosshair V / AMD 1090T Phenom @ 4 GHz
RAM 16Gb G.Skill RipJaws Z 1.5v DDR3 @ 1600 / Asus R9 290 / Crucial M4 64Gb / 1Tb Samsung / H100i and a boatload of Gentle Typhoons / Seasonic X760w GOLD
HP Microserver N40L / 128Gb Samsung SSD / 4x 1Tb drives / AMD 6670 / Asus Xonar DG(x?)
Williz is offline   Reply With Quote
Old 17th May 2012, 11:57   #13
ALS
Multimodder
ALS's Avatar
Thanks !
"Enlarge your ... riser"
w/o any risers and with Bigger Longer & Uncut :
Old 17th May 2012, 20:44   #14
ALS
Multimodder
ALS's Avatar
Old 3rd Nov 2012, 22:14   #15
ALS
Multimodder
ALS's Avatar
Old 3rd Nov 2012, 22:34   #16
patara
life is wonderful
patara's Avatar
patara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremel
ALS is glad to see you,than plan to sew up an external part of the case?
__________________
patara is offline   Reply With Quote
Old 3rd Nov 2012, 22:45   #17
ALS
Multimodder
ALS's Avatar
hi !
perforated aluminum panels
Old 14th Nov 2012, 22:56   #18
ALS
Multimodder
ALS's Avatar
Old 14th Nov 2012, 23:28   #19
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
Interesting stuff. Will be keeping an eye on it.
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 20th Dec 2012, 22:47   #20
ALS
Multimodder
ALS's Avatar
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
