Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 11th May 2012, 18:06   #1
Entropy
le mayo
Entropy's Avatar
Entropy has yet to learn the way of the Dremel
Problems installing XMS3 1333MHz in a P5KC
I have been using 4GB of 800MHz DDR2 for a few years now and decided it was time to upgrade, so I bought 2x 4GB 1333MHz sticks (as mentioned earlier, they are Corsair XMS3).
I am using an ASUS P5KC motherboard which has 4 DDR2 slots and 2 DDR3 slots, but it seems to just not register the DDR3 ones at all. As I write this I have both one stick of DDR2 and one of DDR3 in my motherboard, and obviously my computer is fine. Is it most likely the DDR3 sticks just aren't working?
I've tried unplugging my hard drives and DVD drive and having only one, the other and both of the DDR3 sticks in at any one time, but the computer has never booted.
I'm using a C2D E8200, a GeForce 9600GT, Samsung 1TB and Maxtor 500GB hard drives.
Entropy is offline   Reply With Quote
Old 11th May 2012, 18:47   #2
lancer778544
isnt really an ultramodder...
lancer778544's Avatar
lancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpitlancer778544 is almost as Godly as yodasarmpit
If my memory serves me correctly, you can only use DDR2 or DDR3, you can't use both at the same time. I'll do some more research now.
Edit: Yep. Page 38 of the manual, "You can only install either DDR2 module(s) or DDR3 module(s) on the motherboard; otherwise, the system will not boot up."
__________________
AMD Phenom II X4 955 @ 3.8GHz | Asus Crosshair II Formula | 8GB Corsair XMS2 DDR2 | EVGA GTX 570 SC & PNY GT 440 | Corsair Force 3 120GB | 1TB Seagate Barracuda | Enermax Infiniti 650w PSU | CM Storm Trooper | Creative Soundblaster X-Fi Platinum Fatal1ty Champion Series | Windows 7 x64 | Dell U2312HM primary (570), Samsung SM940BW secondary (GT 440) & Sony 32S3000 occasionally (570)
lancer778544 is offline   Reply With Quote
Old 11th May 2012, 19:00   #3
Entropy
le mayo
Entropy's Avatar
Yeah you're right, I was just plugging them both in because I was curious as to what would happen. I have established now that one of the sticks doesn't work, however another issue has presented itself.
Each stick individually should be more powerful than my old two sticks (4GB 1333MHz vs. 4GB 800MHz), yet when I had the one working 1333 stick in, the "Windows Experience Index" scored a 6.4 on the memory. With my old DDR2 in, it scores a 6.7. Can anyone explain this?
I am in the process of returning the memory, hopefully the replacement will be working!
Old 11th May 2012, 19:08   #4
lancer778544
I wouldn't worry about the WEI number, the 1066MHz DDR2 in my PC scores 7.7 as a reference. As long as the PC at least feels as fast, I wouldn't worry about it. It's probably the fact that a single stick will only run in single channel mode rather than the 2 sticks of DDR2 in dual channel mode causing the lower number.
__________________
Old 11th May 2012, 19:13   #5
Entropy
le mayo
Entropy's Avatar
That's what I have done, just one of the DDR3 sticks doesn't work. I'm going to return it as soon as possible so hopefully it's all up and running within a week.
Old 11th May 2012, 19:14   #6
lancer778544
Ahh, so I see, I should have read the first post properly Hopefully the new stuff will work for you
__________________
Reply
Tags
1333, corsair, e8200, p5kc, xms3
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
