#1 |
Administrator
bit-tech Staff
Intel details 10nm, 7nm, 5nm process roadmap
Intel has released slides claiming that research has begun on 10nm and below process nodes.
http://www.bit-tech.net/news/hardwar...cess-roadmap/1 |
#2 |
Multimodder
MOAR TRANSISTORS!
Doesn't seem that long ago that I was getting excited for 45nm... 65nm seemed small enough already at that point.
__________________
Core 2 Quad Q9400 @3.4GHz | Gigabyte EP45-DS4P | 8GB (4x2GB) Gskill DDR2-1066 CL5 | Galaxy GTX 260 @650/1150
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | 2TB Seagate Barracuda | 1TB Samsung F1 | 2TB Seagate Barracuda Green| Corsair TX750 | Creative SB X-Fi Titanium 22" LG W2253TQ | CMStorm Quickfire Rapid | Sidewinder X8 | Logitech X-540 5.1 | Corsair Vengeance 2000 |
#3 |
ITX is where it's at !
Or just MOAR thermal issues ?
dunx
__________________
Asus P6T7 WS Revo. + Asus U3S6 - i7-960 @ 3.8 GHz - Corsair H70 - 6 GB Corsair DDR3 @ 1600 MHz - 64 GB Cucial M4 SSD - Dual WD Caviar Black 1TB SATA III HD's - HD 5870 + GTX 480 - Coolermaster 1250W PSU - ANTEC P280 - 4 x 240 V server fans - Griffin Powermate
#4 |
Multimodder
Good point. Someone should tell Intel to stop following Moore's law. We don't want moar transistors.
I would like to think alternative semiconductor designs will deal with any thermal problems. Surely that is what they would be working on?
__________________
#5 |
I've been away far too long
I beg to differ, we do want MOAR transistors, but we want them without needing LN2 to keep the CPU cool at stock speeds lol
I'm guessing they're already thinking about how to deal with the thermal issues given the poor thermal properties of Ivy Bridge.
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU |
#6 | |
Officious Bystander
__________________
My Flickr
#7 | |
still wants Homeworld 3
the CPU itself is great, performs well as you said. but the processor as a product is disappointing due to the poor thermal interface materials used between the die and the heatspreader. hence the "heat issue" mentioned. solution is to change manufacturing process by soldering the heatspreader onto the die. at least that should work for a few years until 7nm made the "heat issue" resurface.
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr |
#8 |
Hypermodder
At this rate, Intel will need to work on their molecule-shrinking technology to keep Moore's law going.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | MSI Radeon 7970 | 128GB Crucial C300 + 1TB Samsung F3 | CM Silent Pro Gold 600W | Samsung XL2270HD Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 |
#9 |
I Mod, Therefore I Own
both chips under stock settings stock cooler reach about a similar temparature
once overclocked is the temp dif at 4.5ghz the temps are aproaching 100c on most poor air coolers really do need a decent chip + cooler to get a overclock going |
#10 |
fast as you can and don't fall off
Looking forward to the first picometer chips
__________________
i7 3930 @ 4.7Ghz : Asus Rampage IV Extreme : 16Gb Corsair Vengeance @ 2133Mhz : 512Mb Crucial M4 : ANTEC High Current 1200W : 2 x GTX570 SLi : Swiftech Apogee HD : XSPC dual bay res / pump : Custom water loop with 1 x 360 rad, 1 x 140 rad, CPU, GPU SLi, North and South blocks : CM Storm Spawn mouse : Logitech G15 : Creative X-Fi USB : Corsair Obsidian 800D : Crappy DGM 26" 1920 x 1200 monitor : Sennheiser PC350s : Belkin Nostromo : Alarming beer habit |
#11 | ||
__________________
#12 |
I *am* a Dremel
Why not do a 32core at lower speeds with more cache. I really do not care if the processor takes 5x5cm or 1x1cm of space. In idle mode let 31 cores sleep to save loads of energy.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. In 1982 I was addicted to Lady Bug and played it in the local arcade (every day) And yes i'm proud I did that! |
#13 |
Pointless processor is pointless, at least in a consumer environment. You're hard pressed to find software that utilises anything more than 4 cores, let alone 32. In a server environment though, it'd be a good move.
__________________
#14 |
I'm no expert in processor design, but how about spacing the four/six cores out on a bigger chunk of silicon, and adding the system RAM to fill the spaces in between ?
dunx
__________________
#15 |
But then RAM wouldn't be upgradeable, at least not without removing the IHS.
__________________
#16 |
Multimodder
I, for one, welcome our sub molecular overlords ...
__________________
DargonZine: The longest running fantasy magazine on the net. Period. |
#17 |
Multimodder
When I see stuff like this, I begin to wonder if something DID crash at Roswell.
#18 | |
14 year old Technophile
http://www.techpowerup.com/165882/TI...After-All.html |
#19 | |
Multimodder
#20 | |
Officious Bystander
Anyway, nomenclature aside, I understand the point - IB chips get hotter than they would if the process was different - but the temperature in itself is pretty meaningless. What counts is how the chip performs, and (heat issue or no heat issue) IB chips are epic.
__________________
My Flickr
| Thread Tools | |
